Question about Dell E173FP 17" LCD Monitor
Have a dell DE 173 FPC LCD monitor. When power switch is pushed, the green light comes on then goes off. I replaced a defective 3.3 volt regulator on the small circuitr board. If I have the 4 plugs thatconnect to the high voltage disconnected, the power light now wil stay on, and act as it should. As soon as I insert the 4 high voltage pluges the power light goes out. With respesct to the TL1451 controller, only 0.4 volts on the output. The high voltage side of the larger board seems dead except for 12 vdc, and 3vdc etc. Like to get some help on this problem. I have electronic experience with surface mout componets and can replace them. Some surface mout capacitos don'r seem to act right with my DMM. Thanks for any help. LDendinge
  • Bud Martin
    Bud Martin May 11, 2010
    Does your monitor PCB look like this one? No shorted transistors in the inverter transformer driver circuits?http://s807.photobucket.com/albums/yy352... Shorted out transistors are common problem in the 172/173 series
  • 89 Answers
Hi, i repair these monitors regularly, capacitors you test, are they close to a block of transistors? the four plugs you speak of are the backlamp connectors. two things, the backlamps could be shorted due to rubbed wire insulation near where they disappear into the screen. second, more likely cause. the block of trasnsitors right next to the high voltage plugs. they are NPN power transistors. it's been so long, but i think they are labeled C5404, don't quote me on that, but they are likey bad and what maybe causing the funny readings on the capacitors. i have never purchased an oscilliscope to test properly, but the DMM ohm readings should show about 3.5 K ohms from end terminal to end terminal(three pin transistors, outside pins, both) when i found ones that were not high in resistance, i junked em. but be careful to only test the one labeled beginning with C, if you find other transistors on the board away from the high voltage block, they are not the same, likely mosfet PNP type and if you test, you may short with DMM. don't worry about capacitors ohm reading, only if they have blown tops of course. most of the time, if i really suspect a bad cap., and if it doesn't have blown top, i will charge with 12 volt power and then check draw resistance dicharging to ground with ohm meter. good luck, hope i helped some.
Posted on Jun 17, 2010
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
The DELL E172FPb LCD Monitor (switch light flicks green)scr black
hi, extremely common problem for dell 17 in monitors. the capacitors and transistors on the power board internally have gone bad. to get repaired, it may cost 40-50 at a shop. i have repaired these in the past and they always come out well for at least 3 more years. may want to find another monitor though. if you would like steps on how to repair, let me know and i will find my old repair threads to give to you.
May 12, 2010 | Dell E173FP 17" LCD Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
HELP ME
I HAVE a MONITOR DELL E193 FPC AND BIND to LAST 3 SECONDS IT ERASES AND IF I COME BACK TO BIND IT IS BLACK AGAIN WHAT IT CAN HELPS BE ME I AM NOT IN CONDITIONS TO CHANGE NOW OF MONITOUR AND TASTE OF THIS OBLIGED MODEL
Jun 13, 2009 | Dell E193FPC 19" TFT LCD Flat Panel...
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell LCD E207WFP (Switches on Briefly then goes Off)
two case trouble reason and need to do:
1) back light driver (inverter) works not stable and DC power protect. it near some component damage, should repair inverter by egineer.
2) back light (lamp) over life cycle so protect by the inverter, should change new lamp (regular parts)
3) DC power supply not stable or component over life( wave filter capacitor), should be replaced
Aug 03, 2008 | Dell E207WFP LCD Monitor
Display goes black after 5 minutes
Repairing the DELL E171Fpc LCD Monitor with the complaint of display shutdown after few seconds (power LED still on) was not difficult. Normally when this type of problem happens, we would first suspect the inverter board, then the filter capacitors and lastly the main board. A defective in one of the lamps and a faulty TL1451AC PWM IC or inverter ic may caused the display to shutdown as well. If the lamp is defective, it will send a feedback to pin 3 or 14 of TL1451AC IC and caused it to stop producing output signal thus the display just shut off once you switch it on.
Dec 09, 2006 | Dell E171FPb 17" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
300 people viewed this question
Alun Cox
