Question about Lexmark X500n Color Laser All-in-One Printer
Lexmark x500n paper jam
Repeat paper jams on my lexmark x500n. Error message always says to clear jam by opening back panel. I do this for every 2nd or third sheet of paper. No paper is ever jammed in there.
HELP. :)
    Champion:
  • Lexmark Expert
  • 217 Answers
Try cleaning the roller that picks up the paper. You can use a drop of alcohol to clean the roller.
Posted on Feb 09, 2010
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
I cleared an paper jam in the rear and when i restarted, it has an error message, missing transfer belt. nothing has changed
if you are sure nothing has been changed then there might be a small peice of paper blocking the transfer belt sensor
try manually rotating the rollers where possible near the problem area and also try to blow some air with pressure to remove any torn bits of paper
hope could be of help
Mar 28, 2011 | Lexmark X500n Color Laser All-in-One...
201.02 paper jam
Please open up the printer take the toner out, please there is a paper jammed in this location, Bring paper out put toner back and power on the printer
Apr 17, 2010 | Lexmark X342n All-In-One Laser Printer
Where is the paper jam when the panel of our Lexmark C750 says "200 paper jam"
Primary: Paper is jammed at the printer input sensor. Open the printer left door to access the paper jam. If sheets have been accumulated to be stapled or offset when the jam occurred, the printer alternately flashes the primary and secondary messages to indicate that all accumulated sheets not be removed during the jam clearing procedure.
Secondary: When this message is displayed, do not remove accumulated sheets during the jam clearing procedure as the printer will not reprint the removed sheets. Also, if the accumulated sheets are removed, the portion of the job printed after the jam will not be stapled.
Nov 03, 2009 | Lexmark C750 Laser Printer
Paper jam - can't clear error message
Hello Nj,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Paper jams are was very common on HP printer model.
Here are few instructions on how to clear the paper jam on your printer.
How to Clear a Paper Jam on an HP Inkjet Printer 1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
2. Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
3. Look for paper through the opened back panel. Remove any paper you find jammed.
4. Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
5. Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
6. Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
7. Close the front access panel. Make sure that it latches back into place.
8. Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this helps.
Aug 08, 2009 | HP Office Equipment & Supplies
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
I cleared paper jam, printer won't respond, still have error messages
turn it completely off..let it sit for the length of a cup of coffee..try it again..
Oct 13, 2008 | Lexmark E450dn Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Lexmark X500n Color Laser All-in-One Printer Logo
274 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
