Question about Behringer Pmp3000 16 Channel Audio Mixer
Left channel out on behinger ub2222fx-pro could use a service manual. Thanks in advance
  • Behringer Master
  • 5,603 Answers
Behringer only give the manuals to their authorized service agencies I am told.
Mixers are very symetrical and have lots of diagnostic capability from the outputs.
If you headphones work, chances are the moxer biss es are OK which probably focuses the problem on the output drivers.
Use headphones to see what jacks work... Remember that a stereo headphone will only have sound on one side for the mono jacks you test.
If your mains have a dedicated slider, one half of the slider could be bad. Usually you can tell those by a rougness as you slide them.
Posted on Feb 08, 2010
I have the same mixer (behinger europower, 12 channel). The other day it was being used for a regular speech when suddenly all lights on the mixer started flickering and the sound got cut. After about 30...
You do not specify what model you have.
It could be related to the power supply shutting down (e.g. from overheating) then restarting after cooling down.
If the mixer has a fan, you could check if it is uncovered, clean and running.
May 11, 2014 | Music
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
One channel working and one not
Yep... failed channel... most likely "A" channel? There is weak insulation between two layers of conductors on the power amp circuit board that breaks down and blows out the switching transistors for that side... it is usually the rear-most amp. Repair of the board takes GREAT skill in restoring it as the burned area must be ground away and re-insulated and jumpers put in to replace the circuit that has to be removed. The blown components then have to be replaced. One can buy a new HCA2400 amp module for about $155, but delivery takes forever. Also please read my tip on Fixya regarding PMP Behinger powered mixers of a hazard when using Speakon to 1/4 inch speaker cables/adapters.
Aug 15, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
No output from master out
Make sure channel(s) are assigned to stereo output
Mar 30, 2011 | Behringer Pro Mixer Djx750 Professional 5...
Where (on-line) can we find download for advanced manual for Behringer PMP 4000 16 channel powered mixer? What we found on-line was the exact manual that came with the mixer.
There really ISN'T and "advanced" manual... Everything you need to know is in the user manual that comes with it... Service manual with schematics will not give you much you can use unless you are into electronics detail.
PLEASE read my tip about Behringer PMP mixers on here regarding a hazard if you use Speakon to 1/4 inch cables or adapters. Essentially, the sleeve, NOT the tip is the HOT lead for a speaker on channel A. Ground it inadvertently and goodbye channel A amp.
Be VERY careful of speaker leads with this amp as it is easy to pop a channel IF a speaker comes loose or shorts. Loop cables through the handlesto avoid cables being yanked out or breaking plugs.
Feb 09, 2011 | Behringer PMP4000/B212XL Mains & Monitors...
Hello! I have a dbx 223xl, the right channel is good, but the left channel doesn't work, all de cap and electronic component looks fine, nothigh seem burned out, but it's still doesn't work. What can you...
The only way to troubleshoot this effectively is to use an oscilloscope to signal trace. You can't tell much about electronic components unless they have external damage which often doesn't show.
Jan 10, 2011 | DBX 223xl Active Crossover (Stereo 2 Way...
My UB2222FX mixer has lost stereo channels any ideas if its worth the time and money to fix? How is it fixed?
It should be repairable. Some simple testing will isolate the bad section. A common problem I have seen are people who power their system from different sources such as powering the mixer from a receptacle at the back of a room and speakers from other receptacles at the front of a room. Ground bounce and fault currents can fry input and output audio circuits. power ALL interconnected equipment from a single receptacle or power source.
Jan 08, 2011 | Behringer UB2442FX / B212D PA Package
Hi seems to be no dry signal getting into mixer sends still workin?am workin on a mix and gutted regards my mixer is a 1642vlz pro cheers
Here is where you can get the service manual:http://www.free-service-manuals.com/Mackie_1642-VLZ_Pro_Service_Manual_L15833/ Let me know if this helps.
Nov 26, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Ch. 10 does not work - Mackie 1604-VLZ PRO
Yes, the ribbon cable is the 1st thing I would check. You can check the ribbon like this: Disconnect said cable from the channels. Connect cable connector from a known good channel to the problem channel. If channel sounds the same trace a signal through the channel op-amps.
May 26, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Behringer Pmp3000 16 Channel Audio Mixer Logo
397 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
