I have a Maytag gas range Model numberMGR5720BDW with serial number 11529709ZK. My problem is The code F3 keeps coming up when I try to turn the oven on. I bought this appliance used and have no manual. Can you please tell me what this code means? My email address is [email protected] or phone is 337-255-6625. Thank you Pat
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
F3 is a sensor error. The sensor is in the oven it is a metal rod coming in on the back wall of the oven, it is a little smaller than a pencil. It is either gone bad or came unplugged. It runs up the back to the electronic clock, there should be two wires on it and 2 connections to check.
If you take the back off the stove be sure to unplug the power cord first.
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
hi thanks for the question the part you need is the oven sensor witch is located , in the oven top left /looks like a pen replace that part the number i got is 1365 from repair clinic . thanks the appliance doc
Here is your online use & care manual which explains all about the Sabbath mode on page 15:
http://www.maytag.com/cust_serv/pdf_use_care_manual/8113p462-60.pdf
(http://www.maytag.com/cust_serv/pdf_use_care_manual/8113p462-60.pdf)
