I bought an Acer Monitor, I'm trying to register - it has a 3 year warranty. How do I do this? I used the SNID # that wasn't correct then I tried the S/N: # and nothing happened. What next?
  • 2,517 Answers
Please contact with acer.
Click me
Posted on Feb 07, 2010
Acer monitor will not start, power button flashes
hi Samuel.
this is all i could find from the internet.
You can try a power reset to see if that helps. To do a power reset, unplug the power cable and press and hold the power key for 10 seconds. Then, release the power key and plug the monitor in and attempt to use it. If you are still unable to get a proper display, We would suggest contacting technical support to inquire about warranty repair options. Many of our monitors carry a 3 year warranty, so there is a chance you may still have warranty left.
Acer Service and Support
you could also try this link out.
Acer 22 X223w LCD Monitor will not start up Google Search
Dec 14, 2017 | Acer 22" X223w LCD Monitor
Put code snid code in and says not known not sure i'm on correct site
the correct site is http://support.acer.com/register/default.aspx
if your not sure what the snid code is http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq29.shtml
Jul 19, 2011 | Acer Aspire 3680 Laptop
I have a acer aspire 5610z where can i find my snid # at on the bottom i can read what it says
It's the 11 digit number (numbers only) located next to the bar codes on the bottom of your product label. If you can't read it or if it's worn out, I am sorry, but if you still able to see the serial number and wish to register your product, you can still try using the Serial Number. Here's the direct link to register your product using either the SNID number or the Serial Number [click HERE]
Hope this helps.
Good Luck.
Thanks for using FixYa.
Apr 17, 2011 | Acer Aspire 5315 Notebook
My side bar on acer monitor screen has become white. How can I solve this problem? I was told to click on the auto configuration key but can't find it.
If you have a white bar running up the side of the monitor, then it is probably dead. Acer has 3 year warranties on their monitors so you should call them to see if you are still in warranty. If so, they will fix it free!
If more than 3 years old, try it on another pc. If it is the same on another pc, get a new monitor.
Hope this helps!
Regards,
Joe
Apr 04, 2011 | Acer AL2223W 22" LCD Monitor
My monitor is blank, the Acer logo will flash on when I start it but cannot get a signal, have tried it on another machine same response.
I am not too sure if you have tried this but this might help, for what i know your monitor have 2 ports for video (DVI and VGA). VGA is the one with color blue adapter, while the DVI is white. If your using VGA for both computer might be you can try DVI or from DVI to VGA. Also try a different cable for both VGA and DVI. If still the same might as well contact the Acer and check the warranty, normally monitor had 2-3 years of warranty, Have it replace if still under warranty.
I hope this works on your issue.
thank you for choosing Fixya.
Mar 06, 2011 | Acer V193W 19 inch LCD Monitor
I'm trying to register my Acer One netbook, but the numbers on the bottom of the unit clearly marked as S/N or SNID are not correct. The link that is supposed to help me find the serial number goes...
my daughter hooked up her acer netbook w/out me. now i cant find out how or where to go to register it so the warranty will be valid. can someone help me please?
Oct 22, 2009 | Acer Aspire One PC Notebook
Trying to find out if this ACER monitor is under warranty
Your monitor is still under the 3-year warranty. Go to this Acer website https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
to begin the process. Hope this helps.
Jul 09, 2009 | Acer AL2216WBD LCD Monitor
No display when using bulit in graphic card or AGP grahic card
ok!
first,
check your
motherboard
if all pin is conected properly
check your power suplly
try to replace the power supply
is not necessary to replace the power supply with the original powersupply
replace with standart 350 watt power supply (or higher)
then if the problem is still exsist
check *********** board
try to replace the motherboard
replace it with
any socket 478 motherboard
if nothing change
try to replace the RAM module
replace it with any DDR RAM module
then the last one
if nothing change
you must replace your processor
with an 478 socket processor
note: replace the component with borrowed
you  can borrow the component from your friends or anyone
then if your computer is showing display again
you can buy the component from ebay
here original specs of your computer:
Specifications - Aspire T310
Processor
Intel® P4 Processor with 400/533/800FSB (depending on processor)
Intel® Celeron Processor with 400FSB
Cache
128KB or 256KB (dependent on processor)
Memory
128MB DDR SDRAM PC2100/PC2700/PC3200 expandable up to 2GB
Chipset
SiS 661FX Northbridge Controller,
SiS964L Southbridge Controller
Expansion Slots
3 PCI v2.2 slots
1 AGP slot 4X/8X
Audio
Integrated Realtek ALC655 audio codec (SoundBlaster® Compatible AC97 Audio Codec)
Speakers (selected models)
selected models
Video
Integrated SiS 661FXVGA,
Storage
3.5" 1.44MB Floppy Disk Drive
52X CD-ROM, CD-RW or DVD-ROM (selected models)
20GB-80GB Hard Disk Drive (selected models)
Modem
56K V.90 (selected models)
Networking
Integrated Realtek RTL8100C 10/100 Base T
Ports
1 PS2 Mouse port, 1 PS2 Keyboard port, 2 USB Front, 4 USB Rear, 1 Parallel, 1 serial , 1 VGA, 1 game/midi, 1 RJ45, 5 audio (2 front, 3 rear)
Power Supply
Industry Standard 230 Watt
Chassis
14.2" 360mm) H x 7.1" (180mm) W x 16.5" (420mm) D
Operating System
Windows XP Home
Windows XP Professional
Windows 2000 Professional
Warranty
1-year Mail-in/carry-in warranty, Technical support for first year, available 8a.m. to 8p.m. CST Monday through Saturday (hardware only), 90 day software support. Call 1-254-298-4696
Specifications are subject to change without notice. Warranty covers only Acer purchased parts that are listed as supported and serviced. Please see limited product warranty for full details. Acer, the Acer logo, AcerPower, AcerAcros, AcerEntra, AcerAspire. Aspire by Acer, and Veriton are registered trademarks of the Acer America Corporation and Acer, Inc. The Intel Inside logo and Pentium are registered trademarks of Intel Corporation. Microsoft, Windows, Windows 95, and Windows 98 are registered trademarks of Microsoft Corporation. All other brands and products names are trademarks or registered trademarks of their respective companies.
Jan 24, 2009 | Acer Aspire T310 PC Desktop
Purchased an Acer Laptop Extensa 5630. Can't register warranty on line. Acer doesn't accept SNID 83604719920
If you have problems with the online registration, you should have a card that you can fill out and post. Or a contact number that you can call and register your details with. This will be inside the plastic bag that came with the instructions.
Nov 05, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer 1711 LCD Monitor
My Acer AL1711 packed up last week, I bought a new Acer and noticed they have a 3 year warranty. Give Acer a call on 0870 853 1000, and they`ll do a warranty repair with free pick up and return - great service! Not sure if you need proof of purchase or not, luckily I had mine.
Apr 09, 2007 | Acer AL1711 17" LCD Monitor
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
