Question about Compaq Presario 700 470024-192 Notebook
INSTALLING RAM IN LAPTOP - Compaq Presario 700 470024-192 Notebook
I INSTALLING RAM in my laptop c700 but it get hang and also restart problem due to it ,i have tryed many other brand but same problem ,plis help
Posted on Feb 16, 2010
Installing random access memory in a Sony Vaio VGC-RB30 computer
Ram is installed on the bottom of the laptop. there should be a small compartment about the size as the RAM sticks. Make sure you get laptop ram as desktop ram wont fit. From there you just push on the fins of the ram to pop them up slide one out replace and push back down to lock again.
Sep 19, 2012 | Sony Computers & Internet
I recently purchased 2 1gb pny ram ram sticks hoping to upgrade my ram. After installing the 2 sticks the computer doesnt boot. I reinstalled the original 2 512mb sticks and the computer works fine. Is my...
Without the computer model and make I can't say if it is upgradable or not. Most are upgradable to some extent. You will need to look for the product description of your laptop on the manufacturer website you may want to download the user manual from them or check the manual you have if you still have it. Yo9u are looking for the max ability of the computer and at the speed and type requirements for your ram. Also, you should know that some companies make Ram of the correct type and class but for some reason will not work in some models. I have Kingston ram 2gb modules that will not work in my Laptop but I purchased Siemens Ram of the same type and it works fine. So it may just be a matter of Ram Manufacturer.
Jan 14, 2011 | Computers & Internet
How do i install a memory ram on my computer acer 5050
I don't know your model laptop, but most laptops have one or two memory slots on the bottom of the laptop behind a panel. Remove the panel to reveal the RAM slot/s.
When installing RAM, say 1Gb when there is two 256Mb RAM modules, then you need to replace the existing RAM with two 512Mb RAM modules. Make sure the new RAM is the same speed as the original RAM or faster RAM.
Oct 16, 2010 | Acer Aspire 5050-3242 Notebook
Is there anything you need to do before or after upgrading your memory card in an hp laptop
If this in reference to the Ram Memory module/s, the answer is No.
Things to know about upgrading Ram Memory in a computer.
A) What is the Maximum TOTAL Amount for the computer. (Motherboard)
B) What is the Maximum Amount for EACH ram slot.
C) What Type of Ram Memory does the computer support. (Motherboard)
D) What frequency rate of Ram Memory does the computer support. (Slang for Frequency Rate is 'Speed')
If you have the correct Ram Memory, and are only installing 1 Ram Memory module, be sure to install it in Slot 1. (Also referred to as DIMM 1)
This is the Ram Memory slot the Processor reads first.
If I knew what HP laptop computer this was, such as the Product Number, and I knew what Ram Memory you are installing, I could help you further.
On the bottom of the laptop is a white Service Tag.
P/N = Product Number
(S/N = Serial Number. Do Not give this out online, except to HP Support)
If your problem does not regard Ram Memory, please disregard this solution.
Oct 06, 2010 | Computers & Internet
What is involved in adding RAM to Medion MIM2320 Laptop
Installing RAM is very simple. Just look on the bottom of the laptop and you should see a removable cove. Just remove the screws and you should see RAM underneath it. Now you have 2 slots on your laptop so there should be 2 there. Then just push out the metal tabs on each side of the ram and angle the RAM upwards and then out. Then vice versa.
Check out this page for generic laptop RAM replacement directions.
Link
Nov 03, 2009 | Computers & Internet
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
Installed new ram in my Toshiba Laptop... verified the type of ram needed. Now it won't boot up. I removed new ram... still will not boot... pls help.
If the unit still doesn't come on with the old ram (assuming the old ram worked and the machine booted before) you might have zapped the MB accidentally while installing the new RAM, did you gound your self, take precautions to remain "static free"...? Doesn't take much with today's sensitive instruments to zap a component or two.
Try running an eraser (No 2 pencil) over the contact side of the new ram chips.. this should alleviate any excess static in the slot and then cross your fingers.
If it wasnt a laptop i would say get a new MB (motherboard) and swap it out to see if it worked but with a laptop that is no easy task (getting the replacement MB, or installing it).
Good Luck
Jun 23, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Laptop crashes after installing ram
the ram you installed may be bad. try to swap the rams, boot with one if they aren't identical.
Mar 16, 2009 | Computers & Internet
Installing new ram
open back plate of your laptop. then u see on top of battery the ram slot.
fix your ram.into it.
check also there is any other ram?if there is u must check both ram frequency and chip company.
Oct 11, 2008 | Acer Aspire 5630 Notebook
Installing RAM to Maxdata ECO 3100x
The ram is sited under the keyboard, to remove undo case screws on underneath of laptop. Then, where the keyboard bottom edge meets the laptop case yo will find 3 lugs... which can be pushed in. Lift off keyboard, then undo access panel on right side of laptop. There you will see the 2 memory slots.
Aug 24, 2008 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
