Question about Life Fitness 95Ti Remanufactured Treadmill
Treadmill wont run its saying waxer empty and notify maintainence
    Problem Solver:
  • 18 Answers
Does this treadmill have a wax system ? If it does it will have side access panels on the side just above the rear leveler. The picture that shows here does not but need to be sure it does not really need wax.
If it does not have a waxer- enter maintenance settings on display console,I do not have one in front of me but I believe you hold pause button down and press clear twice. This should bring up maintenance settings.
Scroll using up down arrow untill you see replace wax bag or something to that effect. select [enter ] to save. press clear clear to restart.
Posted on Feb 07, 2010
  • Ronnie Pelton
    Ronnie Pelton Dec 24, 2014
    Some ofhe 95ti`s do not have a wax system but instead use a wax impregnated belt.
    Problem Solver:
  • 50 Answers
95ti has a wax bag but first check the spray nozel as this tends to cover with hardened wax, if this is the case just pick it off with your finger usually needs doing every couple of months depending on use. Also check the bag of wax which I believe is in the rh rail easy to check with a small squeeze if it is empty it will be flat.
Hope this helps good luck
Posted on Dec 01, 2014
  • Hasim Kovacic
    Hasim Kovacic Jun 12, 2016
    Thanks. Very helpful. My 95ti had a wax bag only half used and the spray nozel just needed cleaning.
Display screen says waxer disconnected how do I fix
Remove the motor cover and look for the Wax lift board , it's right by the motor controller and check all wiring going to it.
Mar 01, 2015 | Life Fitness "Remanufactured 95Te...
Treadmiill keeps saying waxer needs filled after filling it
please see the cause and remedy and fix it. Please read carefully your section of troubleshooting instr. manual or download
Inspect spray pattern between 8" (200mm) and
16" (400mm).
If not, verify wax nozzle is clean, hoses are not
kinked, wax bag is not empty, or wax is
contaminated.
http://www.sportsmith.net/images/product_support/lifefitness/Treadmills/TR9100/9100 Treadmill Manuals/Service/m05100k
God bless you
Nov 29, 2012 | Treadmill Doctor LifeFitness 9100...
What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Oct 15, 2012 | Life Fitness 9100 Next Generation...
    Describe your 9100 Next Generation Remanufactured Treadmill Problem display shows waxer disconected ???
    Dear Sir:
    I will help you inmediately.
    1) Display does not illuminate
    when machine is powered
    on.
    Insufficient power source.
    Plug treadmill into a dedicated amp circuit.
    2) Loose 10 pin connection at
    display console or wax/lift
    control board.
    Check all electrical connections for proper
    attachment.
    3)Damaged main harness wire
    connection.
    4)Replace wire harness.
    Faulty display console or Wax/
    Lift Board.
    Verify if 8VDC is present at P1 pin, 3-4 and
    12VDC at P1 pin 9.
    a)If yes, replace Display Console.
    b) If no, replace Wax/Lift Board. See How To...
    Replace Wax/Lift PCB.
    Use VOM digital (Voltimeter)
    Hoping that you can resolve, if you need some extra help, please reach me.
    blessing.
    E.CUADRA
    MANAGUA, NICARAGUA. C.A.
    Sep 13, 2011 | Life Fitness 9100 Next Generation...
    Our machine display show the following masage MOTOR CONTROLLER COMM DRD
    two possible issues
    one, unplug treadmill remove hood and make sure the main power connector to the motor control box is in properly then turn treadmill back on this has worked for me before
    two , you have blown the overload resistor on the motor control board (mcb) to check this unplug treadmill and remove the steel motor control box from under the hood remove the motor control board from inside the box and inspect it for damage and /or electrical burn smell
    if you find damage you will need to get it repaired contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping . it cost $200 plus shipping which is a deal since a new one is $1000,i have many repaired by them
    a common issue for the overload to blow is friction between the belt and deck board . if you have an auto waxer , the waxer nozzle is usually plugged . the nozzle should be cleaned once a month
    contact glide for their non clogging wax to resolve this issue
    good luck
    Dec 26, 2010 | Life Fitness 95Ti Treadmill 95 Ti
    I can't reset a fault named "wax empty" and my equipment doesn't work life fitness 9100
    hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
    Aug 13, 2010 | Life Fitness 9100 Next Generation...
    How do i reset the waxer on a 9100 lifefitness treadmill?
    Press these buttons:
    101–ENTER–
    HILL–RANDOM–
    FIT TEST.
    Program lights come on. Display will scroll toWAX DELAY OFF.
    Press speed "UP" or "DOWN"
    to toggle to
    WAX DELAY ON or OFF.
    May 13, 2010 | Treadmill Doctor LifeFitness 9100...
    I have a life fitness treadmill and put new wax in the blader how do i start the machine and put wax on the belt?
    you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
    Apr 12, 2010 | Life Fitness 9100 Next Generation...
    Variable speed Control problem
    When you are finishing the surface, it's vital to maintain control. Work too fast or too slow and you risk ruining your hard work with unsightly scratches
    Aug 27, 2008 | Vector Vec 260 10 Inch Waxxpro...
    Life Fitness 95Ti Remanufactured Treadmill Logo
    2,659 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Howard
    Howard
    Electro Med Services...
    Matt Olenzek
    Matt Olenzek
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
