Question about Toshiba Satellite A135-S2276 Notebook
Help pls help. while downloading songs my loptop hanged then i turned off manually and when i turned it on the comp is asking for a password.. i tried already my log in password but it didn't workout. what happened to my laptop i cant used it.. is there a way i can reset the password.. pls help me tnx
  • 9 more comments
  • eiyee Feb 22, 2008
    technomanic, im using vista.. they say that the password asking is the bios password.. can u help me how will i reset this password thanks
    technomanic, the problem it is a laptop.. toshiba satellite A135-S2276 help me pls thanks so much
    technomanic, itried already the jopen1 but when i turned on my laptop.. there is no display in the lcd? what happened?
    technomanic, how will i check the RAM? how will i reset?
  • eiyee Feb 23, 2008
    technomanic..... there's no display in my lcd after the short thing.. can u help me? pls what happened? but there is a power when i turned it on..
    technomanic.. got it.. i tried the f2 but the enter password appeared again.. it says phoenix bios setup utility then enter password..
    technomanic.. got it.. i tried the f2 but the enter password appeared again.. it says phoenix bios setup utility then enter password.. nothing happen.. ill repeat again
    guest.. ill reapeat again if i short the jopen the T over U----thats the only one where i connect the metal thing? where at the U only? pls HELP
    thank you i short it again and follow the instruction...
    it all works
    thanku
  • jainijain Apr 22, 2008
    same problem
  • sufiyan kakingarae May 11, 2010
    may i know wich OS u r using
    wich browser u use
    how may user accont u have
Please help me! I just bought a laptop from a friend who has a 10 year old son who reset the BIOS password, and no one can figure it. We dont know the os or anything other than the model number... please help...
Toshiba Satellite M45-S351
Posted on Sep 23, 2008
It works.. thanks technomanic!
Posted on Feb 23, 2008
Do it once again.jopen has not been shoe. follow the insruction again , and please let me know.
    Problem Solver:
  • 10 Answers
Only way you can reset bios password is to reset the BIOS . to do this
*if its an desktop
open tower , inside the tower you'll see motherboard
look out for battert (wich is size of nickle)
remove the battery and wait fo few second
then insert it back
reboot................
*if its an laptop , let me know model no and make
Posted on Feb 22, 2008
  • 6 more comments
  • sufiyan kakingarae Feb 22, 2008
    Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. insert memory modules. insert battery. Power up unit. If all is well, replace memory cover and screw.
    The default password for the BIOS is phoenix. phoenix is all lower case letters. Another thing you can do is as the system is booting up, right before you get to the Toshiba splash screen, you have to tap on the Shift key
    please try it first
    1)Remove Laptop Battery
    2)Take off Memory Cover(underneath - square cover, Sits
    in middle of laptop 1 retaining screw
    3)Using two thumbs spread spring clips to outside and
    pull out RAM memory.
    4)Remove clear vinyl label opposite RAM memory slots in
    upper left corner( laptop battery slot is on right, DVD
    drive is facing away from you)
    5)Using a magnifying glass (unless you have perfect
    vision)in the upper left corner you will see JOPEN1 with
    a white silkscreen square next to it . Inside the square
    you will see what looks like the letter T over a U.
    Using a metal paper clip short the U to the Silver 1/4"
    post connecting the motherboard to the laptop case(this
    is you ground, it is located above what looks like a
    silkscreen outline of a chip)hold for 25 -30 seconds.
    6) Place back your RAM memory, put in the laptop battery
    and test start laptop. you should see a selection of F1
    or F2 for setup. Using the F2 gets you into the Bios
    menu where you reset the time and date. Then Tab over to
    the SECURITY setting tab and change your passwords. Now
    hit F10 key ,yes to save and your done!
    reseat RAM again , and please let me know
    please replay to me as i dont have much time .
    check power supply , check RAM,
    i know how u'd feel , i can help u if u r in live chat
  • sufiyan kakingarae Feb 23, 2008
    hit F10 key
My aspire5600 loptop password i forget asking me user name welcome and password i dnt knw how can i open my loptop
hi there you can see a option in small text " forget password?" click there & give the asking question answer. if you not done then let me know.
Jan 17, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
How do i get songs from my comp to my n99i phone?
well what i do is access my phone through Bluetooth and that's about it. I'm still trying to figure out how to download through the wire cable since my n99i only charges my battery and my laptop doesn't even detect it
Feb 22, 2009 | Dual Electronics N99i Cellular Phone
My sa5245 cannot be turn off,it is hang,pls help whether restting
Using a paerclip to trigger the reset hole will not erase any of your songs.
If that fails, however, and you have to upgrade the firmware, you will lose all of your songs
-Tha Mp3 Doctor
Dec 31, 2008 | Philips SA2310 GoGear Mp3 Player
Compaq loptop power on password
When i turn my computer on it wants a password its not a login password but its like a startup password and i cant remember it i was wondering if you can pls help me pls... Thank you so much if you can help:-)...
Aug 07, 2008 | Compaq Evo N610C Notebook
Cant playing full songs.....
when you installed itunes did you check the box where it asked you to automatically eject ipod or manually eject?
Jul 25, 2008 | Apple iPod nano
Help please!
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw.
Feb 22, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
283 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
