Question about Whirlpool Dryers
Need diagram to hook up a new dryer belt 5 cycle 2 temperature not sure of model # Whirpool
  • Whirlpool Master
  • 2,696 Answers
Put the belt around the drum with the ribs on the drum,put the drum in and make sure the felt on the back is tucked in so you don't see the edge of the felt,now pull the belt under the pulley with both sides of belt touching and then put the belt onto the motor shaft pulley,gab your pants belt near the end between your fingers,you'll see the belt touching and a loop on the end,your fingers are like the pulley and the loop is the part you stick on the motor shaft,that's how it looks when it's connected.it's hard to tell you because i don't think about it when i do it,i just put the belt on ha,hope this helps
Posted on Feb 08, 2010
Testimonial: "good advice makes it simpler"
How to change belt in whirpool washing machine model awg5052/m?
Go to www.repairclinic.com and enter the model number of your machine. You may be able to view a video that shows the whole process.
Jan 04, 2015 | Whirlpool WED4890XQ 29" Front-Load...
Roper dryer res7648kq0, replaced heat element, thermal fuse, cycling thrm, thermal kit, checked outlet, circuit breaker, still not heat, will not advance on AUTO, but will on timed cycle. Now what?
Wow.
In electric dryers with an AUTO cycle; the heater runs on 220 volts, but the timer motor runs on 110 volts. There is a resistor in the system to cut down the voltage. If the resistor is bad, you will see the same symptoms as if a thermostat was bad. The timer motor will not run in the automatic cycle. You need to make sure that you test for continuity in the resistor.
I've looked at two parts diagrams for your washer and cannot find a sensor anywhere in either, so the thermostat is what tells the timer to advance once the dryer reaches a preset temperature.
The thermostat will only tell the timer to advance if the dryer reaches the proper temperature, if you have some clogging in the vents, the dryer may never reach the proper temperature, and thus not advance on the auto cycle. but i'm sure you've probably checked that. I'm baffled. Let me know how it pans out if you can. Thanks. I'm still trying to find a wiring diagram for that model.
thanks,
Mike
Jul 24, 2011 | Roper RES7646KQ Electric Dryer
I have a whirpool front load dryer and I cart seem to get the belt through the pulleys any tips?
As the belt comes off the drum and you are going to hook it to the motor...be sure to fold the belt to make a loop and then pass it thru the idler pulley and then to the motor
Please rate me
Dec 05, 2010 | Hotpoint TDL15 Electric Dryer
1991 Maytag dryer Model #LD 68424AAL Serial # A0190126HY
Are you sure that you hooked the belt up correctly, as it sounds like you may have missed the tensioner pulley. As this will tighten the belt around the middle of the drum
Jul 20, 2010 | Maytag Dryers
I cant find my dryer model number online.
Go to appliancepartspros.com and type in your model number. Use the suggested model number they provide, which is the XMW0 suffix you have listed. The part numbers will be the same for these models. If you look under the "Cabinet" diagram at item number 56, it states in the part description that this belt replaces the 5 rib (wider) belt that you have and fits all Whirlpool models. The part number is AP2946843.
For a diagram on how to replace the belt, go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, is a link for "Dryer Belt Diagrams" under the "Special Features" section. Scroll down to Whirlpool and use diagram H. I hope this helps you. Let me know if you require additional assistance.
Jan 03, 2009 | Dryers
My dryer belt broke
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. There are numerous dryer belt diagram illustrations listed that you can print out. Admiral is listed. I hope this helps you.
Nov 12, 2008 | Roper REX3614KW Electric Dryer
Whirlpool Dryer Model LER88620PW0
Go to repairclinic.com and click on the "Repair Help" link in the left column of the page. On the next page under the "Special Features" section there's a link entitled "Dryer Belt Diagrams". There are two diagrams listed under Whirpool (H and K). Since you stated that the tension pulley came loose in your dryer, I suspect you need to look at diagram "H". Diagram "K" has a tension spring and is fixed in place. I hope this helps you. Let me know if you have questions.
Sep 20, 2008 | Dryers
Dryers Logo
214 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
