Question about Broan-NuTone Broan 110 CFM Premium Bath Fan, Model 676
How can I change the light bulb in this fan. The
How can I change the light bulb in this broan bathroom fan. The unit seems extremely secure if I try and pull it down. I'm afraid it will break.
    Guru:
  • 332 Answers
They have opening clips on the top side all around the cover, you can reach it with your fingers and try opening them all, the cover will come off easily, once done you can unscrew the light bulb and install a new one.
Posted on Feb 07, 2010
  • 4 more comments
  • ViperLancer Sep 30, 2010
    While he is technically accurate, to be more clear, it is the center cover, not the whole cover, which has the clips. As in, the clearish plastic part the light shines through. To release the clips, you simply push inwards on the sides, then the cover pulls down.
  • shard72 Dec 04, 2010
    The clips on my light were not visible but when I used a thin blade screwdriver on the ring holding the globe (glass dome) it moved easily and I could see how it would open. It opened like a recessed light with spring clips. If only I could put a picture or diagram on here it would explain itself. Good luck.
  • cgh1 Jul 19, 2011
    Thanks ViperLancer. Please allow me to again point out "It is the CENTER cover...the clearish plastic part the light shines through" that you push inward.
  • Kathryn Lipin Jul 14, 2012
    These instructions worked perfectly for us, especially the comments that it is the center translucent cover which has the clips. Now it's a piece of cake to change the bulb.
  • Rick Ducharme Aug 17, 2013
    Thanks for the tip. As mentioned bycgh1, it is the translucent cover which is removed. I used a small screwdriver and found the clips on the left and right side of the cover. After releasing one, the cover dropped down.
  • Janet Isackson
    Janet Isackson Mar 19, 2014
    thank you! now my husband can do this too!!!
CHANGE LIGHT BULB I BATH FAN
According to Broan's site - the model you specified has no light bulb - check specifications - you can search the site for the proper model and download the instructions.
http://www.broan.com/products/product/4108f1af-c993-4327-982f-1174f091fd6f
Apr 12, 2014 | Broan-NuTone Broan 110 CFM Premium Bath...
How do I change the light bulb and/or night light for my NuTone bathroom Fan-Light Model 8663RP?
The whole cover/grill/globe pulls straight down to expose the bulbs. There are two heavy "V" springs, one opposite the other, that hold the grill to the fan box. You need to overcome the holding power of these two springs to pull the grill down. If necessary, you may want to run around the edge with a sharp knife in the event it was painted in place.
Mar 30, 2010 | Broan-NuTone N-8663RP Combination Light...
Broan square bathroom fan light combo, no screws - how do I change the bulb?
The entire vent panel and light lens is held up against the ceiling by two spring clips mounted on 2 sides of the panel.
To find which two sides they are one, (they're opposite of each other), just pull on one side with your finger tips and when you see the wire spring clips, just pull down on the two sides where they are so you can get to the bulb socket.
The panel will pull down about 5-6 inches you can then either get at the light bulb, or lift up the light lens to clean it and get the bulb out.
Be sure to replace the bulb with the proper wattage bulb so you don't overheat and melt the lens in the unit.
When you're done, all you do is push up gently on each side to get the panel back in place. You might have to squeeze the wire retaining clips to get them back in, but they'll go back OK.
If you want to completely remove the cover panel, you just squeeze the retaining wire clips nearest the fan enclosure on each side and that will let you take it all the way off for cleaning, etc.
Hope you find this Very Helpful and best regards!
Sep 24, 2009 | Broan-NuTone Broan QTXE150FL Bathroom...
Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Aug 11, 2009 | Broan-NuTone N-8663RP Combination Light...
I need an exploded picturial view of the BROAN fan and light kit. Thanks
go to www.broan.com from there you can look up that fan/light combo and download the installation manual which will give you the exploded view.
Broan Bathroom Fan Care and Cleaning
heatman101
Jul 02, 2009 | Broan-NuTone N-8663RP Combination Light...
I think that the plastic round will pop out of the center--held in by tabs?
Mar 02, 2009 | Broan-NuTone QT100L Fan
Bathroom fan
You'll be able to access the motor to service it and the wiring junction box from inside the bathroom. Please rate this answer if it was at all helpful.
Jan 31, 2009 | Broan-NuTone Designer 721 Ceiling Fan
Open Questions:
See all Broan-NuTone Broan 110 CFM Premium Bath Fan, Model Questions
Broan-NuTone Broan 110 CFM Premium Bath Fan, Model 676 Logo
6,580 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
