Which way does the door go back on for the burner on the front of the monitor
  • 674 Answers
I think the window is offset a little and should be more to the right. If you look on the inside the bottom side should have the angled piece of metal. That is the angled piece should be below the window. If this doesn't help contact me at redniten@yahoo.com and I can take a picture of one that I have apart right now and send it to you.
Posted on Feb 12, 2010
Trying to mtake front panel off to convert from gas to lp
you need to remove the top cover by removing the screws out of the back,then remove the front control panel,then the front door panel and then the lower front access panel,all this needs to be removed to remove the gas line to the burner so you can take the burner tube out to change the gas orfice
Nov 18, 2010 | LG Dryers
Front Burners very low back burners not working
Front 2 burners light properly but back burner does not light. Checked cleaned spider guards, even removed the burner making certain it was clean. Reassembled the back burner but it still does not light.
Jun 23, 2010 | Weber Genesis Gold B Grill
IHOOK UP THE BURNER TO MY COMPUTER BUT NOTHING
Try a different USB port. Check if other USB devices are found when in that port.
Unplug other USB devices (keep your keyboard and monitor attached) and check if the device is recognized. Since you indicate that you used the front port, you may want to check that the cable between back of the port to the motherboard is fully seated on both sdes. Make sure that the OS hasn't been set to turn off the previously unused USB ports (this is a security and power-saving option).
I hope this helps.
Dec 29, 2009 | Sony DRX-830U (027242700338) DVD RW Dual...
Were is the gas dryer igniter located
Depending on the model the gas igniter is located near the front at the bottom, normally on the left side but sometimes on the right side. A good indicator would be a small access door at the bottom of the machine either in from or in back. The access door is used to view the igniter.
Aug 11, 2009 | Kenmore 73952 Gas Dryer
I meant to push broil, but pushed clean and my food is locked inside. How do you cancel the clean?
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Get me the model ,number for your oven and I will be able to help you better, Thanks, Sea Breeze
Mar 29, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Need Manual For Electrolux Oven Model EOB 985GR
Having trouble locating the correct model number. Look at following areas for the model number
  • Let me know, Sea Breeze
Mar 27, 2009 | Electrolux Ovens
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Front right burner on GE glass top range not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Feb 28, 2009 | GE Profile JKP18 Electric Single Oven
GE Elec Range - front left burner will not turn on
Dec 26, 2008 | GE Profile JB968SHSS Electric Kitchen...
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
