Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Every winter my craftsman Lt 1000 has a difficult time starting, during the summer it will start. Thought it was battery, batter was change. Usually have to jump it to get it started. won't start no more. was always slow cranking over during winter also
  • 246 Answers
SOURCE: i need a owners manuel for Craftsman LT 1000 Model# 917.272650
Hello bostont1228:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. You can Also Enter "Owners Manual" in the Search Box and it will Direct you to the Page you Require.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman LT 1000 won't go into reverse or forward
the hydrostat rearend or the belts to loose
Posted on Jun 07, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
  • 138 Answers
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Posted on Aug 25, 2009
SOURCE: craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
My craftsman LT 1000 wouldn't start, it's silent. I changed my battery - still the same.
1. try jumping your mower battery with your car/battery and see if it cranks. If it does, charge your battery. If it doesnt
2. try jumping directly from battery to starter. If that works, its your starter solenoid. If it doesnt,
3. change the starter.
I would need engine model number in order to find your part numbers.
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
are you saying you get no click when turning the key? the starter solenoid should make a clicking sound atleast...sounds more like a safety switch. either located under the seat or on the clutch /brake pedal is not allowing the circuit to be complete so you can start the machine. if the blades are engaged it won't start/ if brake is not depressed it won't start/ if your not sitting in the seat it won't start...each one of these areas have a microswitch that can stop it from starting when turning the key. under the seat its usually a large round button you can depress several times then try again...disconnect and reconnect all the microswitches and look for corrosion on the electrical connections when you do. I hope this helps you
If the engine is hot. when you off it will not start again mitsubishi carisma
Vapor lock is a problem that mostly affects gasoline-fueled internal combustion engines.
It occurs when the liquid fuel changes state from liquid to gas while still in the fuel delivery system. This disrupts the operation of the fuel pump, causing loss of feed pressure to the carburetor or fuel injection system, resulting in transient loss of power or complete stalling. Restarting the engine from this state may be difficult.
The fuel can vaporize due to being heated by the engine, by the local climate or due to a lower boiling point at high altitude. In regions where higher volatility fuels are used during the winter to improve the starting of the engine, the use of "winter" fuels during the summer can cause vapor lock to occur more readily.
Aug 27, 2013 | Mitsubishi Carisma Cars & Trucks
What are the benefits of insulated dog houses?
Insulated dog houses offer few benefits that should be noted:
  • They help keep the dog warm during the winter.
  • They protect the dog's health during weather changes.
  • They are usually made out of cedar wood, which is affordable.
Oct 25, 2012 | Dogs
My name is dave...i live in michigan..i have a snow blade hooked up to my craftman 1000 LT..20hp..my question is..should I use craftman 30sae motor oil during the winter months?
During the winter months where the temperature is frequently below freezing, most engine maunufacturers recommend to use a 10W30 SAE oil.
The thinner, multi-weight oil will allow your tractor to start easier in the colder temp. When the temps are higher, just go back to the 30W SAE oil.
Remember to always use a high quality oil. Lawn tractor engines use the same quality of oil as cars do, so get yourself some Pennzoil or Castrol or Havoline or whatever you normally use in your car.
Most lawn tractor engine use about 48 ounces to perform a complete oil change.
Jan 03, 2011 | Craftsman Garden Tractor Weight
What motor oil weight should I be using on my 96 olds 88....we live where the winter temps can go as low as -10 F and as hot as 95F in the summer
5w 30 or 10w 30 during the winter. After an oil change... check your oil after 200-300 miles of use. Is the level the same? If so your weight is fine. If it drops, it's to light of an oil and your engine is now "drinking it" like fuel, move to a heavier weight. As far as Changing between winter and summer. Changing Oil weights is not bad for your motor so if the winter you go with 5w 30 and it works, great, shoot for the same during the summer. If it seems to "drink it" during the summer using this weight, go up to the next (10w 30)
That being said. Changing from natural oil, to synthetic, back to naturual , or vice versa... swapping back and forth between these KINDS of oil has been known to cause damage. so whatever weight you decide on, stick with one "type", natural or synthetic.
Feb 27, 2010 | 1998 Oldsmobile 88
99 Windstar starts fine in winter but not during summer or spring
its vapor locking, losen the fuel cap the next time it does it if that takes care of the problem then replace the fuel cap!!!
Feb 22, 2010 | 1999 Ford Windstar
Possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Apr 19, 2009 | Craftsman Garden
1997 Chevrolet Cavalier
your radiator could be getting stopped up. also water pump could be weak. during summer though you have electric fans that should be working. need to check. you can purchase some stuff called water wetter by redline racing oil that will drop water temp 20 degrees which is substantial when a thermostat is usually 180 to 190 and boiling is 212.
Dec 10, 2008 | 1997 Chevrolet Cavalier
Battery is dead and I want to charge it and take it in for replacement
Boost your car with jumper cables and let the car idle or drive around for about 20 minutes for the alternather charge the batter on its own .if the car shuts off after you started it might be your alternather is no good . the reason why ur alternather might not be working is because the batter all it does is give enough power for the starter to crank the engine as soon as the engine starts running it gets all its juice from the alternather and it charges the batter as well. but some times when the alternather works and the batter is dead meaning all the cells inside the batter are dead it will never take the charge from the alternather. so you would have to change the batter.
if you would like to know how you can you test both parts useing a volt-a-meter... just ask...
p.s. I think its ur batter if you never changed it. so get that changed for the winter so you wont have any more starting problems during cold wheaters
Sep 26, 2008 | 2001 Chrysler PT Cruiser
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
136 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
