Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
How do i take extension wand # KC99PBZPZV06 apart.There is a electrical problem and i need to get to the wiring
2 Suggested Answers
  • 430 Answers
SOURCE: Loose electrical contact in extension wand
You have a loose connection at one of several possible locations.Inspect the contacts at the top and bottom of the wand .IF they are black or coppery or look melted, both pairs of contacts, male and female will need to be replaced.
Try to wiggle and twist the wand at top, then at bottom. If this does not reveal the short, work your way back down the hose towards the a vac itself, starting behind the hose handle.
Posted on Sep 06, 2009
Repair extension on miele vacuum?
My Hoover had the same problem. I disassembled the plug and socket and cleaned all contacts with alcohol, gently compressed the prongs in the female socket with a pair of pliers so they would grip the male pins more tightly, and reassembled everything. If your wand's socket won't come apart, use Q-tips to clean the contacts and a pair of small screwdrivers to squeeze the prongs together. Also, my wand had a some play in it which caused the contacts to loosen up in the first place, so I used adhesive-backed felt strips to keep it from wiggling. So far so good -- I'm at 18 months and counting!
Oct 31, 2014 | Vacuums
I have a Kenmore 11659812991 canister vacuum. The carpet cleaning accessory that has the spinning brush turns off and on - seemingly randomly. I took it apart and did not see any loose connections (I
There is an electrical connection at each end of the wand, it could be any of the electrical connections. Could be a bad wire from the lower connection into the vacuum
Dec 27, 2013 | Vacuums
I have an epic 6500 sr. I need to take apart the handle on the wand to clean it (I unknowingly vacuumed over a puddle of urine, yuk!) It is a replacement wand. I've unscrewed the only screw I can find...
Look on the handle near the wand handle release button for extension and there is a little round cover, under that is another screw...usually it is a tamper proof torque screw.
Oct 16, 2013 | Electrolux Vacuums
My power mate keeps losing power. As I am vacuuming, it surges off and on. The rest of the vacuum works perfectly fine. help!
Remove the wand from the telescoping pole, and look at the two holes in the wand where the electrical connection is made between the wand and the pole. You may see corrosion, which will cause the connection to be flaky and the power assist to surge on and off.
In any case, a good bet is that the wire harness in the wand needs replacing. It's about $15. (P/N KC37GBZTZV06) You'll have to take the wand apart - 3 screws and some judicious prying - to replace it.
Dec 28, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
Power Head keeps cutting in and out while vacuuming???Canister motor keeps running but the power head starts and stops like there is a short or some loss of connection somewhere. Any ideas?
The electrical terminal at the top of the extension wand may be loose or corroded. Unplug the vacuum and remove the wand from the hose assembly. Look at the 2 prongs and clean off any corrosion using a a Q-tip or scrape with a screwdiver if it's more persistent. After cleaning reconnect the wand to the hose and try it again. If the prongs are not corroded, they might be loose instead or they might not be aligned properly. If this is the case then bending the prongs very slightly may help realign them. The part that may be giving you the trouble is called the terminal cover (PN 8191782). It costs about $10 but the problem is knowing the procedure to actually replace the part. CAN ANYONE EXPLAIN HOW TO OPEN UP THE EXTENSION WAND TO REPLACE THE TERMINAL COVER ??
Jan 14, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
Need connector wires inside wand. Electrolux central vac. 16" wand 1 1/4" wand dia. Don't need wand, just the wires.
Go to a store like Lowe's and look in their electrical department. You need wire the same gauge size (stranded or solid) and comparable insulation. Hope this helps!
Jan 09, 2010 | Vacuums
When running the 2100 Electrolux vacuum, it is stopping and starting when pulling or pushing the floor attachment. Seems like the connection at the top of the handle is a little loose or the electric tabs...
Depending on the age of your 2100, you will need to replace, the wand cord, the handle wiring and perhaps theh upper wand inner tube and handle as well.
If you examine your cord contacts they will be blackened from slippage, so will the female socket they plug into. On and aging 2100 the 1/2 inch groove at the front of the chrome handle tube begins to wear and the metal inner tube clip under the thumb button of the wand develops play back and forth. The wand comes apart into 4 pieces, plastic sheath, upper and lower tubes and cord assy.
If the hose handle groove is worn enough to allow in and out play, you will need to replace the handle, it's wiring, and at least the clip button on the upper wand as well as the wand cord.
You will find these wand parts at a pro vacuum shop but if your hose is original you will need to go to an AERUS Electrolux repair center for parts.
Post back with your results.
Nov 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Meile SEB 213 powerbrush cuts out
Your problem is either in the wand, assuming you have the telescopic dark grey electric wand. The only other thing it could be is the hose, once again, assuming you have the electric hose with either the rocker switch that shuts down the power brush, or the deluxe hose, with the electronic suction control, as well as the brush shut off. Miele wands and hoses are notorious for causing power brushes to cut off. If your Miele is under two years old, I would suggest taking it to a autherized Miele service center, and see what, if any, warranty you have left, and have it checked out. Let me know how you make out.
Jan 14, 2009 | Miele SEB 213-2 Vacuum
Extension arm
Try pulling wand up from hose with machine turned off.
Or are you saying that the wand & handle wont uclip from the body of the machine ?
http://dysonmanuals.llc.nu/
Sep 26, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
60 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
