Question about Air Tools & Compressors
Compressor blows breaker switch - Air Tools & Compressors
  • jaap schildmeijer May 11, 2010
    what kind of compressor, piston or screw or other.
    is it de-pressurised at moment of starting
    is it running smooth by hand
    cables and connections ok
  • Al Kupchella
    Al Kupchella May 11, 2010
    Can you provide a little more information? Does it only trip on startup? Every time? How long is the wiring from the breaker to the compressor? What gage is it? What compressor model?
    Scholar:
  • 169 Answers
What size compressor? what size circuit breaker? what voltage? starting with air in the tank or without? it all makes a difference!
Posted on Feb 09, 2010
I have a tcl split system air con when you turn it on it runs for a while then when the compressor and fan come on it blows the circuit breaker at the meter box.
in most cases like this (circuit breaker tripping at compressor switch On ) compressor is burnt out ! A Meg ohms test Leakage to earth would confirm this
Nov 02, 2017 | Heating & Cooling
I have a model #919.167200 5hp, 20gal. air compressor. It has been working great for years, but when I went to turn it on today it blew the breaker. I pulled cover and cleaned contacts on pressure switch,...
Hi dtsorrell...
If your somewhat of a mechanic/electrician then you can by-pass the pressure switch by hooking the color coded motor wires together with the incoming color coded wires from your power cord in the proper order.
Plug it in and then check to see if it blows the breaker again, if it does then it is your motor that is faulty.
Please take time to rate me.
Jul 28, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I have a GE 7000 Portable Air Conditioner that blows the breaker when I turn it on. The machine will run when the water bucket is removed but as soon as I put the bucket in place, it blows the breaker. ...
there is a switch that that locks out the compressor when bucket removed When you put the bucket in the compressor is probably trying to start and if its blowing the breaker its time for new unit
Jun 21, 2011 | GE PAC12 Air Conditioner
I have an Armstrong air conditioner scu10e60a-2 on the compressor is the any kind of fuse that is in the plug that has run/common/switch cause as soon as you plug in breaker on wall blows
If the breaker does not trip with the plug not connected to the compressor, then you either have a bad run capacitor or the compressor is internaly grounded and is bad.
Jun 19, 2011 | Heating & Cooling
Compressor runs and compress air,but when air setting is depleted compressor will not start to compress more air.If you waite it will start some times do think this might the compressor switch
If it doesn't try to start, then it could be the pressure switch. Another suspect could be the thermal overload on the motor. The motor (or just the overload) might be overheating and shutting the unit off, then allowing it to restart when it cools.
Is there any humming, or does it blow the breaker? When ot shuts off, do you hear a brief hiss of air?
If there is humming or breaker blowing on restart, or no hiss of air at shutoff, the pressure switch unloader valve is probably bad. If the air blows off, and there is no humming, and the compressor doesn't reliably start, it is probably the pressure switch. If pressure drops too low, give the pressure switch a tap with a screwdriver. If it starts then, the pressure switch is your problem.
Jun 02, 2011 | Air Tools & Compressors
Keeps blowing the breaker... only 6 months old
This compressor is small however like other brands in this size range draw 13 - 15 amps. Thats quite a bit of power. The compressor has a thermal breaker that will begin to trip if compressor is hot. I am assuming that the breaker that is tripping is the one on the compessor. I have seen many hitachi breakers fail. Easy to replace with generic 20 amp, cost about $10. Before you replace anything, check amp draw with meter, if within specs try to determine what is causing heat.
example:
cycling too many times per hour (check manual for recommended)
low power due to weak circuit or extension cord
using generator for powering compressor (not recommended)
using low quality oil (use synthetic if hot climate)
air leaking from intank checkvalve back to pump
If no reason to overheat then replace breaker on compressor to 20 amp but watch for overheating. Good luck
Jul 09, 2010 | Hitachi EC89 4 Gallon Twin Stack Air...
Sluggish on start and blows the breaker on compressor 17amp
replace the start capacitor on the motor body,it is located under a metal cover by loosening 2 screws,it is getting weak,also if you leave this breaker jumped,you will soon over heat the motor windings and ruin the motor
Apr 09, 2010 | Hitachi EC119SA Twin-Stack Air Compressor...
Aquired 3 door victory in existing bldg. Service
First check for bunrt wires that can be grounded, then you can disconnect the compressor and plug the freezer and if doesn't blow the breaker , the compressor is bad ,if still blows them ,put the compressor back and try the fan , then try the other fan(inside one) or also could be the light switch, or the defrost heaters.
Oct 06, 2009 | Victory Freezer Refrigeration ''Value''...
Breaker blows out when starting up compressor
there are a number of possible causes. you really need an amprobe to read the draw as the compressor starts up. Then check the label on the motor. There is also an unloader in the air loop that allows the unit to start up with no air pressure against it. to help you you really need to give alittle more info.
Aug 09, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Dewalt compressor electric not starting after blowing circuit breaker
look for a reset button on the compressor sometimes but not always is red in color but could be black also
Mar 22, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Air Tools & Compressors Logo
57 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
