Question about Heavy Machinery
TUNNISSEN CHIPPER 190 MANUEL GERMAN CHIPPER NEED TO NO HOW TO CHANGE CHIPPER BLADES E.T.C
3 Suggested Answers
SOURCE: I don't have a manual for the tomahawk chipper and
You will need to turn the flails (also called cylinder hammers).  Each flail has  4 sharp corner cutouts, only one of which is in use.  When you turn them you get to use a fresh corner, the dull one is still there but no longer contacts the stuff you are chipping.  You will need to remove the chute to access the flywheel, and by rotating the flywheel access the steel bars (cylinder pins) that hold the flails and spacers.  I lay the chipper down, with a 5 gallon bucket protecting the engine, gas tank, to access the bottom, so that you can, using a punch, drive out the 3/16X3/4 roll pin which can be found in one of the long spacers.  You will note each bar has 4 flails, with two long spacers and two short spacers and the roll pin goes through one of the long spacers.  You buy the roll pin punch at a hardware store.   There are four sets of bars with spacers and flails, so four roll pins.  You will want four fresh roll pins also, because the old ones are compressed and shouldn't be used again.  When you have punched out the roll pin you can then drive the bar from the end (where the chute was) but be sure to line the other end of the bar up with the hole on the other sidewall of the chipping compartment.   When you are trying to punch out the roll pin it helps to stabilize the fly wheel--I use a couple of vise grips in a way that the fly wheel is stable.  When you are pounding out the bar (called a cylinder pin) you will need a slightly lesser diameter long (6-8") bolt as a driver.  You can pound on it and it will follow the cylinder pin as it gets pushed out the other side.   When the spacers and flails fall out onto the floor, then you can turn the flails to use a fresh cutting corner and put the spacers and flails back on.  I find it helpful to file the rough edges of the inside ends of the spacers so they slide easily on the cylinder pins.  Get a round file for this purpose.  Also, keep some WD 40 on hand because these things tend to be stuck.  I do only one cylinder pin (with its four flails and four spacers) at a time, so I correctly put it all back in the right order.   You will see that the the order alternates.)
Posted on Mar 23, 2009
rwvanlue
  • 486 Answers
SOURCE: How to sharpen blades on a Yard Machine 6.5 chipper
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10151
above link will provide a pdf of manual
Posted on Nov 08, 2009
Cub cadet chipper shredder starter coil is locked - will not pull
REMOVE THE SPARK PLUG. You now can safely take apart the unit to remove the covers over the chipper and shredder blades and remove the material stuck in the blades.
Aug 23, 2013 | Cub Cadet CS2210 - 2" 208cc Tow-Behind...
Need replacement chipper blades for 5HP tomahawk chipper. Older model distributed by GardenWay. Model # 47255. Probably pre 2001 bankruptcy action. Would settle for specifications (L,W,Thkness) and type of...
This is the only source that I know of for the older chipper blades. Problem is you need to know the dimensions.
http://www.wesspur.com/chipper-knives/chipper-knives.html
There is an MTD one that is for troy-bilt but was not able to match it up with your unit due to pub issues here on my end: PN is MTD 1901782MA
I recommend you contact these folks to get it sorted out:
http://www.wesspur.com/contact-wesspur.html
Hope this got you pointed in the right direction.
Thanks for using FixYa.
Kelly
Jun 26, 2010 | Troy-Bilt ChipperShredder
Replacement blades for Troy-Bilt chipper-shredder
The knife kit for the 47042 and 47044 Tomahawk Pro chipper is part number 1772231MA.
There are several for sale on Ebay or from a Murray dealer
Mar 12, 2010 | Troy-Bilt Chipper Shredder
I have a troy built 250cc chipper shredder.. it
hi yes you can. when you take the back off you can reach the cuttingwheel and clean everything. after that its ready to use again.
Jan 30, 2010 | Troy-Bilt Chipper Shredder
Need a leaf bag for a chipper/shredder/vac
That is actually a good price. MTD wants $225.00
Oct 04, 2009 | Craftsman 4 Cycle Blower/Vac
I need a owners manual for a 10 hp chipper schreddermodel 24a464g729 serial no. 1io14g4o175 i think i may need blades
Go on line to " PartsTree.com" Start your search by clicking on MTD. Go to chipper/shredders, and fine your Model number, It's listed. In the search window- type in chipper blade. Also, on the drawing schematic of the machine, the blades are # 31 in the list of parts. I looked up the 2005 model. There are are few years with the same Model #.
Jul 14, 2009 | Mtd Products Yard Machines 158CC Tiller
My chipper is throwing long chunks of unchiped
Either your blades are dull or the gap between the intake tray by the blades is too far or is rounded off. Many chippers have a plate on the intake by the blades that can be flipped around when it rounds off. Also some have a edge on the other side of the blade so it can be reversed and give you a fresh edge. Be sure to unplug the sparkplugs and remove the key when going into your chipper to ensure no one can start it when your in it. There is usually a lock bar to keep the blades from moving.
Mar 31, 2009 | Heavy Machinery
Heavy Machinery Logo
248 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
