Question about Gateway 7330GZ Notebook
I tried downloading the hard drives. It won't let
I tried downloading the hard drives. It won't let me download the basic devices such as controller because they say that they aren't installed. I can't get the internet to connect because it won't give give me an IP address.
  • 11,896 Answers
Go to start menu, then control panel, the performance and maintenance, then system, the find device manager, You can expand the lists here which should have all your devices on it. From here you can download drivers, change settings, check to see if devices are enable and working properly or not.
If you can get an ip address, go to start menu, go to "run" type ipconfig release, then ipconfig renew and it should issue you a new ip address.
Posted on Feb 07, 2010
Acer external hard drive problem code 10
Try chkdsk or download Testdisk and run to ensure the disk is in good order.
Feb 27, 2013 | Acer Computers & Internet
I have hundreds of pics and my WD won't open
can you see your wd passport in windows explorer ?
you might check all power and data leads that are attached from your wd passport to your computer make sure they are not faulty
Windows 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error.
This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition.
Now I have seen cases where Malware can break the link of a Hard Drive.
So let's try a couple of steps.
Let's go back in to "Disk Management"
Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths"
Now try selecting a new Drive Letter.
This will restore the path if it has been broken.
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
hope this helps
Sep 23, 2012 | Western Digital Passport Computers &...
DVD/CD drive won't recognize discs. System says corect driver installed
Is it a disc that someone made on their computer and gave to you or is it one you purchased from the store? Computers sometimes have a hard time reading a disc that someone made and gave to you. Try a disc that you purchased and see if it plays it.
See if you can update the driver in the device manager.
Uninstall the DvD Drive from the device manager, then reboot and let it reconfigure everything. Go the Control Panel and under System find the device manager. Right Click on the dvd drive and select uninstall. Reboot.
Reseat the the disc by unplugging the power cord, remove the battery, then turn the laptop over and remove the screw that holds the dvd drive in place. Pull the drive out, then put it back it.
If you are using Windows Media Player try the VLC player.
Try using VLC as your player. Go to www.google.com andin the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Downloadand install it. It downloads and installs in 3 minutes or so. It'sa very fast player, smooth and it can play just about any type of dvd formatsand media. It's totally FREE.
Apr 14, 2012 | Computers & Internet
I recently upgraded my operating system (to Mac OSX 10.6) and now my VCI-100 won't show up as a device. Any advice on how to resolve this?
Here is an online manual, Can't download it, though. Hope it helps.
http://www.manualslib.com/manual/399951/Vestax-Vci-100.html
Mar 10, 2012 | Vestax Vci 100 Midi Controller
Cant find driver for SimpleTech 250gb external hd. Is it available?
Should not be necessary. It is recognized by the system automatically. Try connecting to another port, check the data cable and the connection to the unit, it may be corroded or loose.
Sep 13, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
I have unplugged my Toshiba Canvio 500 GB Basics Portable Hard Drive usb cable while transfering data, and my windows won't detect anymore. And i scan with some tools it says its have a bad sector at...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover lost files.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Sep 05, 2011 | Toshiba Canvio Basics Portable 320 GB USB...
I have a usb portable diskette drive that says compatabible upto windows 98 I have windows 7 can I download drivers for it?
If it won't plug and play then your basically out of luck. That is a very old device. If you still need to access floppy's i would purchase a newer device or have an internal floppy installed.
thank you,
Lee
Jul 26, 2011 | IBM USB Portable Diskette Drive (05K9276)...
When i try to download something it says connect storage media to save destination what does that mean and what can i do to download stuff without that coming up
File formats that the PS3 doesn't recognize as something that it can play, can only be saved to a USB storage device, or a memory card. You can't download anything to the PS3 hard drive via the browser that you couldn't copy to it from a USB storage device. That is what the error message means. You have to connect an external storage device, because the PS3 won't store this file format on the internal drive. This protects the integrity of the system. If you connect a USB drive or memory card (you will need a USB adapter for the memory card if you don't have a launch PS3), then you can download anything that you want using the PS3 web browser. Sometimes called a thumb drive, a USB drive costs about $20 and plugs into the USB slot and is removable.
May 01, 2011 | Sony Playstation 3 (PS3) Console
I don't have driver of pen drive in windows 98
Let's check your Windows 98 Version first :)
  • Right click on My Computer and select Properties
  • On the System Properties page that opens up click on the General tab, if it is not already on that page.
  • Under the System heading, look for the version number (see right)
    • Version 4.10.1998 is the original version of Windows 98 (98FE)
    • Version 4.10.2222 is Windows 98 Second Edition (98SE)
  • Click the link below for the download and installation instructions for your version of Windows 98
Fo Windows 98 FE:
  1. Download and install the Windows 98 Service Pack (35.5Mb)
  2. Download to your desktop the driver file from the Download section below
  3. Remove ALL drivers for USB flash drives in Device Manager (Optional)
  4. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option) (Optional)
  5. Remove ALL unknown devices from Device Manager
  6. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  7. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
The drivers can be downloaded from the following link:
Windows 98 FE Generic USB Mass Storage Device Drivers v3.20
For Windows 98SE:
  1. Download the exe file to the desktop
  2. Remove ALL drivers for USB flash drives in Device Manager
  3. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option)
  4. Remove ALL unknown devices from Device Manager
  5. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  6. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
Windows 98 SE Generic USB Mass Storage Device Drivers v3.3
For detail explanation, please visit http://www.technical-assistance.co.uk.
It's help for me :)
Thanks
AkulahPathub
Mar 13, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Gateway 7330GZ Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
