Question about Acer TravelMate 529ATX Notebook
My monitor will remain black when notebook is powered up
I turn my computer on and the notebook's monitor remains black.  The power button is lit, but the screen remains black.  I have only owned the notebook for around 40 days
Tried on power only and battery only. No better with either.
  • romana May 25, 2008
    Greetings;
    I have turned laptop on and can hear it start up but cannot see a picture and monitor remains blck when it is powered up.
  • 981 Answers
Black uses much less power. It's a device for automation, so you really should not lavish the watts and attention on it unless it has to perform something truly novel.
If you really want to use the monitor though, you can use the function-key combination used to switch the display between internal and external displays.
Posted on Feb 22, 2008
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
My Samsung SyncMaster 740N occasionally turns itself off. Timing varies and the condition varies. Usually the screen just goes black - from seconds to hours after it is turned on - the blue LED remains...
This could be because of the 'eco' friendliness of the monitor. Basically a lot of monitors are designed to turn off into a low power state when not in use so to preserve power and life of the monitor. I would return the monitor as the sensors that control this seem to be broken in your monitor.
Mar 15, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
The laptop needed charging. After charging, when the power button was pushed, the screen remained black. The power button is lit. What is the problem?
Sometimes when you reset the computer, that happens. disconnect the AC and count to 10. Plug back in. If that doesn't work...turn on from the power and that should automatically reset the screen.
Nov 27, 2010 | Toshiba Satellite A135-S4527 Notebook
Describe your samsung syncmaster 204bw Problem: I turn the monitor on, the power button turns blue, the screen remains dark, the image on my Powerbook G4 appears flashes on the screen before it goes black...
Check the power supply DC filter cpas first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 08, 2010 | Samsung SyncMaster 204BW LCD Monitor
The screen remains black when i turn it on. The power button turns green and blinking but the screen remains black.
try using the Fn + F?key (has a graphic of a monitor)F5 or F7 to switch the system from external monitor to the laptop ... you probably have it in presentation mode for external monitor.
Oct 14, 2009 | Acer Computers & Internet
SGI F180 Flat Panel Display no longer turns on.
If the power button does not stay on, the monitor might be burned out.
Aug 20, 2009 | SGI Silicon Graphics Silicon Graphics F180...
Blank Monitor on my DELL
Your display is having problems with the Inverter that generates high voltage to lit the lamp.
This issue is explained (including how to fix it) here:
http://josepino.com/?howto-repair-dell
Good luck
May 07, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
test it with another monitor if you things then maybe the LCD has a fault.  Come back here for more instructions
Oct 15, 2007 | Acer Aspire 5100 Notebook
My monitor will not turn on
Test it with another monitor to see if all is well and if you see things then there is a problem with the LCD.  Come back here for more instructions.
Acer TravelMate 529ATX Notebook Logo
177 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
