Question about Nokia N86 Smartphone
Where can I get repair parts for the N86 MP8, such as the LCD display and flex
    Scholar:
  • 111 Answers
You can get parts for your Nokia N86 from Inovagent or other cell phone repair experts. You can get the part and install it yourself or an expert can install it for you.
Posted on Feb 08, 2010
I want my restricion network code for my Nokia
Hi, You can get the restriction code for a Nokia N86 from http://www.classicunlocking.com/nokia-n86/rs17wp9/ at affordable cost.
UNLOCKING STEPS FOR NOKIA N86
1 - Switch on your Nokia N86 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N86.
3 - Compose #pw+CODE+1#.
4 - The Nokia N86 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N86 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N86
Oct 09, 2012 | Nokia N86 8MP Unlocked Dual-Slider 3G...
Can't read any information in the window
hi,
Is your phone still works even w/o display?
there are several reasons why display disapprears.
1) probably your phone experience accidental impact and that causes lcd flex connector to get loose and causes no display.
2) defective or damaged flex connector.
3) defective lcd or open line connection to lcd.
You can fix it yourself if the problem is on no. 1 (loose connector). open your phone slowly (since delicate parts inside and remember its part placements) using screws driver and locate the lcd flex connector (usually behind the LCD) that connects the lcd to the main board. remove it slowly not to damage it and look for abnormalities, if none, then put it back securely and assemble your unit. then give it a try...
for problem 2 and 3. You can order flex or lcd at ebay and change it yourself. be sure it is the right type for your unit. for dismantling your unit be sure to remember the parts, how they are installed and how to put it back. Be patient and this requires a lot of time to disassemble.
Good Luck!
Don't forget to rate me OK! Thanks...
Hope i helped you...
bst rgrds,
John
Jan 25, 2011 | Uniden Cordless Phone
J700 white display,i have change the flex and display but same problem
hi,
is your phone still working even no display? i mean, does it still receive calls or messages?
if it does, then the problem is within the flex or lcd. be sure to change the good one cause sometimes you get a devective parts. if your sure the parts you just placed in are good, then most probably the problem is in the hardware, that is the video circuit or video ic and it is difficult to repair instead have it repair to technicians.
if your phone just displays a white screen and doesn't work, receive or make calls then it has a software problem and need to format it. have it reformat to your nearest service center instead of buying gadgets to format your phone. this save you $$$.
Hope this helps you.
Don't forget to rate me. Thanks...
Regards,
john
Jan 11, 2011 | Samsung J700 Cellular Phone
Blank lcd
hi,
I recommend not to open your phone since it is very tricky to open it and there's a great chance of damaging the LCD and also if your unit is still in warranty and if the warranty sticker is broken, your warranty is void. instead have it repaired to your phone dealer or provider and that saves you from trouble.
but if you really to gamble and give it a try (Don't do this if your not sure what your doing!), you can fix it yourself if the problem is on no. 1 (loose connector). open your phone slowly (since delicate parts inside and remember its part placements) using t6 or t7 screws and locate the lcd flex connector (usually behind the LCD) that connects the lcd to the main board. remove it slowly not to damage it and look for abnormalities, if none, then put it back securely and assemble your unit. then give it a try...
Good Luck!
bst rgrds,
John
Jan 08, 2011 | Nokia 1209 Cell Phone
Pleas how to repair my nokia 3110c light problem
hi,
there are several reasons why there is no light in your lcd screen.
1) you accidentally turn off its lcd backights if your unit has that features. check on it on display settings of your phone.
2) probably your phone experience accidental impact and that causes lcd flex connector to get loose and causes no light for the display.
3) busted lcd backlight or open line connection to backlights.
I recommend not to open your phone since it is very tricky to open it and there's a great chance of damaging the LCD and also your unit is still in warranty and if the warranty sticker is broken, your warranty is void. instead have it repaired to your phone dealer or provider and that saves you from trouble.
but if you really to gamble and give it a try (Don't do this if your not sure what your doing!), you can fix it yourself if the problem is on no. 2 (loose connector). open your phone slowly (since delicate parts inside and remember its part placements) using t6 or t7 screws and locate the lcd flex connector (usually behind the LCD) that connects the lcd to the main board. remove it slowly not to damage it and look for abnormalities, if none, then put it back securely and assemble your unit. then give it a try...
Good Luck!
bst rgrds,
John
Jan 06, 2011 | Cell Phones
The main display disappears after opening the phone. It appears every time the phone is opend and then disappears. I can't access numbers and cannot see who is calling. The battery has been charged and the...
hi,
Good Luck!
bst rgrds,
John
Jan 06, 2011 | Nokia Cell Phones
Nokia 2626 getting blue display
hi,
there are several reasons why your getting a blue display.
2) open connection to lcd.
3) busted lcd.
If your phone has still a warranty don't try to open your phone and there's a great chance of damaging the LCD and also your unit is still in warranty and if the warranty sticker is broken, your warranty is void. instead have it repaired to your phone dealer or provider and that saves you from trouble.
but if you really to gamble and give it a try (Don't do this if your not sure what your doing!), you can fix it yourself if the problem is on no. 1 (loose lcd connector). open your phone slowly (since delicate parts inside and remember its part placements) using t6 or t7 screws and locate the lcd flex connector (usually behind the LCD) that connects the lcd to the main board. remove it slowly not to damage it and look for abnormalities, if none, then put it back securely and assemble your unit. then give it a try...
Good Luck!
best regards,
John
Jan 05, 2011 | Nokia 2626 Mobile Phone
No display
What you have here is a LCD problem. LCD means Liquid, Crystal, and Display.
If it's a flip up phone, check if it is detachable and replace the flex, but if it is not detachable, you have to change the flex and LCD. If it is a LCD without flex, you have to use another LCD, it will then display.
But if after following all this instructions and the screen does not come up, then take the phone to a technician for proper repair.
Jan 12, 2010 | Nokia 5310 Cellular Phone
DCR-HC32 LCD
I also got the problem of LCD screen not displaying anything (HCR 21E). Since I am an electronics engineer, I opened it on this weeked. And saw that flex wire for LCD has two parts (a) part for touch screen (b) part for lcd display. And in my case part (b) is broken. I checked that part on Sony website and it costs 22 USD.
I am not sure, how much will they charge for repairing.
Manoj
Jan 27, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Nokia N86 Smartphone Logo
444 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
