Question about Toshiba Satellite 2415-S205 Notebook
Laptop will not charge
All of a sudden my laptop will not accept a charge. I purchashed a new ac adapter but this did not correct the problem. What could be causing this problem and how can I correct it?
  • 5 more comments
  • jdude8 Feb 22, 2008
    Hi Maggie B,
    The battery is the origional that came the laptop.
    The unit is not charging at all.
    the ac adapter does indicate that it is receiving power from the wall but the computer does not show any indication that it is receiving the charge when plugged in.
    thanks.
    The computer will not charge and therefore will not turn on at all. Also there are no activity lights on the computer when I open the screen and look at the activity lights.
    Thanks.
    Shaun,
    thank you for the suggestion. I tried to manipulate the prongs but this still did not work. Any other ideas?
  • Anonymous Feb 23, 2008
    I need to restore my hard drive to how it was when this computer was first brought. I need the system recovery disk.
  • Anonymous Aug 31, 2008
    Satellite A105 -S4334 battery wont accpet charge and over time is achieving a lower and lower charge level -from 61 % down to 35% and then stops charging
  • Maggie B May 11, 2010
    How old is your computer/battery?
    Is your unit charging at all -- or is it taking a partial charge and running out of battery extremely fast?
    When you plug the adapter into the unit and the wall plug, does the unit show that it's charging?
    Please see if you can answer any/all of these questions to help narrow down the possible cause of your problem...
    Thanks,
    Maggie B
    Sorry, I have one more question --
    Can you run/use the computer on ac power at all? (Like, if you plugged it into the wall and booted up, it shows in the tray in the right hand corner that it's on ac power?
    Maggie
    Problem Solver:
  • 17 Answers
Make sure you take a good look at the prongs inside the DC jack. I'm not sure the configuration of your DC Jack but if it has bent or pushed in prongs it can cause this as well. Use a flashlight, it helps tremendously!
Shaun
Posted on Feb 22, 2008
  • 37 Answers
If you are using windows XP... plug the laptop in and go to Start Menu... Control Panel... Power Option.... and click on the "Power Meter" tab. There it will tell you the current status....your either batteries or AC power. If says AC then your adapter is not likly the problem. Most likely it is your battery. Over time they can loose their capacity to fully charge.
    Scholar:
  • 41 Answers
I have a strong feeling the problem lies within you power port itself which is part of the motherboard. However, I can't remember if this particular series can run on AC w/o the battery being in place.
That was my next suggestion: pull the battery out and try to power on the computer with it just plugged into wall power if your machine is able to run that way (although nothing I see on my research says either way...
Even if that doesn't work, while you have the battery out of the machine, (and you may or may not have already done this) I would clean the little contacts with a soft, dry cloth and then re-insert the battery.. carefully -- to make sure it's seated right (while the unit is unplugged from the wall you can probably clean the contacts there as well) and try again.
The last thing you can do that won't cost you anything is to go to a place that can test your battery to see if it's out of charging ability. I don't know if you are in an area that has battery "stores", but in our area we have Batteries Plus - they carry notebook batteries considerably cheaper than most stores like Best Buy. They usually will check your battery with equipment they have to see if it can hold a charge.
If they say it's the battery, and you choose to buy one from them, make sure you're able to return it if it won't start charging (I'd take my laptop with me and plug it in right there and wait the few minutes to see if your charge light comes on.)
Obviously, if, with a new battery, you can't get it to draw power to charge the battery, it's the port that the plug goes into in the back of the computer. At that point, if it's under any kind of extended warranty, you should use it to have the part (probably the motherboard) replaced.. if it's out of warranty, you need to decide if it's worth the cost of repair.
Sorry for the length of this note, but I wanted to try to cover all bases with you... Good Luck!
Maggie
Dell m5110 laptop won't charge new battery and ac adapter is not recognized in bios
Try another AC cord/charger with the EXACT same specs as original. Is the battery a genuine Dell battery, if not return it? Some aftermarket laptop batteries don't play well with your computer, the pin-out connections aren't correct and MAY be a fire hazard.
Apr 06, 2013 | Dell Inspiron Computers & Internet
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
When I put my adapter inside for charge my laptop turns off and the light is on saying that is charging but its doing nothing pls help. Regards
Read the article below, may it will help.
Laptop shuts off when AC adapter plugged in
Possible cause:1. Power adapter failure.
Possible troubleshooting steps and repair solution:First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard.
Jan 09, 2011 | Toshiba Tecra M5-384 Laptop AC Power...
Won't accept AC
A couple things to check. In most cases the AC adapter itself fails and needs to be replaced.
  1. If there is another D series AC adapter available, try the system with it and see if the system works. If it does, replace the AC adapter.
  2. If no known good adapter is available, see if the AC adapter is putting out around 19 Volts DC at the connector that would normally plug into the system (Ground is outside of plug, + is the inside not the pin in the center) If you have no power detected, replace the adapter.
  3. If the LED on the AC adapter is not on when disconnected from the system but plugged into the wall, replace the adapter.
  4. If the LED goes out when plugged into the system or the DC jack on the system is loose, then you most likely need the jack replaced or the motherboard replaced both are about $100
Dec 10, 2009 | Dell Latitude D600 Notebook
Ac adapter does not connect to battery
You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
2. Try removing your battery and using the ac adapter. If this works the battery is bad.
3. Try a new ac adapter.
4. Power supply is bad
Jun 05, 2009 | Dell Inspiron E1505 Notebook
Computer wont turn on
hi thanks for using fixya!
May I ask, how many years now is your laptop?
Try to remove the battery, and use the AC adapter instead, connect it to your laptop, check if its going to have a power. Turn it on. If its turning on and working normally, then the problem is your battery, you have to purchase compatible and original battery. If its not working while it is connected to the AC adapter, check if the adapter is supplying power, because maybe the problem is with the AC adapter.
If you need further assistance, let me know.
May 23, 2009 | HP Pavilion dv9628nr Notebook
Battery doesn't stay charged
The problem is with the battery. All Lithium batteries last for around 1000 charges or so. Since the laptop is 2-years old the battery needs to be replaced.
I Hope this solves your problem. Kindly Accept my solution.
Regards, Arjun
Apr 01, 2009 | HP Compaq Presario C306US Notebook
Gateway laptop AC adapter not working
Fixable? Maybe
Sounds like a problem with the power jack on the Motherboard. If so, it is possible to remove the board and replace the jack but this requires soldering skills and is probably not something the average person would want to try.
You might try another adapter to be sure but if it is a motherboard problem the best solution is probably to junk it and buy a new laptop.
Mar 14, 2009 | Gateway 450ROG Notebook
Toshiba Satellite 2415-S205 Notebook Logo
1,781 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
