Question about Nuova Simonelli Premier Maxi Espresso Machine
I have a Nuova Simonelli Premier Maxi . The is a water level indicator on the front. the water level in the funnel is always in the mid but from last 2 days its above max. How to fix this issue... is it dangerous..like some one told me that this is showing water level in tank and above max means it can explode
  • Nuova Simonelli Master
  • 1,711 Answers
There is a level probe which is insert inside the boiler you should find it either on top or on the side of the boiler and with a wire conected directly on it. It also secure with 12 or 13 mm nut. You can anscrew the nut remove the probe whech is only a metal rod and this should be cover with scale or other water dirt. Put back together and the levelof the water will stop at the write point 2/3 of the boiler. Be careful to put it at the same psosition so you will not change the corrct level of the water. If it is very dirty then this mean that the whole boiler and machine need also descaling and cleaning.
Posted on Feb 13, 2010
Pitcher light keeps flashing
The water level is low
Term the machine of and start it
Apr 11, 2014 | Nuova Simonelli Premier Maxi Espresso...
Simonelli premier maxi gauge
I have exactly the same problem please help us
Feb 01, 2013 | Nuova Simonelli Premier Maxi Espresso...
I have a premier maxi which recently stopped heating the water. When the coffee is brewed, it comes out cold. not hot water and no steam. What can the problem be??
First thing I would check is the reset thermostat on the right side of the machine above the element. Turn machine switch off then push in on pin you will hear a click.
Aug 06, 2011 | Nuova Simonelli Premier Maxi Espresso...
Nuova Simonelli Premier Maxi V , 2005...when water turned on machine constantly leaking from the pressure relief valve and the hot water valve.
Has the machine been in cold storage? If no then the inlet solenoid could be the culprit. There might be sediment keeping the valve open.
May 11, 2011 | Nuova Simonelli Premier Maxi Espresso...
Hi I have just bought a Nuova simonelli premier maxi and the warning light keeps flashing above the coffee pot sign. Any ideas welcome
Hi, is the water tank filled with water? Did you perge the system,remove air locks? Is coffee beans filled?
Sometimes when these machines are new or used and sit for a while, you have to purge the system.Try turning on power and when ready light comes on, use the frother knob to let out a steady flow of steam.
If this machine was always in use, then you may have to ``descale`` the system by running a solution of descaling liquid thru a few cycles.
Try this ,hope it helped you..
From-an Espresso fanatic...
Feb 25, 2011 | Nuova Simonelli Premier Maxi Espresso...
I would like to be able to adjust the flow of the water my nuova simonelli maxi machine. The water flows out of the machine in about 10 seconds and stops which is way to fast. Seems as though the...
Take the cup warmer off the top and find where the water line comes into the machine, follow this line to a tap that has a screw in knob. If you turn the know clockwise it will slow the flow of water to the hot water spigot.
Sep 06, 2010 | Nuova Simonelli Premier Maxi Espresso...
I have a 3 group 2002 premier maxi. the laft and
The metering jet filter on top of the heads are blocked or the solenoid coil is damaged.
Jun 18, 2010 | Nuova Simonelli Premier Maxi Espresso...
Nuova simonelli mac cup red light
It sounds like the thermostat on the boiler nest to the element tripped. Fill machine with water until you can see the level about half way, then open the right side of the espresso machine, you might be able to get to thermostat from the top of machine (make sure it is unplugged) then press the red pin on the boiler between the 2 wires, that should reset the thermostat, if it does not then it will need to be replaced. As for the water on the top of the group head, is there any way you can post a pic of the top, because simonelli made a few different head and I want to give you the correct advise.
Nov 13, 2008 | Nuova Simonelli Premier Maxi Espresso...
Open Questions:
See all Nuova Simonelli Premier Maxi Espresso Machine Questions
Nuova Simonelli Premier Maxi Espresso Machine Logo
280 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
