Question about Maytag Neptune MCE8000AY Electric Dryer
Change heating element in neptune dc cannot get the cover off to get to the heating element
3 Suggested Answers
  • 949 Answers
SOURCE: Maytag Neptune Not heating
I did find a service manual for this unit. If you want to get me an email address to send it to it is in pdf format.
Posted on Apr 24, 2010
heatman101
  • 43501 Answers
SOURCE: Gas dryer neptun DC does not heat and dry cloths
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 04, 2010
My Maytag Neptune dryer stopped drying. There is no heat coming out. We replaced the heating element and still nothing. What else could it be?
Hello there and welcome to fixya
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out,
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Sep 28, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
THE DRYER IS NOT PUTTING ANY HEAT OUT.
Jan 22, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune Dryer Not Heating
Bingo. I have the same problem. It is called the Thermistor and it "blows" if subjected to over temperature or high voltage. Found it as part # DC32-00007a for $8.95 s/h on Samsungparts.com.
Jun 14, 2010 | Maytag Dryers
Maytag neptune dryer not geting hot
If your Dryer is the Electric version, then more than likely you have a burned out heating element, you can check it by first UNPLUGGING THE DRYER!!! after you have UNPLUGGED THE DRYER!!!, you can remove the front cover and check the element for continuity, the whole unit comes out as a Tube.
May 31, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Apr 22, 2010 | Maytag Neptune MDE4000 Electric Dryer
Heating element turns bright orange, gas does not ignite
you need to replace the primary and secondary gas valve coils on the top of the gas valve located inside the machine which will require you to remove the top cover and front panel to access the coils
Jan 02, 2010 | Dryers
Blows only cold air
Check connection to heating elements. My have bad heating elements
Jan 19, 2009 | Maytag Neptune MDE6800 Electric Dryer
No heat
HI FRONT PANEL COMES OFF 2 SCREWS ON ALMOST BOTTOM CORNERS REMOVE FRONT PANEL ELEMENT ON RIGHTTHANKS THE APPLIANCE DOC
Sep 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Not drying no heat.
be element are thermo fuse on element no easy to change remove 2 screws on door hinge 2 screws on the ather side frount comes off there the element
Feb 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
113 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
