Question about Maytag Neptune MDE5500AY Electric Dryer
How do i open the back door of dryer to check
This is to check the funny noises inside ?motor
    Sergeant:
    Champion:
  • 263 Answers
You access it from the front. Open the door and you'll see 2 screws on each side. Then you can figure it out. Make sure you unplug it!
Maytag Neptune dryer repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 07, 2010
After doing a few cycles the dryer would not turn on. Pressed the start button and it made a buzzing noise 2-3 times then no noise at all. After letting it cool, took the dryer apart, cleaned it out and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 12, 2011 | Dryers
My Hotpoint Aquarius TVM570 started making a funny noise then cut out... I changed the fuse to see if it was that but no luck. You can turn the timer but as soon as you press 'start' it just trips...
if you check this link it shows the basics for getting in the dryer ,, after that , you may have to remove the vent tube inside ,, you will see a fan attached to the back of the motor, your missing Rib could be rubbing against that or possibly even the drum as it turns,, be sure and unplug the machine anytime you remove the back
Jun 12, 2011 | Hotpoint Dryers
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
My dryer drum sparks when i push on it
You have loose or shorted wiring in the dryer. Unplug the dryer.Raise the top lid. Remove the screws on the top right and left inside the dryer to remove the front panel. Disconnect the door switch wires and set the panel aside. Reach in under the drum and remove the drive belt from the motor and pulley. Remove the drum. Inspect the wiring visible inside. Remove the rear panel from the dryer and inspect all wiring and thermostats and fuse relays.Remove the terminal cover where the cord connects and inspect all wiring there for broke or loose. Open the control panel and inspect all wires there for broken or loose. Repair any wiring found defective and replace any parts found defective.
Sep 17, 2009 | Kenmore 83142 Electric Dryer
Access motor
Your dryer and motor can accessed a couple different ways depending on the make and model:
1. Can be the Top (remove 2 screws near filter-pull) can slide a putty knife and screw driver and pop the top off.
2. Also, the Door must be taken off to access the motor (Screws on inside of door)
3. Bottom - panel comes off by sliding a putty knife or screw driver and dis-engaging.
After intially opening the dryer cabinet; you will most likely need to remove the front door by removing 2 screws located at the inside top corners (1/4'). ** Be sure to turn off power to unit before opening and servicing.
Whats the problem? Humming noise? Not tumbling/turning? How old? What make?
Jan 27, 2009 | Dryers
Dryer won't turn on. No noises prior to not working.
The door switch does more than turn on the light when you open the door.. It also allow's some to activate the motor circuit thus when you open the door it stops.. the points inside this switch can go bad like the points on an old car and when they do from moisture they make no contact.. check it with a meter from the inside..
May 17, 2008 | Kenmore Dryers
Fisher Paykel dryer
buzzing sound generally come from the motor assy, not necessarily a bad motor however. try opening the front door and along the inside of the top of opening is 2 phillips screws the top will tip back and then removing 2 5/16 screws from inside the font panel will remove giving you access to the motor blower assy.. it is possible that something( baby sock, small undergarment) has fallen inti the blower preventing free spin also resulting in a buzzing noise, if so simply remove debris and reassemble.
May 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
Hotpoint dryer stop working
if its the same as my dryer CTD40 (or similar) then you have to remove the sides to check into the dryer if anything is stuck, i had a plastic burning smell once and found it was one of the runner wheels had dislodged and was scraping on the drum just re-aline the wheel if it is that, they do come off easily if the dryer has been moved, as i found out. also you will find that the sound of the dryer will change, (scrapeing noise) dont let an engineer lie to you and tell you the bearings have gone, (when i say engineer i mean when you call one out NOT Fixit engineers)
Good luck
Mar 22, 2008 | Hotpoint TDC32 Electric Dryer
G E dryer
Open the service panel and look for a broken belt and does the motor spins. Let me know if you will need for further assistance. Good luck!
Sep 08, 2007 | Dryers
Kemore Dryer will not start
the dryer is almost 15 years old! the drum rotates on two or three felt bearings in front and a ball bearing in the rear. the belt may have broken, the tensioner may have loosened. the motor goes in one direction only and starts off a centrifugal start switch. If the motor doesn't get up to speed to open the start winding, the machine just won't go. check the belt first.
Sep 04, 2007 | Kenmore 62602 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
79 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
