Question about HP Photosmart C6280 Printer
Code 0xc05d1281 inkt problem - HP Photosmart C6280 Printer
  • 4,041 Answers
Hi there ok
The "Ink System Failure" error is causes by air in the ink feed tubes.
I hope this helps, If so please rate our solution.
Please perform the following steps in order:
1. Press and hold the “*” key.
2. Press the “#” key and release both keys.
3. Display should say “Enter Special Key Combo”
4. Press and release in sequence the “1”, “2” and “3” buttons.
5. Screen should say "support" R0631M"
6. Press and release the right arrow button until the display says “System Configuration Menu”.
7. Press and release the “OK” button.
8. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
9. Press and release the “OK” button.
10. Display should say “Hardware failure status: Clear. Press OK to clear”.
11. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
12. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
13. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
14. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
15. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
16. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Posted on Feb 07, 2010
HP c8180 error code oxc05d1281
http://h30434.www3.hp.com/t5/Other-Printing-Questions/0xc05d1281-Error-code-for-Photosmart-C8180/td-p/1212853
Apr 10, 2015 | HP Office Equipment & Supplies
Kan de handel rechts niet optillen? Zijn er meer mogelijkheden?
In de hoop dat dit helpt . U moet de printer op om verandering inkt / head . Je kan hebben om te gaan door de printerinstellingen en vertel het om inkt te veranderen .
Jan 15, 2015 | Canon Office Equipment & Supplies
HPPhotosmart 3210 AIO hangs us with error code of 0xc05d1281
Hi Minnie,
This could be because of residue on the Printhead electrical contacts
Try the steps below and it should help.
Turn off the Printer.
1. Open the Carriage access door.
2. Remove the Cartridges
4. Move the carriage from left to right 6 times and it should move freely
5. Clean the contacts on the Cartridge with lint free cloth. ( Golden dots )
6. Turn on the printer and it should say " Cartridge missing or need to be reinstalled "
7. Install the Cartridges and close the Carriage door
8. the printer should go through alignment process
If this step does not fix, You may try calling HP customer support to check for better options/solutions
HP Customer Care : 1-800-474-6836
Regards,
Sean
Feb 16, 2013 | HP Photosmart 3210 All-In-One InkJet...
Error code 0xc05d1281
Try the steps in the following website:HP Website
It may help.
0xc05d1281
A full guide for clearing all 0X error codes can be found here. I would normally paste the solution but there is so much information you may be best checking out the whole thing (with images).
Hope this helps.
Nov 01, 2012 | HP PhotoSmart Office Equipment & Supplies
Een dikke zwarte streep op de achterkant van het papier, bij eerste afdruk na opstarten van printer
Mijn 4 jaar oude Canon MP500 begon ook een brede zwarte streep te trekken aan de onderkant van het papier. Dat gebeurde na iedere reiniging van de koppen, de eerste paar velletjes kregen een zwarte streep en daarna was het meestal goed totdat de printer zijn koppen weer reinigde.
Bij het reinigen van de koppen wordt met een soort pompje wat inkt door de kop gezogen. Deze inkt wordt via een slangetje afgevoerd naar de ruimte tussen de bovenste plaat en de bodemplaat van de printer. Een groot deel van de bodem van de printer is gevuld met een soort vilt dat de inkt kan opnemen. Zolang het vilt inkt opneemt is er niets aan de hand, maar bij mij was het vilt rondom de uitstroomopening van het slangetje helemaal verzadigd met ingedroogde inkt. Daardoor kon nieuw aangevoerde inkt alleen maar omhoog tot aan een aandrukrol voor het papier. Dit aandrukrolletje bracht de inkt keurig over op de onderkant van het papier.
De oplossing is de printer uitelkaar halen en de overtollige inkt in het binnenste verwijderen. Dat is een vies werkje waar je echt even voor moet gaan zitten, en als je niet handig bent kun je er beter niet aan beginnen.
Trek alle kabels (vooral de 230V) uit de printer en zet hem op een goed toegankelijke plek waar je een dikke laag kranten op hebt uitgespreid. Eerst verwijder je de zijkanten door 2x2 schroeven los te draaien. Het lipje aan de voorkant moet je vervolgens (een beetje) naar voren trekken zodat het los komt. Aan de achterkant is een schroevendraaier in de naad handig, de zijkant komt dan los en kan naar beneden toe worden verwijderd.
De veer van de scanunit krijg je los door aan de voorkant twee lipjes opzij te buigen. De scanunit is nu vrij, maar is nog verbonden met de printer met 3 massadraden, een connector met 4 draden en twee flatcables. Die moet je met moed en beleid loshalen, en noteer even wat waar zit. De draden loshalen is geen probleem, met de flatcables moet je heel voorzichtig zijn, zo dicht mogelijk bij het connectortje vastpakken (daar is de flatcable iets dikker) en voorzichtig er uit trekken.
Nu kun je de kap loshalen (4 schroeven).
Dan kan het printermechaniek worden verwijderd van de bodemplaat door 4 schroefjes te verwijderen. Om bij de vierde te komen moet je de voeding loshalen: een connectortje bovenop losmaken en aan de onderkant twee lipjes opzij buigen. De voeding komt dan naar onderen uit de printer.
Maak alles enigszins schoon, verwijder in ieder geval alle dikke lagen inkt. Dan weer alles in elkaar zetten. Als je geen magnetische schroevendraaier hebt, kun je ook tijdelijk een dun draadje om de schroefjes wikkelen om ze op de goede plek te krijgen. Denk er aan om de schroefjes die in kunststof worden gedraaid, eerst even de verkeerde kant op te draaien. Je voelt dan een klein klikje waardoor je er zeker van bent dat de schroef precies in de oude draad komt. Doe je dat niet, dan heb je een grote kans dat je het schroefje dol draait. De flatcables hebben maar aan een zijde contactjes, dus steek ze juist om in het connectortje.
Als alles weer in elkaar zit doe je een schietgebedje , sluit de printer aan en testen maar...
Feb 07, 2011 | Canon Pixma MP500 All-In-One InkJet...
Display says error 0xc05d1281
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
Buddy
Corporate Computer
www.ccl-la.com
Jan 03, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure with error code: 0xc05d1281
I had the same problem and took Guru NinaE advice....1. Unplug power cord from back of printer while it is on. 2. Wait for 60 seconds after it is in sleep mode. 3. Press and hold "Print Photos" and "Red Eye Removal" at the same time and while holding the two buttons down, plug in the power cord into the back of the printer. 4. The printer display should go blank or Reset might show up on the display. When this happens, touch the ON button and the printer will reset itself.
May 20, 2009 | HP Photosmart C8180 InkJet Printer
Cannot remove ink cartridge
usually there are are buttons on the printer on has a drop of inkt benath it one is for the paper and one is on and off
open the plastic cover of the printer
turn printer on and press the ink button for 2 -7 seconds (depending of the model) than release it , wait for the cartridge holder to "park" open the holder and remove the cartridge wich was empty by a new one and put the cartridge in the correct place, than close the cartridge holder, than close the cover, press the inkt button once and wait until it is ready
Nov 26, 2007 | Epson Stylus C42UX InkJet Printer
HP Photosmart C6280 Printer Logo
289 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
