Question about HP OfficeJet J4580 All-In-One Laser Printer
Getting this error message: Print cartridge problem: Tri-Color. Refer to device documentation for troubleshooting.
  • Rod Eslinger
    Rod Eslinger Apr 05, 2013
    This error ("refer to device documentation for troubleshooting"), along with the famous "Incompatible Cartridge" error message, typically signifies the cartridge is suffering from internal electrical (micro-electronic) damage. You can bypass the error (temporarily in most cases) and run a cartridge health diagnostics check, via the 2 service procedures below: HP Officejet J4500 J4600 4500 Cartridge Error Bypass -- HP 901 Cartridge Errors:http://www.youtube.com/watch?v=I4-m_RLdR... HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics -HP 901 Incompatible Print Cartridges:http://www.youtube.com/watch?v=S6uATgXxQ... (please note this is a service test, the printer will attempt to print the tap 41 pattern, whether the cartridges are good or bad): HP 901 Ink Cartridge Care Tips - Everything you need to know:http://www.youtube.com/watch?v=jTtNj6rN4...
    President:
  • HP Master
  • 2,923 Answers
Print cartridge problem: Tri-Color means that you need to replace the color cartridge and the problem should be resolved.
Good luck and have a great day!
Posted on Feb 07, 2010
kiio
  • 31 Answers
SOURCE: tri-color cartridge problem
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
308
Posted on Mar 17, 2009
BelgianAlien
  • 50 Answers
SOURCE: HP Solution Center Screen said:
Have you tried to replace the current cartridge with a new one? It is not uncommon for even a new cartridge to be faulty, It happens sometimes.
Also, look in your printer manual for the procedure on how to run a nozzle/cartridge cleaning and alignment.
If that does not resolve it, take the cartridge out, grab some rubbing alcohol and some q-tips. Put some rubbing alcohol on a q-tip and GENTLY wipe the contacts on the cartridge AND on the contacts in the printer where the cartridge installs. BE CAREFUL! Make sure no cotton from the q-tip gets left behind on either.
Good luck and thanks for using the fixya forums!
Posted on Mar 27, 2009
SOURCE: printer 4580 tri color troubleshoot
i think i run out of ink[or color.whatever the stuff in there is called]
so i will buy a new one and try to see if it fix the problem
Posted on Jul 19, 2009
SOURCE: Print cartridge problem : [tri-color
My husband pushed and wiggled each connection on the back of printer and it started printing. No flashing problems!! Maybe it is in the connections.............Hope this works for you
Posted on Oct 03, 2009
SOURCE: Getting the error code: Print Cartridge Problem
I have the same problem. Is there no other solution then changing the ink cartridge?
Posted on Dec 04, 2009
I got 3 months ago message on hp officejet j4580 display: Print cartridge problem: [Tri-Colour]. Refer to device documentation to troubleshoot. Today while printing a document, i noticed printing with...
You must be using HP60.
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you used brand new, do same thing to cartridge circuit part.
Otherwise, there got to be some circuit shot happen in printer.
For your reference, HP4580 is pretty new model and has not cause major problem.
Good practical and durability is good.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | Office Equipment & Supplies
I am receiving the ?Print cartridge problem-[Tri-Color] refer to device doc. to troubleshoot.? Error message on my Hp j4580. There is no help in doc and nothing I?ve tried (cleaning etc.)works. Should I...
I had the same problem. I called hp and spent an hour running through the troubleshooting things that I'd already done. They ended up sending me a new ink cartridge, and surprisingly, it worked. For some reason, the printer refused to recognize a nearly full ink cartridge. Go figure. It seems to be working for now, but it's a huge waste of ink and money. If you have the patience for it, call hp and see if they will replace your cartridges.
Sep 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer 4580 tri color troubleshoot
Jul 19, 2009 | HP OfficeJet J4580 All-In-One Laser...
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
Just stoped printing;print cartridge problem
Remove print catrige and clean it with cotton cloth then refix it.
May 19, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
Apr 03, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP OfficeJet J4580 All-In-One Laser Printer Logo
179 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
