Question about Ice Cream Makers
Need a taylor C712 instruction manual - Ice Cream Makers
Falla term tolba
Posted on May 14, 2013
Please sent me complete parts list manual for taylor icecream machine model # c 712-58 with all parts figure
Posted on Dec 21, 2011
WHAT IT MEANS R-HPR THERMAL FAIL FOR TAYLOR ICE CREAM MACHINE MODEL C713
That code means the right side hopper thermistor probe has failed. That is the sensor that reads the temperature of product in the mix hopper.
This is the part you need:
http://www.softserveparts.com/i-26471492-thermistor-probe-c712-c713-barrel-stanbye-probe.html
If you order it from us, I would be happy to put a technician on the phone to help you install it yourself.
Aug 01, 2017 | Taylor Ice Cream Makers
Taylor c712 with pumps one side sounds like it is pumping and looks like its pumping but when you use it there is no mix in the barrel
Hi Megan,
The first thing I would do is tear the machine down, sanitize and rebuild and properly lubricate everything. If you have a spare kit, you should install all new pump o rings and seals (Parts 4, 5, 6, 8 and 14 in the schematic). Hopefully, it is either improperly lubricated o ring, or a worn out seal and that will fix it.
The plastic pump parts do wear out over time (Parts 3 and 4) and so do the stainless steel pump sleeves (Part 1). If seals and lubrication don't correct the issue, you can start looking closer at the pump parts.
I have the tune up kit available here.
http://www.softserveparts.com/i-26471781-x49463-81tune-up-kit-for-taylor-c712.html
Schematics of the pumps are here with prices and part numbers.
http://www.softserveparts.com/p-37364-exploded-parts-views-for-taylor-c712.html
Soft Serve Parts C712
Jun 18, 2017 | Taylor Ice Cream Makers
I have a C712 taylor soft serve and we have one side somehow mixing in to the other ??? how is this happening ???
The separate flavors only meet at the center draw valve of the freezer door. That valve should have an H-type seal that looks like 2 connected o rings. If you haven't replaced this seal 034698 Large Basket Seal, it could be the problem. You can buy the seal individually or as part of a kit.
You can also try to make sure that the viscosity of the product is even, you don't want one side to be noticeably softer than the other.
The other possibility is there is a problem with the mix pumps. First try replacing all of the seals and gaskets. Use this kit X49463 81Tune up kit for Taylor C712. The pump parts do wear out over time including the stainless steel cylinder sleeve. If one pump was working better than the other, that could explain the mix bleeding.
If none of that takes care of the problem let me know. tex@softserveparts.com
Jun 17, 2017 | Taylor Ice Cream Makers
Poor Overrun on Taylor 162-12
You cannot change the overrun on a Taylor 162. Once you've properly primed the machine and installed the feed tubes, the viscosity or how firm the product is.
I do not know of any soft serve machine that will give you an 80% overrun. You can adjust the overrun on a Taylor pressurized machine like the 8756 or the C712, but I believe the limit is somewhere around 40%.
You can email me tex@softserveparts.com or call 1-800-879-7839 if I can answer anymore questions for you.
Soft Serve Parts Supplies
Jun 02, 2017 | Taylor Ice Cream Makers
I have taylor machine model c712, the problems is ones i draw the icecream its melted, whats is the problem of may machine?
You have to add salt to the ice you are using to cool the machine. This will make it colder and make the ice cream harder.
Nov 05, 2014 | Ice Cream Makers
Mix is foaming in the hopper
I have a c712 and we have noticed that when i put it in sleep mode over night the hopper was getting to warm and making the ice cream foam ( we use non dairy) on the top but still liquid on the bottom. We had to turn the sleep mode temps down for over night. We haven't had a issue after that. Hope this helps.
Aug 09, 2013 | Taylor Ice Cream Makers
Hello. We have Taylor c712 with air mix pump. After 1 hour (18-25 cups) product is overfreezed(have a grainy and icy texture) and temp of tthe product between 14-15 F.
it is over freezing, you need to have the viscosity adjusted and also make sure you are removing all the water when you are priming unit.
Sep 05, 2011 | Taylor Ice Cream Makers
I was wondering, I have two two barrel taylor soft serve machines from an old Carvels Ice cream store. The model numbers are c-712-33 and 8771-33, They were on a glycol machine, DO you have to have a...
This particular Model C712-33 goes into a heat cycle every 24 hours depending to pasturize the mix ,usually good for two weeks.Then the machine must be brushed cleaned.The timer can be disabled as to allow for regular operation.
Jan 18, 2011 | Taylor 632-27 Ice Cream Maker
Ice Cream Makers Logo
579 people viewed this question
Top Ice Cream Makers Experts
Andrew Taylor
Andrew Taylor
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
