Question about HP Pavilion a630n (PC109A#ABA) PC Desktop
Have a hpa630n,left computer on while running errands,came home and computer acted as if in hibernation,tried powering off with switch and powering back on and still no luck,ir mouse blinks briefly(can see reflection)then turns off,have 12v and 5v power in several places on the cables,any ideas
Unplug power from the back of the pc for a couple minutes and then plug back in..
Posted on Apr 30, 2010
  • 50 Answers
Do power flee
Posted on Feb 11, 2010
Act like out gas when you first start it
stalls (or misfires) tune up time, ever heard of a 60k mile service?
and get and injector balance test, sounds like they leak,
and the starts are doing so from the flooded state.
no crank.
repeat that again. the key switch has many posisitions
no (this era) car cranks, in the non run or start position so?
my guess, is the start position (spring loaded it is) is intermittant
and when starting you wiggle key , in the ST posistion and the starter
motor wakes up. this is a bad ignition switch, which love to go bad
with huge key rings, (heavy)
if car is A/T tranny, wiggle the shifter any time it dont crank
and, try starting in Neutral (fresh switch contacts there)
Stalls is a 2nd symptom and if the dash lights dont die.
then is not related to the ignition key switch.
that is the 12vdc power system is good and the EFI/engine has issues
try a tune up first. (its in the operators guide read that)
after tune up and drive 20-50 miles
now using any newer OBD2 scan tool scan the PCM.
got DTC'S? post them. DTC are ERRORS.
Jan 12, 2014 | Jeep Grand Cherokee Cars & Trucks
Tip
HIBERNATION
THE OPERATING SYSTEMS WHICH THE MICROSOFT HAVE PRESENTED TO US HAVE MANY ADVANTAGES AND NOW I AM SHARING ONE WITH YOU FRIENDS.
WHEN WE ARE DOING A TASK,IF WE WANT TO GO FOR ANOTHER WORK LEAVING THE COMPUTER ALONE,WE USUALLY SAVE THE WORK AND SHUTDOWN THE SYSTEM AND GO FOR THE NEW WORK.BY A SIMPLE TECHNIQUE THIS CAN BE AVOIDED AND WE CAN REENTER INTO THE WORK WHICH WE WHERE DOING BEFORE SHUTDOWN.THIS FEATURE IS CALLED HIBERNATION.THE STEPS TO DO THIS IS THE FOLLOWING.
1.Click Start
2.Select Settings-Control panel- Power options-Hibernate- Enable hibernation.
3.The system can be left to hibernate by selecting the turnoff option,then point the mouse to the stand by option and by pressing down the shift key,select it,then you can see the option as hibernate and select it.Then you can see instead of shutting down windows,it gives the message as hibernating.Then it is ready,then you can return to the work by again pressing the main power switch of the CPU.Try it and look how amazing it is.
WARNING:First go for a trial with open windows(2 or 3......) and then try in actual practice.Does not cause any failure to the system 100% safe operation.Thank you
on Dec 28, 2008 | Microsoft Windows XP Home Edition
Problem restarting toshiba satellite c660 from hibernation mode
Go into power options, select hibernate and uncheck the box to the left, this will disable the feature, microsoft worse piece of software. This will free up disk space and improve performance, best of all no sleeping computer to wake up.
Jul 08, 2012 | Toshiba Satellite P105-S6197 Laptop
My hibernation option is gone.....
Hibernation may be disabled by default in XP.
Go into Start > Settings > Control Panel > Power Options. Click on the Hibernate tab, then check the Enable Hibernation check box to enable it.
Otherwise:
You can start hibernation of your PC manually, if hibernation is enabled, by:
1. Selecting 'Turn Off The Computer'' from the Start menu.
2. Normally the left choice on the resulting pop-up window is ''Stand-By''. But, if you hold down the Shift key it becomes ''Hibernate''. So holding down the Shift-Key and clicking on the resulting ''Hibernate'' button (the left-most button) will cause your computer to start hibernation mode.
Note that many computers also have a button for starting hibernation mode also. Often pressing the Power button while the computer is on will cause it to go into Hibernation. (Sometimes desktop computers have this option disabled, but it can be enabled through some Setup menu item (unless a special key has been assigned to do it on the keyboard.)
Hope helpful.
Mar 18, 2010 | Compaq Computers & Internet
Computer goes in to sleep/ hibernate mode and I can not wake it up without shutting it off, and restarting
If we are talking "hibernate", then that's what the computer does - it saves the whole memory contents on the hard disk and shuts down. You then have to power it up and it boots like always on power up, but instead of loading the system the usual way, it reads the hibernation file and restores the state in which it was when hibernated.
"Sleep" or "standby" mode is different - the system stops execution of all the running programs, switches the processor into low-speed, low-power mode, executing only the basic functions of waiting for wake-up signal. Depending on machine and settings, it will be woken up by keyboard event, system event (like laptop battery running out - time to hibernate), network activity, or the power switch.
It should wake up when the Fn key on keyboard is pressed, the lid is lfted up (if it was closed of course), or when you momentarily press the power button. If it does not, then something is wrong with your ACPI/Power Management setup, and/or there are some drivers missing or corrupt. You can try going to IBM/Lenovo website and looking for updated system drivers for your model.
Dec 03, 2009 | IBM ThinkPad T43 Notebook
How I can enable Hibernate and Stand By button? I have windows XP SP3
You can enable hibernation in Windows XP by following the steps below.
1. Type powercfg.cpl in the Run window. To get the Run window press Win key + R. Or, you can go to the control panel and click on Power Options.
2. Find the Hibernate tab and click on it. Check the Enable Hibernation check box. In case its necessary, free up some space on you C: drive by running disk cleanup or your favorite system cleanup utility.
3. Now you can hibernate your system by clicking on the Start button and then on the Turn Off Computer (or Turn Off ). You'll see three standard options, Standby, Turn Off And Restart.
Hold Shift key and you'll see the Standby button turns into Hibernate button. Click to hibernate (Still holding the Shift key).
4. Optionally you can do this: Create a batch file for hibernating, and put it on you desktop. Every time you need to hibernate your system, just double click this file from your desktop. To do this, First Open up Notepad, type the following line in it.
%windir%\system32\rundll32.exe powrprof.dll,SetSuspendState Hibernate
Then save the file as, something.bat onto your desktop. Run this batch file to hib
Or you can
manually put your computer into hibernation:
1)Open Power Options in Control Panel.
2)Click the Hibernate tab, and then select the Enable hibernate support check box.
If the Hibernate tab is not available, your computer does not support this feature.
3)Click OK to close the Power Options dialog box.
4)Click Start, and then click Shut Down. In the What do you want the computer to do drop-down list, click Hibernate.
To automatically put your computer into hibernation:
2)Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply.
If the Hibernate tab is unavailable, your computer does not support this feature.
3)Click the APM tab, click Enable Advanced Power Management support, and then click Apply.
4)Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Thanks
Sep 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
When ever i turn my laptop on..it boots properly..then ill be typing and it will shut off..or go on standby not sure then i will push the power button...but it doesnt rootboot ...and starts back up where i...
Try this.
Right click on desktop.
Mouse down to properties, & left click.
Left click on screen saver.
Mouse down to Power In monitor power, & left click.
Check your power settings & hibernation settings.
Also some computers are setup to hibernate if mouse is placed in certain parts of the screen (top right or left, Bottom left or right.
Hope it helps.
Mar 11, 2009 | Dell Inspiron 1525 Notebook
Pavilion Dv1000 monitor won't show anything
Power management lets you reduce your Notebook power consumption. Your Notebook has two power management modes:
  • Hibernation is an energy-saving feature and safeguard that saves information to the hard drive, then turns off your Notebook. When you resume from Hibernation, your information returns to the screen where you were previously working. Your Notebook hibernates when the Power button is pressed, when the battery has little power left, or when your Notebook (operating on battery power) is in Sleep mode for more than one hour.
  • Sleep, also called Standby, is an energy-saving feature that reduces power to system components that are not being used. When Sleep is initiated, your information is saved in Random Access Memory (RAM), and the screen is cleared. Your Notebook is still on, but the display is blank. When you resume from Suspend, your information returns to the screen where you were previously working.
Automatically put your notebook into hibernation Windows can automatically put your computer into Hibernate mode after a specified period of inactivity. Or Windows can detect when your batteries are running low, and then automatically put your computer in Hibernate mode to save your work before the battery fails. NOTE: Using Power Options in Control Panel, you can adjust any power management option that your notebook's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To automatically put your computer into hibernation:
  1. In Category view, click Start , click Control Panel , click Performance and Maintenance , and then click Power Options . In Classic view, click Start , click Control Panel , and then click the Power Options icon.
  2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply . Figure 1: Enable hibernation check box c00035872.gif
  3. Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Manually put your notebook into hibernation This feature is available only on notebooks with the Windows XP operating system installed.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box. NOTE: If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start , and then click Turn Off Computer . In the Turn off computer dialog box, hold down the Shift key. The Stand By button will change to Hibernate. Click Hibernate .
Jan 06, 2009 | HP Pavilion dv1000 Notebook
How to turn on toshiba satellite M300 laptop from hibernating mode
hi shirleygty, is that automatic hibernation (the computer hibernates by itself) or manual hibernation (by pressing the hibernate button)? If either applies to your case you might need to update the BIOS information for your computer to fix the power management issues on it. You can get it here. Just run the file, click install & choose Install From Windows. Make sure you don't have any BIOS password or any external devices connected to the computer. When the update completed successfully, your computer will automatically restart, then try hibernating this time (manual or automatic). I do recommend setting the hibernation to 1min. at the control panel > power options > change when to turn off the display. When it hibernates, pressing any keys or the power button should wake up the computer.
Hope this helps.
Oct 05, 2008 | Toshiba Satellite A205-S4617 Notebook
Won;t Hibernate
Sony laptops are infamous for these kinds of problems. You very likely have another Sony program running in the system tray which is trying to control all power functions in a "smart" (in other words, defective) manner, and this is conflicting with and resetting your OS's normal power settings. Try to find this program on your laptop and run it and check what it thinks it is doing. You might also have a problem with the actually writing of the hibernation file on your machine due to any number of problems (low disk space, conflicting file names, corrupted administraive priveledges for whatever program thinks it is doing the writing). I'd suggest uninstalling the SONY power management software and then using the stuff the operating system provides. It might not be good, but it at least works kind of, and consistently.
The changing status of the hibernate settings you describe suggest to me that another program is changing them to try to be "efficient".
Last resort - disable hibernate; it doesn't work very well on Sony laptops even at the best of times.
Nov 16, 2007 | Computers & Internet
HP Pavilion a630n (PC109A#ABA) PC Desktop Logo
63 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
