Question about Indesit Washing Machines
Indesit washing machine WIL123S doesn't spin fills with water then empties straight away
Privilege sensation 9414 washing machine showing E20
Posted on Feb 07, 2010
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit washer not draining
Check filter not blocked and pump turning freely
May 09, 2012 | Indesit Washing Machines
My indesit wib111 wont go ignto o spin cycle or empty.it fills and washes ok
Washing Machines do not spin when filled with water for obvious reasons. Have you checked the filter? this could be blocked with a build of fluff etc.
Can you hear the pump running when it is supposed to be emptying. This means there is a blockage. Can you hear a "humming" This means the pump is jamed, may be a coin or some other small item. If there is no sound then the pump is most likely at fault.
May 04, 2012 | Washing Machines
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit WI 121 washing machine
If this is a front loader it could be the up/down motion causing machine to vibrate against the floor. You can pick up some cushion pads for front load washer and dryers at the dealers to go under the four corners of the machines.
Dec 29, 2007 | Washing Machines
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
156 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
