Question about Medion MD-1768 PC Desktop
I blew the tower out with compressed air and replaced the thermal glue on the back of the proccessor. I also started to remove the front cover, but then decided to put it back on.. it didn't want to go back on and took a bit of elbow grease to snap back on. Now the power button blinks rapidly with the fan running low when I apply power to the tower. any help or suggestions would be appreciated
  • joecoolvette
    joecoolvette May 11, 2010
    Computer unplugged from power. Check for pinched wires by that Front Panel. Also I hope you cleaned the top of the Processor's case, and the bottom of the Heatsink THOROUGHLY, (Not shouting), before reapplying thermal Paste. (I hope it isn't thermal glue!) I use an old plastic credit card, and Q-tips with Isopropyl Alcohol, (Rubbing alcohol. CAUTION - FLAMMABLE!), to scrape the Processor, and Heatsink clean, then follow with the Q-tips/Alcohol. Make sure the Heatsink is sitting flat on the Processor. Three screws tight, and one loose will cause problems. Using clips to hold the heatsink on, finesse has to be used as the Heatsink could be tilted off to one side, if one clip is snapped into place, then the other. Best method is to snap both clips in place simultaneously. Using TOO much thermal paste can be as detrimental, as using no thermal paste. When the Processor heats up to normal working temperature, the excess thermal paste will ooze out, and make it's way down to the pins of the Processor, and any exposed solder joints. If by chance a thermal pad was used, never reuse it. Thermal pads are junk anyway, toss it in the trashcan, use thermal paste. Thermal glue is not a good idea, because the next time you want to replace the thermal media, the Heatsink will be glued to the top of the Processor case. Generally you have to use a hairdryer on low heat, (Moving back, and forth), to get the glue to soften enough so you can GENTLY twist the Heatsink sideways, back and forth, to remove it. NO FUN! Puts sweat beads on your forehead. I hope you observed anti-Static precautions, when you went to replace the thermal substance.
  • 617 Answers
Take cpu back out then re-install
Posted on Feb 07, 2010
Sears 417.80042990 keeps blowing thermal fuse
Did you clean out the lint filter at the front, heat is the enemy. Clean out all lint from front, if you are handy, get around back and remove all lint and dust by blowing compressed air.
Sep 21, 2012 | Frigidaire FEQ332E Electric Dryer
Have a GFSF6KEXAWW and would like advice on cleaning the coils. Do I need to remove the back cover?
Yes ,remove the back and front cover and use a well direct burst of compressed air to clean the coils. You can use a brush, but the best cleaning method can only be effected with compressed air.
Dec 23, 2010 | GE Refrigerators
Cycle stops and F35 displays flashing
I blew mine out with compressed air and it worked, You have to take the cover off and remove the small rubber hose. Then blow out the hose and blow into the small hole on the sensor. It is easy to remove from the machine, 3 screws in the back then remove the rubber hose, twist the unit so the bottom is facing the back of the washer and it pops right out, then remove the wire plug.
Oct 16, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
Entire vent system cleaned (was really bad). Purchased thermal fuse and thermostat kit la-1053 . Motor spinning fine as well as the air wheel is tight. Removed tumbler unit, checked tension pulley, motor,...
Did you clean the exhaust from the wall behind your dryer to the outside. This is more important than the dryer exhaust system itself. If not get behind dryer and remove exhaust to the wall and using a leaf blower,(electric) put it inside house vent then push dryer back to hold in place go outside and watch to see what all blows out. Good luck.
Jan 29, 2010 | Dryers
Same problem -- won't start
Are you getting gas from the tank to the carb?
Maybe pluged fuel line...
Also pull bowl off carb and pull out main jet if it has one and make sure that you can feel the compressed air coming thru the main jet, plus also check idle cirurt the same way...
Sep 12, 2009 | Yamaha 1,000 Watt Portable Generator...
My acer 5420 keeps overheating and shutting down
Clean the insides of your Desktop case.
1. make sure all the fans(CASE FANS, POWER SUPPLY FANS AND CPU FANS) are working dust and lint free.
2.remove dust and dirt build up in CPU heat sinks.
3. remove dust and dirt build up in the motherboard, RAM and
expansion slots.
4. remove dust and dirt build up on CD-ROM's, Hard Disk Drives and expansion bays.
5.apply new thermal paste on your CPU.
Jan 20, 2009 | Computers & Internet
Loud Fan on XPS 200
welcome to fixya
if you have a desktop then this is easy
remove the cover of your destop (Make sure unplged )
on the top of the fan should be 4 screws unscrew them and remove plug there you go then go buy an ew one and replace
HOW EVER i would just go buy some compressed air and try to blow the fan out first and clean it up so no dust or anything is in it then while your in there blow some of the air into the power supply to get the dust and stuff out of there
And blow ot the entire computer while your there this should all be done atleast 1time a month .......
hope this helps you out have a good day :)
Jul 28, 2008 | Dell XPS 200 PC Desktop
Nve n852a it keeps trying to load software
Jack7777,
I opened up the Navigation and blew it out with some compressed air and the software loaded up once and the navigation started. Try that.
-TT_MT6
Apr 01, 2008 | Alpine PowerNav NVE-N852A GPS Receiver
!!! TOSHIBA SHUT DOWN !!!!!!!
If ventilating helps, check that the vents on the bottom and where the fan blows out warn air are'nt blocked, try gently hoovering around area witha nozzle.
Oct 21, 2006 | Toshiba Satellite A60 Notebook
Medion MD-1768 PC Desktop Logo
98 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
