Question about Whirlpool Duet GHW9150P Front Load Washer
When I push the start button on my dryer it says it is on, but it is not spinning
    Genius:
  • 1,036 Answers
If the dryer seems to be getting hot and otherwise working (just not spinning), try this test -
Turn off.
With the door open, try rotating the drum by hand.
If it spins easily, and you cannot hear any connection to the drive motor, then it is very likely just the drive belt that needs replacing.
Order a spare for your specific model, and a reasonably competent DIY'er should be able to fit it.
If you are unlucky, and the motor is spinning - just not working, then replace the brushes on the motor as a first atempt at a fix. These are available online, but you will need to quote model numbers.
Again, a competent DIY fix.
If the motor is OK (after testing), then the control board may have a defective (burnt) component that needs replacement - usually by swapping the board with a good one. This repair is for experienced technicians or skilled trades.
Thank you for using Fixya.
Posted on Feb 07, 2010
I push start button and it humm's and dosen't spin i open the top of the dryer and then push the start button and the push the drum to jump spin it and then it work's.any thought's
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Dryers
When pushing the start button dryer hums but does not spin. when u release start button dryer shuts off
Sounds like a bad motor. Check to make sure the drum isn't stuck, if you can spin the drum put some tape on the door switch and press the start button while you spin the drum. If the drum continues to rotate, you have a bad motor.
Mar 10, 2011 | Maytag Washing Machines
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
When pushing dryer start button, a slight buzz is
the noise is coming from the motor,if you can spin the drum by hand and it moves freely you have a bad motor and need to change it out,next time send model number and the brand name of dryer,if it doesn't spin,the belt could be jammed up or something stuck in the blower wheel,let me know how you make out
May 13, 2010 | Dryers
Dryer doesn't run
the motor is going bad..push in the door switch on the dryer,an it start an spin the drum ,it it works,replace dryer motor,or purchase a new open....turn start button,pusn in door switch,spin drum by hand...all at same time....hope this helps...dryer may run a couple of times...good luck...michael..doctor airr appl.repair...843-384-8474....
Mar 26, 2010 | Dryers
I press the start button, but the dryer will not start.
ok open the dryer door look for a button inside where door shuts against hold that button down with other hand spin the dryer have some one push start button let it run for a sec then shut door and it should start
Dec 23, 2009 | Whirlpool LER4634J Electric Dryer
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 | Dryers
Hi my dryer buttons seem all good but as soon as i start the spin it spins for a second then stops then it beeps repeatedly
Whats brand dryer is it? Older style or newer style. Is it the regular machanical timer style dryer or the new computer led light style dryer? If it the regular machanical timer style type, then you saying when you push the start button it starts but once you let go of the "push to start" button it stops. Is this right? In that case is could be a bad motor. The centrifigal switch in the motor is probably bad and isnt holding to the "run winding" in the motor internally.
Jul 30, 2009 | Dryers
Dryer drum wont start spinning after pushing the start button
the problem is with the start winding on your dryer motor.it is centrifical switch,so if a lint build up gets in that motor switch area it stays on the run winding.pop the top .remove the frount.pull drum.vacume motor out if then starts on own great.other wise you need new motor.parts about 100$God bless,tom
Jan 02, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
