Question about Westinghouse L1975NW Monitor
AC inverter dead - Westinghouse L1975NW Monitor
  • 11,361 Answers
Please look here: http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
Bad caps, blown fuse, blown MOSFET.
Posted on Feb 08, 2010
How to i get the timer on a Fujitsu Halycon inverter to repeat every day?
is not possibily,to any ac.the timer run just for 24 hours.on the power surce of your ac you can make a timer control programms, who take or give energy to your ac inverter(you put the ac inverter to run , and when the energy is shut down ,the ac inverter is stop working and when the energy is come back the inverter start working)
Nov 26, 2013 | Heating & Cooling
The power and everything is on but the screen is dead
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Sep 16, 2010 | Computers & Internet
Will not turn on
sounds to me like there is a dead short somewhere in the system, I would take it to an electrical appliance repair shop and they can fix it. If there are none in your town then look on the internet for one in your state so you won't have to send it very far to get it fixed.
Jul 14, 2010 | Vector MAXX SST 500 Watt / 1000 Peak Watt...
Xantrex Inverter/Charger has no AC output
HI
Checking AC Output
1. After the battery voltage and connections have been checked, disconnect the inverter.s AC output wires from
the power distribution system and connect a light to the AC output of the inverter/charger.
2. Disconnect the remote panel to eliminate it as a possible problem.
3. Turn the inverter ON using the power switch on the front panel of the inverter. The 100-watt light should
illuminate. Measure the voltage at the AC output wires using the multimeter. The reading should be 114.126
VAC or approximately 230 VAC if the unit is an international model. If the light does not illuminate, there is
a problem with the inverter. Contact Xantrex technical support.
May 21, 2010 | Kitchen Ranges
I have power and sound..no picture
smcclain2, Might be a possible failure of the electronic "ballast" circuit that provides 600 to 1000volts AC to light-up the "cold-cathod-fluorescent-lamps" (CCFL's) hung on rear of the glass lcd panel and provide white light so you can see what is on the panel!! The "ballast" is called an "INVERTER". DCv to AC The new energy efficient curlie-Q screw-in light bulbs use a CONVERTER type ballast. AC to AC. You or ccfl back-lit monitor technician will need to troubleshoot and repair the ballast circuit board. Same "lighting technology" is used in 98 percent of all lcd computer monitors. 12fixlouie
May 18, 2010 | Polaroid TDX-01930B 19 in. LCD HDTV
Hi I have a Tripplite 3636VR connect up with 3 X 200AH batteries in series. The inverter works fine when connected to city power, when the city power fails the inverter takes over noramlly, I then go and...
check the system but you may have to turn off the batteries
the inverter is charging the batteries but when mains power fails , the batteries will be discharging back through the inverter that is dc converted back to ac
if you power on a genset and the ac is not phased correctly, what you describe will happen--- inverter ac from the batteries against genset ac to the inverter-
If you had mains power on then it would dead stop the genset because of the out of phase situation
it all has to do with the 2 wave patterns for ac current from each unit being in harmony and not working against each other
Mar 19, 2017 | Tripp Lite PowerVerter APSINT3636VR UPS...
Xantrex Prosine 1800i "DCDC Shutdown" when connecting AC Load
Hi Schnupfy,
Well, it may be advertised as 1800 watts, but that is a peak. While the 230 VAC may be dead on target, don't expect it to run a mig welder.
Sustained high output is totally dependent upon the power source. What it's doing is protecting itself. DCDC Shutdown indicated 'An overload or system Fault'
Possible problems that would cause this:
  • The load is too high (what is the load?)
  • The power source is intermittent or weak
  • The power source is run through a distribution panel or isolator (Voltage drop)
  • The wiring from the 12VDC source is too long for the gauge used
Click here for a PDF copy of the manual. It is quite well documented.
BEST REGARDS,
MIKE
Dec 18, 2009 | Xantrex Technology Xantrex Xantrex Prosine...
Dead appearing ups/inverter
keep on your main switch. off all the lights fan and other electrical items, let that inverter get charge first
Jun 18, 2009 | APC Back-UPS CS 500VA UPS System
Xantrex 2412 will not open my Chamberlain Lift Master Prof. door
That must be a pretty big door opener. Problem is probably the motor's starting current draw. Most AC induction motors pull 5 to 7 times their rated running current when starting from a dead stop. (about 7,820 watts) That's much more than the surge capacity of a 2.4 Kw inverter. Sounds like you need a bigger inverter or a smaller door motor.
Jun 06, 2009 | Xantrex Technology Trace Series Inverter /...
Monitor went black completely dead
Hi...there,
A simple way to check your AC Adapter, plugged into a socket and see if it lite green... If you don't see a green light lite on the AC Adapter, then it's DEAD... You can order the AC Adapter @ www.3rd-rocks.com but sometime you need to replaced both. Have a nice day!
Nov 17, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Westinghouse L1975NW Monitor Logo
149 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Dudeman321
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
