Question about Clio Designs Health & Beauty
The clio electric shaver just will NOT turn on and i just put new AAA batteries in i.
5 Suggested Answers
  • 5 Answers
SOURCE: how to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Posted on Jan 07, 2009
SOURCE: Electric Shaver will not charge
There are 4 small philips head screws deeply recessed on the rear of the razor. Unscrew these and the back half of the case just lifts off. Unsolder the battery leads and fit new battery pack.
Posted on Mar 21, 2009
brector3
  • 1623 Answers
SOURCE: Braun Synchro 7526 Electric Shaver How do I open
You will find an instructional video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
You will also find compatible batteries at the link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Posted on Nov 28, 2010
  • 1739 Answers
SOURCE: Can batteries in Remington 5130
Yes you can have the battery replaced. This however needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
Posted on Apr 05, 2011
Needs a new battery
lolol
keith i dont know alot about shavers but i would either suggest getting a new battery and searching you tube videos about this (: or get a new shaver ): .
also some shavers have hex screws that they put on electronics to keep you from disassembling it, but if u really want to fix it you would need a t5 screwdriver.
Sep 12, 2013 | Philips Philishave HQ481 Electric Shaver
Norelco 7240 battery
I have a shaver of that type too and when my father's shaver and mine went dead I put NMH type batteries in them. Now these items are made with Ni Cads but they are old design type batteries. The charging of these batteries have to be managed but being the readout on mine tells you when it is full the problem is not such a big one. Just do not leave plugged in for days. Nickel Metal Hydride batteries can have twice the capacity of the Ni Cads and also they have no memory effect.
I would get some premium batteries from Tenergy and solder them into the unit and see what happens. I think they have 2 AH batteries in AA size now and almost that in AAA types.
Oct 01, 2012 | Philips 7240 XL Electric Shaver
How do I remove the old blade from my clio palm shaver
Hi tluve555-
I'm assuming you are talking about a clio plamperfect battery-operated shaver. In that case, grip the shaver with one had and with the other use your thumb and forefinger to grab the combs on either side of the blade case. The blade is one unit that should easily pop out...it's ok to give it a little pressure. Hope this helps!
Jun 13, 2011 | Clio Designs Health & Beauty
How do I open my Braun 9585 Pulsesonic shaver to replace the battery??
Hello
Remove the electrical cord from the base of the shaver.
Press down and slide off the panel on the front of the shaver.
Remove the two nickel-plated batteries. Use these batteries as a guide to purchase new batteries at a hardware store or home repair store. Recycle the old batteries when finished. (Many hardware and home repair stores have battery-recycling stations.)
Put the new batteries inside the shaver and press gently to pop into place.
Place the front panel back on the shaver and plug the electrical cord into the bottom of the shaver. Connect to an electrical outlet to charge.
THANK YOU FOR VISITING FIXYA
Feb 03, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
My Phillips arcitec has a red light blinking at the very bottom of my shaver. I've had the shaver for 3 years.
It's means that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is Norelco RQ10 shaving heads.
Aug 05, 2010 | Philips arcitec 1060 Electric Shaver
Clio 1.2 W reg
try my last solution posted, connectors on renault clios renouned for corroded electrical connection car guaranteed to start unless car needs replacement loom these also prone to fail very bad design of wiring connections they did a better job in the 70s
Aug 09, 2009 | 2000 Renault 181
It no longer turns on even if pluged in.
It needs new batteries. I followed the instructions in this forum and had Batteries Plus connect in series and put solder tabs on NMH batteries, then installed them myself. It cost $12.
Jul 14, 2009 | Remington Titanium MicroFlex Ultra R-9170...
Motor does not start.
electric shaver hq5812 charges,light is on but does not cut efficiently
Aug 25, 2007 | Philips Philishave HQ5812 Electric Shaver
Health & Beauty Logo
59 people viewed this question
Top Clio Designs Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Clio Designs Health and Beauty Expert? Answer questions, earn points and help others
