Question about Maytag MER5775Q Electric Kitchen Range
The temperture in my oven it's either to hot or to low but it read the temperure I want for exsample it I want 450 degress that what it will but the oven will read 265 or 300
    Genius:
  • 1,036 Answers
This is a problem with the temperature sensor - which is replaceable. If this fails to cure the fault, then it may be the control board that is not interpreting the sensor correctly.
I would change the sensor first - as it's the cheaper of the two.
If you do not feel competent in finding it, then get quotes for replacing these specific parts.
Posted on Feb 07, 2010
Oven temp can be reduced but not increased
Bake at 350 degrees? Oven temperature is uncontrollable ...
www.slate.com/.../bake_at_350_degrees_oven_temperature_is_unc...
SlateAug 8, 2012 - Your oven may say 350 degress, but can it be trusted? ... over their hot boxes, but the dials still typically only offered low, medium, and high settings. ... It's not particularly surprising that this development came when it did.
Why You Should Stop Worrying About Your Oven ...
www.thekitchn.com/why-you-should-st...
Apartment Therapy's The KitchnAug 14, 2012 - If you fret over the accuracy of your oven's internal temperaturereading, you're working too hard. ... If that all sounds like cause for worry, it's not, and here's why: the ... low (under 275 degrees); moderate (between 275 and 350); high ....It's certainly possible to cook without temperatures, but one will have ...
temperature - Glass Dish Baking Temparature - Seasoned ...
Dec 14, 2015 | Cars & Trucks
Turned oven to 350 degress but it wont go past 200 degress please help
Ben, the most common failure for this range is the oven temp sensor. Part # 316490001. Sensor is accessible from the back of the range. turn off power, remove the sensor and check the resistance of the sensor you have now in a glass of ice water (12 oz) mixed with one tablespoon full of salt, well dissolved. you should read approx 1000 ohms +/- 4.0 If you are outside of this value, replace the sensor.
Apr 18, 2014 | Frigidaire PLCF489AC Dual Fuel (Electric...
My Whirlpool AKZ451/IX/01 will not heat up correctly
I can fix this for you. Where are you residing please? Thanks David. "The Famous Forry'
Oct 20, 2017 | Philips Ovens
Hi..if i set the control knob to 350 for the oven..its goes to 400 or 450 degress..i put a oven termonater in there..its always hotter than what u set it on. model # JBP24G0K2AD or the o is a 0 not sure..
The oven thermostst needs replacing, as it is not sensing the correct temperature, this is the switch behind the control knob
Please rate my solution.
Thanks.
Nov 10, 2009 | GE Ovens
Hear noises in the cooling system, sounds like boiling over, but the temperure seems a little warm not hot. What is it? Doug
That is normal on those models as long as your gauge is reading fine dont worry about it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 27, 2009 | 2000 Chevrolet Blazer
Temperture in wall oven is much hotter then setting
have it calibrated, usually behind the knob when removed,
or more easily remember this and get a little oven thermometer , Theyre better anyways and the stat if not junk will maintain desired setpoint without much variance
Aug 25, 2009 | Whirlpool GS475LEKS Gas Kitchen Range
Oven not work
It can be fixed, that falt means your oven got to hot. Recomend replacing the temp sensor.
dmparenti
Jan 09, 2009 | Kitchen Ranges
TOW FANS AGAINST THE RADIATOR, TOYOTA CAMRY 2001 4 CYL
yes, they are both radiator fan. dependent on the temperture of the outside air and the cooling temperure on control panel. the fan will kick on when the temperture cross over the preset- set on the computer. so, either fan on, no fan, fan is runing when the car is runing or not, is not a porblem.
the porblem occures when the fan stops, and the temperture is over 100 degree outside.
Nov 11, 2008 | Compaq Presario 1626 Cooling Fan Case...
Gas oven dosen't maintain set temperture
My experience on the direct spark ranges is that the gas valve is usually at fault for this problem. The regulator valve and the burner shutoff solenoids are all built together in one valve assembely. The valve will work properly until it gets hot then it will stick and not open when the oven calls for heat again.
Please post back with the complete model and serial numbers if you need further help in troubleshooting it. There have been many updates and design changes on these ranges.
Thanks/Mike
Oct 28, 2007 | KitchenAid KGRS807SSS Gas Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
91 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
