Question about Frigidaire Dryers
My dryer is working but it is not producing any heat. I reset the circuit breaker but it still isn't heating up.
  • 3,230 Answers
Well it's better if you can tell us the model number of your dryer....... anyway first of all you can check Vent- Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. then you can check the heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Please post comments for more help or information........
Good Luck!!
Thanks
Posted on Feb 07, 2010
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Does not heat and the timer does not shut the dryer off
Most dryers have two circuits. It sounds like one of these has a blown fuse. Check the breaker/fuse box and make sure the breaker isn't tripped or the fuse isn't blown.
Jul 24, 2011 | Dryers
Dryer want heat up what's problem
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it. Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Dryer heating elements come in various shapes and sizes. They are all strung with a coiled wire made of a nickel and a chrome alloy. This wire receives, but resists, a controlled electric current and as a result, the wire heats up. The heat produced is used to heat and dry the clothes in your dryerOnce you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it, thanks to parts direct
May 31, 2011 | Maytag Neptune MDE6800 Electric Dryer
My dryer has power and tumbles, but produced no heat (tested with vent tube off). I reset the circuit breaker and now it produces heat. What is up?
If your dryer is clogged up this will not produce heat inside the dryer but will produce heat to the vent tube. Try unclogging the Vent tube and see what happens.
Feb 18, 2011 | Dryers
Does not produce heat anymore. 3yrs 8mos old.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Make sure front of dryer is not blocked, Air Flow is needed to dry. Check that the lint filter and exhaust duct is clean.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 01, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
No Heat
Hi, Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Thank you!
May 10, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
HE3t Kenmore dryer runs fine but suddenly stopped producing heat
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Kenmore Dryers
Replaced coils / looks good and produced heat but now no heat
caused a short maybe ,reset circuit breaker and check 4 wire against frame
Aug 23, 2009 | GE Dryers
Kenmore Dryer model # 60202990.... no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Sep 13, 2008 | Kenmore 62872 Electric Dryer
Dryers Logo
19 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
