Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Kenmoore 76523 ss bottom freezer, freezer works, refrigerator does not
Kenmoore model 76523 , ss bottom freezer. this unit is about 2 years old. suddenly the refrigerator completely stopped cooling but the freezer is fine, the lights work correctly but the digital display does not change temp control on any settings. I disconnected the power for an hour, i was then able to change all control settings but the refrigerator still not working. then after an hour the controls would not adjust anymore only display numbers and temp. would alarm .note; the freezer works but unable to adjust freezer controler. temp. did show as freezer cooling.all coils are frost free and clean.
any suggestions?
  • 2,336 Answers
Here is some additional info that could be helpful.
Click HERE
Posted on Feb 22, 2008
    Genius:
  • 3,422 Answers
first try setting your temperature settings to lower setting, check if your compressor is running you can hear a humming sound. if your compressor is not running try to check relay. if its running, touch the condensers at the back of your refrigerator if its cold their is leak on your system and need to be repaired by qualified technician.
  • If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostar
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Also have a look at thsese two links:
1)Click HERE
2)Click HERE
Goodluck..
  • Kenmore Master
  • 19,396 Answers
This is not my main field of expertise . However, as I see you are not getting more support I can address you to this link. It may help you
goodbye
Freezer and refrigerator are warm
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 12, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
If the ambient temperature is the same or less than the temperature in the fresh food cabinet of a refrigerator with the freezer on top, will the stat ever call for cool? sub question---where is the...
Yes, and if you turn the thermostat colder and the thermostat is in good condition it will. You model was made with a mechanical thermostat with Freon filled probe. You may need to close the cold air flow to bottom during extreme cold days and redirect the thermostat probe closer to the freezer opening but it should work. My refrigerator worked fine in ten inches of snow last year and temps in the teens. Thanks, Sea Breeze.
Jan 17, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Foul dead animal smell from kenmoore side by side refrigerator/ice maker
I'm sorry that I don't have a solution, but we have the exact same problem with an older model KitchenAid side-by-side. Did you get this problem solved? If so, can you share what you did?
May 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Freezer defrosting itself?
They refuse to admit to a sticking defrost. check mother board, LCD boards (2), retrofit air way (known defect). And don't take no for an answer.
Jan 07, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Rattling compressor on Kenmoore bottom freezer refrigerator
IF IS NOT 5 YEARS OLD YET CALL A TECH ASAP THIS MODELS HAVE A COMPRESSOR THAT ARE FAMOUS FOR LOCKING UP AND THE ONLY FIX IS TO REPLACE IT BUT FIRST DISCONNECT AND REMOVE BACK COVER AND RIGHT BY THE COMPRESSOR THERE IS A SMALL BOX ATTACHED TO IT CALL A OVERLOAD REMOVE IT AND SHAKE IT IS IF RATTLES THEN JUST REPLACE THAT PART IF IT DOESNT RATTLE CALL A TECH
Nov 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Mod #76523
The problem is the fan unit that pushes cold air up to the fridg, usually located nere the back of the freezer.
Aug 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
KENMOOR 59672253200
I was out of town and the top part, the refrigerator part lost the coldness. The freezer which is on the bottom is working ;just fine.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
193 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
