Question about Garden
What is the gap setting on a poulan pp4218av chain saw between the coil and magneto
    President:
  • 2,220 Answers
You need something non-magnetic. Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
Card stock is usually 0.0085 - 0.0095"
If you still have no spark after assembly please reply below and I will happily assist you. HTH
Lou
Posted on Feb 08, 2010
Poulan Pro 42cc 2-Cycle 18'' Gas Chain Saw excess oil on chain
are you using a chain bar oil as this is a lot thicker than normal engine oil
Jul 16, 2012 | Poulan PP4218AV 18" Chain Saw
How do i adjust the module-ignition on poulan pro chain saw model #PP4218AVWhat's your problem?
are you talking about the magneto to the flywheel gap i just use a piece of paper between the two and tighten it
Apr 07, 2012 | Poulan Pro Chain Saw 46cc 20"
Sounds loike its running lean, start by replacing the fuel filter on the end of the pipe in the fuel tank, if this does not help you need to richen up the mixture screws, unfortunayly you need a special toll to adjust the screws ( they have a spline, not a screwdriver slot ) the tool is part no. 530035560, once you have the tool unscrew the carb screws 1/2 turn on each and try again.
Feb 13, 2011 | Poulan PP4218AV 18" Chain Saw
Gap between magnato
Use a clean and dry business card to set the gap from magneto to flywheel. It is almost the perfect (.006") gap setting.
Aug 19, 2010 | Poulan Pro Chain Saw 46cc 20"
Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin: need gap for magneto adj....
Ignition module gap
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 27, 2010 | Poulan Garden
Chain saw chain replacement
Pages 6 and 7 are quite detailed.
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2004/NOUS2004_530165555-01.pdf
If you saw is not a Poulan PP4218AV you can find your manual here (chain installation should be similar):
CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
I hope this was helpful. Additional assistance can be found adding a reply below.
Lou
Jan 24, 2010 | Poulan PP4218AV 18" Chain Saw
Chain slips off bar
I would suggest adjusting the tension and cleaning and debris along the chain path (guide bar).
Here's the manual for Poulan PP4218AV =>
http://72.3.225.179/manuals/165555e.pdf
Look at page 6-7 for instructions to adjust the chain tension and page 16 for cleaning the guide bar.
Here's the link to other Poulan Products =>
http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
Jan 03, 2009 | Poulan PP4218AV 18" Chain Saw
Garden Logo
217 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
