Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
I replaced the lamo 6 months ago, but thepicture just went off. The green light flashes then the red light fla
Have blue spots on screen of tv
Posted on Feb 12, 2010
  • 668 Answers
If you turn the set on and the green light blinks then the red light blinks and no other sound comes from the back of the set and you cannot hear any fan turning, you probably have a bad Temperature Fuse. It would be locate either under the lamp assy or on the side of the lamp housing. It would be necessary to remove the Optical Block to get access to it.
I hope this helps,
Skyassoc
Posted on Feb 08, 2010
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
The gear shift indicator light flashes green all the time while the engine is on, regardless of what gear it's in. Even if it's in park, the park light indicator is red, but a green light still is fla
Transmission problems. Have the codes read. Could be just a solenoid replacement. Keep driving it like this and it soon will be a transmission rebuild.
Jan 23, 2015 | 2007 Honda Civic 1.8
We replaced the lamp about 6 months ago..but now it cuts off randomly..the red light and one green light will flash? Lamp replacement was when all 3 lights were flashing. Suggestion?
Is the picture quality good if it is then the lamp is ok try to reset the lamp timer if you haven't all ready. I think that the problem is coming from the ballast board this is the power source to the lamp, with time this part starts to ware out and starts to get weak. that is the reason your lamp does not stay on
Sep 07, 2010 | Samsung HL-S5686W 56" HDTV
When charging the batteries, are there 2 lights that go on...1 red and 1 yellow?
on my m51 the lights on the charger are red and green the green is flashing what is this telling me.also should i have the controller on when i plu in the charger my chair i 6 years old battery replaced 2 years ago
Jun 18, 2010 | Invacare Pronto M51 Power Wheelchair
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
My Sony Wega 60 LCD (model # KDF_60XS955)
below the lamp is a thermal fuse that has opened
Sony Part Number: 191002393
https://www.vancebaldwin.com has them in stock
thanks
scott
May 30, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
175 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
