Question about HTC TyTN Smartphone
Connecting to my laptop
I cannot connect to my laptop. I keep getting an error from the Bluetooth PAN client "Connection from [ruddle] has been denied.
Ruddle is my phone ID
I cannot find any info in regards to this. Any ideas?
My phone is a TYTN 2
  • Ruddle Mar 04, 2008
    I have bluetooth. I am unsure what H2 is though.
    And yes I am using Vista. Probably should have mentioned that!
  • Anonymous Mar 05, 2008
    What is passcode when pairing my HTC TyTn1with laptop
  • 3 Answers
Make surre your laptop has h2 bluetooth protocol. Are you using windows vista?
Posted on Feb 24, 2008
Bluetooth connection
Creative T15 Wireless Bluetooth Connectivity TroubleshootingGuideKeyword...
NOTE: Check to make siure that the bluetooth chipset is A2DP compatible.
Mar 17, 2014 | ASUS Computers & Internet
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
How to connect moto z3 to internet to use in laptop..
Hello, motorola phone pc suite or phone tools software no longer works for using net from mobile. It may better to use bluetooth dongle to connect net. Just purchase a bluetooth dongle then install driver n on your phone's bluetooth and connect it with dongle select PAN connection if possible otherwise make dial up connection. This will surely work
Hope this will solve your problem...
Jul 24, 2010 | Motorola Mobility MOTORIZR Z3 Cellular...
Hi... I am using dell vostro 1510. I can see bluetooth sign on my laptop. but unable to use bluetooth. Please help me to use bluetooth
U can connect your system to internet using ur mobile phone through bluetooth.For this u need to set Bluetooth Personal Area Net(PAN)or use ur phone as dial-up modem.Check information of ur mobile to see if it can support either of these methods.Once the PAN is set, u can use net .If ur phone could be used as modem,do following to connect to internet.
Make sure that ur phone is paired with with ur comp.For more information,see Set up a Bluetooth Enabled Divice.
2.Click to open the connect to Internet Wizard.
3.If u already have Int.connection,Click Create new connection any way.
4.On the "How do u want to connect",Click "Dial-up"and follow the steps.Be sure to select ur phone.
5.On the "Type the information from ur Int.service provider(ISP)" page,in "Dial-up phone no." type ur phone no. or carrer no.
Contact ur mobile service provider to get required ID,Password,carrer code or phone no.
Apr 10, 2010 | Computers & Internet
How can i connect HTC P3300 to pc with bluetooth
It's as simple as that.
1. Enable bluetooth on your HTC phone.
2. Tap 'Start' > 'Internet sharing'.
3. From the 'PC connection' drop-down list, seletec 'Bluetooth PAN.'
4. Tap 'Connect'.
5. Enable bluetooth on your computer/laptop.
6. Go to 'Conenction Manager'.
7. Select 'Conenct via bluetooth'.
Both devices will be in sync now enabling you transfer data.
Oct 18, 2009 | HTC P3300 Smartphone
Status of wireless is connected but cannot browse
Check with this tip
Let me know if everything is clear and if you can put every setting matching on both sides: Access Point (= router, AP) and Client (PC).
Radio connection IS different from browsing Net.
Can PC browse internet when connected with LAN cable to same router?
Are both on same subnet?
Have you checked if an access list is installed in router firewall?
Is the Client blocked /allowed in Firewall?
Can you ping router from Client?
Did you see the router as default gateway in Client IPCONFIG?
Is Router IP address in HOST client file?
Any antivirus, firewall (like Zonealarm) software blocking some new LAN connection and requiring to unblock?
Jan 25, 2009 | WiFlyer - Portable, shareable WiFi base...
Bluetooth not found by computer
Hi Bryan,
if you installed the printer by USB, the computer will have installed the drivers for that connection. ( Although USB is Plug and Play ) I,d refer to your user manual regarding bluetooth connectivity, also your printer.
The bluetooth device ( printer ) usually has to transmit signals, to be detected by the Computer. You,ll probably find that if you enable bluetooth on the Laptop. And turn the bluetooth on the Printer ( if Applicable ) by turning on/off or other function ( sync et,c ) the laptop will sense the Printers signal.
Once you have a communication between the two your setup.
I,d suggest unplugging the USB, as the laptops software/hardware, will assume that the printer already has an adequate connection, and will look no further.
Hoipe this resolves your questions regarding Bluetooth Connectivity.
Mike @ compurepair.
Mar 07, 2008 | Canon PIXMA iP90 InkJet Printer
Keeping a connection with multiple laptops
Yes, you should be able to run about 128 wireless clients. Are the three laptops that have problems farther away then the OK one?
Jan 15, 2008 | Linksys Wireless-G WRT54G Router
HTC TyTN Smartphone Logo
154 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
