Question about Whirlpool Washing Machines
Whirlpool WET3300SQ1: washer, when spinning - is totally off balnce and want to know how to open it to take a look
4 Suggested Answers
  • 714 Answers
SOURCE: will not totally spin
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Jan 16, 2010
  • 1073 Answers
SOURCE: whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Posted on Apr 23, 2008
heatman101
  • 43501 Answers
SOURCE: I have a stackable washer/dryer
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Apr 02, 2011
Constant out of balance on washer
Check the inter tub ring you should hear water when you spin it by hand
if you dont hear water replace the spin tub balnce ring it must be cracked or has a hole in it and leaked out the fluid this is a counter balancer when it gows into the spin cycle
h Tech AL Wojo
Apr 01, 2013 | Maytag Bravos MTW6600T Top Load Washer
I have a stackable washer/dryer whirlpool model #WET3300SQ1. Heating element in dryer is not heating. We have replaced the heating element and it is still not working.
heatman101
Aug 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Will not totally spin
Jan 16, 2010 | Whirlpool LSR5132PQ Top Load Washer
Water setting temperatures are off
It would say that it should be under warranty.But this model has parts that are no longer availible. Here is my guess, you have a bad switch.
Part number PS1491292
on this web site http://www.partselect.com/
Please rate solution
Aug 24, 2009 | Whirlpool LTE6234D Top Load Stacked...
OUT OF BALANCE SPIN CYCLE
Check you base pads and plate pads,...also make sure you have a total of 5 springs connecting to the bottom of the tub. Make sure they are all there.
May 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool washer that wont spin or drain
open the machine and place a pen or, a screwdriver into the lid switch hole the machine should spin let me know
May 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Not draining
what happens once it quits and you advance the timer back to a nother spin cycle does it spin or does the motor not start back
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care
Kenmore 23832 top load washer
lalocke If the load is not properly balnced, your washer will shake too much on the spin cycle and it wlll never go on full speed. Gendos...post back
Mar 01, 2007 | Kenmore 23822 Top Load Washer
Washing Machines Logo
122 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
