Question about LG enV3 VX9200 Cell Phone
Can the large display be replaced or repaired. It
Can the large display be replaced or repaired. It works but has vertical lines running through it
  • 23 Answers
If that's the only problem, and all other functions of the phone work, an enV3 replacement display module is available on eBay for around US$38. (This is a single module that incorporates both the inside and outside display screens.)
I successfully replaced this display module in my daughter's phone, which had been dropped twice, cracking first one, then both screens.
However, I wouldn't recommend attempting this yourself unless you have some electronics repair experience, as well as patience, good eyesight for close-up work, and some steady-handed soldering skills. See this thread for some of my comments on this repair.
Posted on Feb 09, 2010
Sony bravia KDL-50W800B got only vertical lines when turn on.
You need to take it to a TV repair service, preferably one that specialises in Sony TV's. There is nothing you can do to fix this yourself.
Jun 16, 2016 | Sony Televison & Video
How do I remove dotted lines running vertical along my screen.
Unfortunately, this is the result of a defective LCD display. A transistor in the LCD matix is either stuck on or off, causing the line. The display must be replaced. More info on this can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Oct 18, 2014 | Garmin Nuvi 1450LMT
Vertical line up to 2 inch
It is damaged and need to be replaced. NO option to repair. Sorry.
Apr 22, 2014 | LG 26LH20 LCD TV
Small vertical pink line on the screen Garmin Nuvi 3590LMT
Most defects of the picture on the LCD display, typically points toward a defective display. We've repaired a lot of units with lines, splotches, color problems, etc. just by replacing the display.
Mar 18, 2013 | Garmin nuvi GPS
Pink/purple vertical line visible
Anytime you see visible lines running through a display, this is usually an sign of an eminent screen failure. It could stay that way for weeks or the lines could multiply and then it could fail. There is no repair for this, only screen replacement.
Feb 20, 2010 | HP w17e Monitor
The monitor just goes out. It displays vertical
vertical lines can mean either a connector problem on the lcd itself or on the motherboard connector or a problem with video ram or the chip. Unfortunately none of those are cheap or easy to fix. You can try an external monitor and if that displays normally then the problem is connector or lcd. You can sometimes find a replacement display at fair prices so if that is it then it might be worth fixing. If it is the motherboard then the repair can cost as much as a new replacement laptop.
Sep 25, 2009 | Gateway MT6451 Notebook
Vertical green line in display
This is a hardware issue. If it's under warranty, no problem, get it fixed. Otherwise, you can either put up with it or replace the unit. LCD displays like this are so inexpensive now that it no longer is cost effective to repair them.
May 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I got white vertical line running down a plasma display panel . they are close together that you cant even see on that side of the tv. on a closer inspection they are blue-green-red-blue-green-.... but...
A vertical line running down a plasma display can be caused by :
faulty buffer module.
Fauly sustain card.
Faulty plasma display.
Try unplugging power cable and see if this helps, if it does not , then you will need to call a technician.
In that case call the support number listed on your owner manual.
If warranty has expired, ask for a warranty extension, if available. this is cheaper than repair cost, and will cover the repair.
Jan 04, 2009 | Sony PFM-50C1 50 in. Plasma HDTV
Vertical lines
Unfortunately you have a bad display. There isn't any way to repair the display itself when these problems occur, but it can be replaced. Usually it costs almost as much to replace a laptop display as it does to replace the laptop, though. You might try an internet search for a replacement screen; there are a good number of sources. You might also check ebay or craigslist. You can sometimes find a dead unit you can get the display from.
Nov 02, 2008 | Compaq Presario M2000 Notebook
Blue Line
Sorry no bulb issue here. theres a vertical sweep issue though. if your not a tech i wouls sugest that you find a good one as this is a solid state set and there are no user replaceable parts inside, so you cannot service yourselfs unless your trained to do so. please seek out a trained tech to assist you in this repair.
Sep 22, 2006 | Akai PT4298HD Rear Projection Television
LG enV3 VX9200 Cell Phone Logo
134 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
