Question about NAD T751 Receiver
HOW TO CONNECT SPEAKERS B&W 601 S3 TO AMPLIFIER NAD T751?
Just for listennig a music.
Gurudristi
  • 98 Answers
SOURCE: Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Posted on Mar 12, 2009
johnnydiode
  • 647 Answers
SOURCE: My front display is burnt out on my NAD T751. How do I fix this?
Usually the problem is not that the display is burnt out but the voltage that supplies the filament is missing due to bad solder contacts on the terminals of the display.
If you disassemble the unit so you can see where the display assembly solders into the board check/resolder those terminals.
Posted on Oct 20, 2009
  • 10 Answers
SOURCE: NAD T751 constant buzz
It is a known problem with this model. The source of the buzz is the Dsp power supply. On the DSP board itself there is a 2200my\f/16v capacitor that is defective . Usually the capacitor will turn brown and swells due to overheating. Replace it with a higher temp rating capacitor with the same capacitance and voltage specifications.
Posted on Aug 10, 2010
mlapres
  • 757 Answers
SOURCE: I own the nad t751
Yes. However, you will need an additional connection type. It is the coaxial connection for your DVD player. Just replace your existing optical cable for that connection with the coaxial connection (sometimes labeled on some players as "bitstream"). Then you can use the optical cable to the Apple TV.
Posted on Nov 14, 2010
dunnbiker
  • 8546 Answers
SOURCE: Hi, I have a 304 NAD
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor. It's wise to occasionally (with power OFF) operate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Posted on Feb 04, 2011
How do I connect a cd player to both a tv and an audio amplifier so Ican play either Cd's or DVDs?
Does the TV have a line audio outpot (red and white jack)? If so feed the amplifier input from there.
Dec 23, 2012 | NAD C372 Amplifier
My NAD C326BEE amp goes into protection mode at moderate volume
The protection only should come on, when the power amplifier has to give more current than it can deliver. (electronic fuse)
If in the music is a lot of subsonic, sound, so low you can't hear and your speakers can't produce, this could cause the problem. Normal CD players will cut of all frequencies beneath 20 Hz, but it could be your PC is giving everything from 1 Hz and above.
I would certainly try to play some music over a CD player and check if that would solve your problem. Not sure if that works, what you could do to suppress the sub sonic in the computer music.
Aug 22, 2012 | NAD C326BEE Amplifier
Hi, nad going but no sound from speakers. can get FM but only up towards full volume.
Checker speaker wiring on back for shorts, if okay! the audio drivers and outputs are highly suspect, at this point I suggest a serviceman because of the complexity of the surround sound system.
Apr 20, 2012 | NAD T751 Receiver
I OWN A NAD M 25 ---7 CHANNEL AMPLIFIER. I AM USING 4 CHANNELS TO BIAMP MY SPEAKERS. ONE OF THE UNUSED CHANNEL IS SHOWING A RED PROTECTION LIGHT.THE BIAMPED CHANNELS ALL WORK FINE ...I HAVE CHECKED ALL...
The manual would suggest you have a problem.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-M25-Amps-manual/id/8043ci561/t/2/
Try unplugging all of the speakers and see if that amp is still distressed. If it looks clean and happy start adding speakers until it returns (or not).
Jul 03, 2011 | NAD M25 Amplifier
How do you connect a nad c270 amp to the bose 901 series vi equlizer and system/
Bear in mind that 901's require exclusive use of any amplifier they use. You shouldn't expect to use conventional speakers alongside them on the same amp. The reason is that the 901's require the use of their dedicated Active Equalizer to shape the frequency spectrun to match their drivers' response curves, resulting in a flat sound output. Applying that kind of equalization to any conventional speakers will sound to sharp at the extremes and may even potentially damage them.
For connection I would run a pair of RCA cables from the L&R Audio Line OUT of whatever preamp or source you're using to the Active EQ's Line IN; then the EQ's Line OUT to a NAD amp's Line IN. DEselect any Tape options on the Active EQ, attach the 901's to the new amp, set the NAD volume controls pretty high (and leave them alone), run through any level setup procedures in your control electronics for volume, etc and you're done.
Aug 17, 2010 | NAD C270 2-Channel Amplifier
I am trying to hook up my home theater system
marvidson,
With the NAD model that you have and its lack of component or HMDI switching, the only way is to connect your system, sort of, backwards.
The only way to do it is to connect your digital cable box and blueray player directly to the tv, then the audio output from the tv to one of the video inputs on the NAD. The NAD has digital coaxial and toslink inputs so if your tv has one of them as an output, that would give you the best sound to the NAD. If your tv does not have either of those outputs, then you will be limited to the composite outputs (red and white) but that will still give you good sound.
Also, depending on the digital output to input configuration, you could possible find a converter online.
-Chris
Jan 19, 2010 | NAD T751 Receiver
Dear Tim,
Mar 12, 2009 | Onkyo TX-SR803 Receiver
NAD 7140
Amplifier is about shot, need to replace IC pack or transistors (whichever it has). Could, remotely, be the speaker lines are installed incorrectly?out of phase. + to +, - to - from amp to speakers. Some amps will protect themselves when this condition occurs till fixed.
Aug 01, 2007 | NAD 712
Nad 302 amplifier
sounds to me that the vol control has lost its earth end connection So yes its a problem with the dial control You couls try some contact cleaner But better still lift of the lid and base if possible while the amplifier is not plugged into the power socket and see if you have a dry joints around the vol control pot regards Trev
Mar 14, 2007 | NAD CI9060 Amplifier
Open Questions:
NAD T751 Receiver Logo
130 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
