Question about Frigidaire 24" Built-In Single Gas Wall Oven - Black
Frigidare Gas oven gas build up causes explosion when igniting
Range/ Oven does not ignite immediately- then we hear a BOOM niose when the oven eventually ignites. We think that the gas is building during delay of igniting . Pld Advise on how I can repair myself (model # = fgf354bgdf )
bigg t
  • 640 Answers
SOURCE: Fiigidaire gas oven trips power when I turn oven on
disconnect the wires going to the oven ignitor,turn the unit on see if its trips.if so the ignitor is shorted if not then disconnect the wires that go to the coil of the gas valve and do the same.i think either one of these is your problem.also if theres a fan in the oven do the same.
Posted on Jan 06, 2008
  • 135 Answers
SOURCE: Our Frigidaire 24 in wall oven won't light. The
The ignitor is weak and needs to be replaced. You can not tell by looking at it. You have to measure the amp draw through the ignitor.
Posted on Sep 01, 2009
meBNme
  • 334 Answers
SOURCE: the oven of maytag range mgr5775qdw poorly
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
Posted on Sep 25, 2009
marka19
  • 1430 Answers
SOURCE: where is the oven igniter located at in a
remove the oven racks, in back there will be two chrome screws, remove them. Lift the lower oven panel out by pulling up from the rear. Remove the screws holding the flame spreader and remove the flame spreader. Now you will see the burner and igniter attached to it. There are 2 quarter inch hex screws holding the ignitor on. GE likes to put them on an angle, so it is easier to remove the burner tube. Remove the bottom drawer and remove the screws securing the burner to the back wall. There should be one in the front too. The burner will now lift up and you can get at the screws. The new ignitor should come with ceramic wire nuts. Just cut the old igniter, strip the ends of the wires going to it and wire nut the new one on. Reverse the rest of the steps. There is also a video at www.appliancehelponline.com/servicemanual.html that walks you thru testing this part. You can also enter your model # for diagrams and illustrations.
Posted on Apr 09, 2010
heatman101
  • 43501 Answers
SOURCE: Frigidaire oven will not ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Jul 23, 2010
We replaced my ge gas oven ignightor but the gas is building up and when its heating to the right temp the door blosw open
sounds like the gas valve is leaking un plug the range and use a soapy water to find the leak
Jun 26, 2014 | GE Ovens
I turn on the stove and about a minute later it shakes the side of the house and lights. Heats well and works fine after doing this. It's a kenmore and about thirteen years old. What could be happening.
There could be expansion issues with the oven. When the oven heats up the sides or bottom could be flexing causing this. If it is a gas range with an oven igniter it could be the igniter is getting weak and the gas is not lighting right away and causes a small explosion when it does light. If it has an igniter look to see how bright it is. If it is orange in color it is probably the problem. They should glow a bright yellow. If the igniter has never been changed it could be the problem. Hope this helps.
Feb 17, 2014 | Ovens
Propane oven will not get up to tempature
change the igniter
had the same problem I was told the oven cools off
because igniter isnt allowing gas to flow
it will lite but temp isnt there
Sep 16, 2012 | Frigidare FGB24S5DC Gas Single Oven
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
Aug 26, 2012 | Frigidare FGB24S5DC Gas Single Oven
Oven turns on gas but doesnt ignite until theres gas build up and has small explosion. kenmore model 362.75702001
What is causing that is a weak oven igniter that is not strong enough to fully open the gas valve yet just open it a little,letting gas accumalate in the oven then finally the igniter gets to full strenght and all the gas explodes. By replacing the igniter with a new strong one it will stop that.
The igniter is pretty easy to replace. Just remove the floor of the oven and the wing looking flame spreader, the screws that hold igniter to bake burner can be removed, and disconnect wiring.Then attach new igniter to burner reconnect wires and reinstall spreader and floor .
The part number for igniter is WB13K21 it could be purchased at your local appliance parts store or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
appliancepartspros.com
apdepot.com
I hope i have been able to help you fix your oven,
Gene
Aug 13, 2011 | Kenmore 30172 / 30174 / 30179 Gas Single...
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The oven of maytag range mgr5775qdw poorly
Sep 25, 2009 | Maytag Ovens
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
Electronic ignition works, but the gas does not come on
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician.
Jun 26, 2009 | Frigidare FGB24S5DC Gas Single Oven
Gas Odor coming from oven
The reason you can't smell it when the oven is on is because the gas is being ignited. DO NOT USE YOUR STOVE until you get this fixed by a gas fitter. You have a gas leak, which is either a loose fitting or faulty valve or line.
Call your appliance dealer IMMEDIATELY or you could have an explosion!!!!
Sep 06, 2008 | Ovens
Frigidaire 24" Built-In Single Gas Wall Oven - Black Logo
408 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
