Question about Kenmore Microwave Ovens
What does F6 mean on the display - Kenmore Microwave Ovens
Whirlpool 6 sense f6
Normally the F6 code means a shorting cook relay. That can be repaired for $39.95 in most cases.
But it would be best if we knew your full model number from the cooking cavity or elsewhere on the oven.
Jun 09, 2013 | Microwave Ovens
Getting an "F6" error on
HELLO.
An F6 error code typically indicates a controlpanel problem. Disconnect power and wait several minutes before plugging itback in. If the F6 error code comes back within a minute of restoring power,the control switch pulse return line is not connected properly. This willgenerally require professional repair.
Thanks.
Sep 21, 2011 | Kenmore Microwave Ovens
How to resolve the F6 E0 error code on the built-in Kitchenaid microwave oven? The unit was brand new and installed 2 and half years ago in my new house. One website mentions the description for this...
"F6" on a Whirlpool microwave means you have a shorted cook relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 26, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
While using the Bake Potatoe setting the code F6 came up on the display and the light went out and the machine was making a humming noise.
F6 on a Whirlpool microwave means your cook relay has shorted.
We can repair that with our $39.95 service (details here) or you can order a new control circuit board from the Pros here.
Jan 24, 2011 | Whirlpool Microwave Ovens
It wasnt working at no display nothing, i took down and cleaned real good now im getting a F6 code
Funny that a cleaning would revive a totally dead microwave! Never would have guessed. On microwaves manufactured by whirlpool, F6 apparently means "Microwave relay failure. Check wiring to relay 4903 for short circuits."
Talk to your local service shop and see if they will replace a microwave relay... they should be able to give you a parts and labour estimate before they begin so you will know what you are in for.
Oct 21, 2010 | Whirlpool MH1150XM Convection/Microwave...
Microwave is humming when off display says F6
We had a power failure for 2+ hours. I went to defrost something when the power came back on. Somewhere along the line the F6 popped up. With the door closed it sounded like the machine was running.
I slapped the side too and it worked. I pulled the vent cover off to clean it and found the tech sheet stuffed in a bag inside. I found what F6 means. 'Microwave relay failure. Check wiring to relay 4903 for short circuits. If wiring is ok, replace control board' Then, of course, a whack on the side by the button panel worked
just as well. rek('_tx6');
Reference: It means the relay is stuck in the run position. Apparently if you slap the unit hard enough it will unstick the relay and allow it to work properly again. rek('_tx7');
Aug 06, 2010 | Kenmore Microwave Ovens
Midway through heating my lunch, my microwave started making a funny noise and "F6" came up on the display. Now I can't get it to work. What does this mean and how do I fix it?
The F6 failure code on a Whirlpool microwave means the cook relay on your control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or two with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please mention your full model number from the tag on the unit) for more information & help.
prototech@usa.net
http://www.microwavedisplay.com
Apr 17, 2010 | Whirlpool Microwave Ovens
Whirlpool wmh1162xvs service code F6 after power failure
This is almost always a shorted microwave power relay on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Or feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Jan 14, 2010 | Microwave Ovens
Displays F6 error code, hums when you start it and the tray circulates when you open the door
Depending upon which make and model you have, F6 is the code for either relay failure or shorted tempurature probe.
May 01, 2009 | Microwave Ovens
I replaced the light bulb, now it displays -F6- and pushing any button causes a humming noise.
I left the unit unplugged over night, plugged it back in the next day and still had the same problem.
Oct 13, 2008 | Roper Microwave Ovens
Microwave Ovens Logo
47 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
