Question about Toastess Cordless Electric Glass Kettle Globe Electric Kettle
Broken glass kettle
Where can I find a glass kettle replacement for toastess electric kettle.
    New Friend:
  • 81 Answers
Hello. Broken glass kettle is a real serious issues and those are not easily replaced as well, but I know a place where one can find all their relevant answers and for this, they just have to click at the below link: Top 5 Best Electric Kettle
Posted on Jul 23, 2015
Buy a new one
Posted on Jul 18, 2010
Russell hobbs problems
Hi Naomi,
please check the manual.and see if it is has a small hole or opening in kettle to go to outside of steam.
your one must be blocked .
regards.
nuwan
Jan 13, 2014 | Toastess Cordless Electric Glass Kettle...
Tip
Leakage problem at the bottom? Toastess International Kettle Model: TJK-103...
Leakage problem at the bottom…
Model: TJK-103 120V, 60 Hz, 1500 W
She was complaining that our kettle was leaking a bit at the bottom.
Warranty is over.
Here is what I did to fix the problem.
Unplug the kettle and empty it completely.
Remove excess residual water inside.
Remove the bottom cover by removing the screws holding it.
Gently remove the plastic ring screwed in place.
Now you will be able to put your hand inside the kettle and push the bottom out, toward the outside of the unit.
Take out the rubber seal and clean it. Ours was full of fine residue…
Gently dry it out and lube it with tiny bit of silicon.
Clean the inside part of the kettle before putting everything back together.
Make sure that you don’t squeeze any wires inside.
With a lot of patience, put everything back in place.
Make sure that the seal is perfectly installed. You can see it looking trough the plastic.
Kettle is now fixed and she is happy! ;-)
on Jan 23, 2008 | Toastess The Storm Electric Kettle
Tip
Kettle stoped working...
After the warranty was over, our beautiful electric kettle just stopped working.
Check the wires inside, the ones connected to the heat element.
On our kettle, one of them was completely burned off and disconnected.
So I replaced it with a heavy duty equivalent copper wire and sauder it in place.
Make sure that you do a good job installing and replacing the new copper wire.
Kettle is now fixed and working perfectly.
Need a filter for DLJK459
Filter part DLJK459-05 $4.50 each plus $8.95 shipping/handling
to place an order, please call 1 800 321 6993
Dec 22, 2013 | Toastess Dljk459 Delfino Stainless Steel...
Oster water kettle leaking from bottom of unit when pouring?
If you're not just simply missing the opening a little as you're pouring then I'd assume it's cheaper to replace than to repair, sorry.
If it's leaking from the side-glass you might get by with filling your kettle just under the lower end of the side-glass.
May 29, 2012 | Oster 5965 Electric Kettle
Need a manual for TJK-319 manual
It's an old product, but most of the manuals of Toastess Kettle are very much alike:http://toastess.com/products/manuals
or email info@toastess.com to get one by mail
Dec 08, 2011 | Toastess TJK-319 Cordless Electric Kettle
Paper Shredder problem Royal JMD500 paper shredder makes a banging noise and paper only shreds about 1 inch in and then stops. You must put machine in reverse to take paper out.
Sounds like shreddder gears are not staying aligned or somethhing is caught in the cutters.
The shredder has a sensor to detect when somethine is insert. Hol the sensor swith down and check for paper clips or staples in the roller/shredding teath. Good Luck and use a match book on the switch to wedge it..
Sep 16, 2009 | Toastess International PV434995 Electric...
Toastess Cordless Electric Glass Kettle Globe Electric Kettle Logo
294 people viewed this question
Top Toastess Kitchen Appliances - Others Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Toastess Kitchen Appliances - Other Expert? Answer questions, earn points and help others
