Serial meaning 2.5mm stereo headphone looking jack to DB9 or "atari joystick" looking plug? I had one on my first Toshiba PDR-M1 camera but that was like 9 years ago. You can probably find the pinouts online for that cable, I believe it is a standardized cable.
The stereo plug is wired to the PC serial port as shown in the
following diagram:
tip ring sleeve +---------------------------------+ | | /-------+-----+--------------+ | | RxD | Gnd | TxD | 2.5 mm Stero Plug | \-------+-----+--------------+ | | | DB9*: pin 2 pin 5 pin 3 +---------------------------------+
DB9*: Optionally short together pin 4 (DTR) to pin 6 (DSR) and pin 7 (RTS) to pin 8 (CTS)
The following table also describes the camera cable's wiring:
Camera PC's Plug DB9* Signal Name Direction ---- ---- ----------- --------- - 1 Carrier detect (CD) input to PC tip 2 Receive data (RxD) input to PC sleeve 3 Transmit data (TxD) output from PC - 4 \ Data terminal ready (DTR) output from PC ring 5 | Signal ground (Gnd) - - 6 / Data set ready (DSR) input to PC - 7 \ Request to send (RTS) output from PC - 8 / Clear to send (CTS) input to PC - 9 Ring indicator (RI) input to PC
* Note that the cable's D-subminature DB9 RS-232 serial port connector
is female. This connector also goes by the historically more correct
name of "DE-9J".
i have a sony dsc-t7 camera , when it comes on now it is stuck in the usb mode and would not moved ...
(More)
i have a sony dsc-t7 camera , when it comes on now it is stuck in the usb mode and would not moved , can you fixed this problem
There is no sound on the videos I shoot using my Canon PowerShot 210.(yes, the sound is turned on on...
(More)
There is no sound on the videos I shoot using my Canon PowerShot 210.(yes, the sound is turned on on the computer :) ).
i have a nikon koolpix s50. the chrome end came off on the end by the lens. is it repairable or...
(More)
i have a nikon koolpix s50. the chrome end came off on the end by the lens. is it repairable or should i just super glue it?
krench@aol.com
My camera has a tendency to lockup when taking photos. It also locks when trying to view photos that...
(More)
My camera has a tendency to lockup when taking photos. It also locks when trying to view photos that was already taken
On my Canon PowerShot SX120IS I am having trouble figuring out how to get better audio. I once...
(More)
On my Canon PowerShot SX120IS I am having trouble figuring out how to get better audio. I once figured it out on accident but since had to buy the camera again because the other broke. When I record concerts the audio is terrible! How can I resolve this problem??
