Question about JVC AV-32230 32" TV
Lost of sound. was working fine but when we turned it on this morning, no sound. all connections picture working. sound from external inputs working, i.e. VCR or feeds from cable, etc.
Received help from a local technician
Posted on Feb 08, 2010
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
Suddenly no sound is coming from the tv
Unplug set and or a box if used for a while and plug back to let units reboot.
Look in menu to see if speakers are switched on or off.
Look to see if a DVD etc connected to a rear input has sound or not.
May 29, 2012 | Toshiba Televison & Video
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
Tv sound wont work
Make sure that all scarts and sockets are plugged in tightly. Try different inputs, try connecting a DVD player or another piece of equipment to the sockets in turn. Also, if you`ve got a sky box, remove the scart plugs one at a time and reconnect it immediately so that you know where you took it from. Check if there`s a switch on the back for external speakers, Make sure it`s switched to internal. Some of the TV`s have the switch for internal and external speakers in the menu`s. Make sure that any switches whether mechanical or electronic are switched to internal. Ian
Jul 24, 2009 | Philips Televison & Video
WORKED FINE WHEN TURNED OFF, THEN NO SOUND WHEN TURNED ON
1. I would first make sure that correct "INPUT" setting is registered.
2. Try a different input source such as VCR, DVD or CD.
3. Connect a pair of audio RCA cable to all the VIZIO set's audio inputs one at a time and touch the center tip while the set is powered ON and the input is set to the corresponding seting. If audio circuit is OK you should hear a hum with at least one of the input settings..
4. If still no audio, then it maybe the audio circuit board needs to be checked.
May 15, 2009 | Vizio L32 32 in. LCD HDTV
Sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
Television has sound but no picture
Check the cables first that connect to your video device, are they in tightly?  Test the cables on another TV to make sure they haven't gone bad, which is common.  Also check the input selection on the TV to make sure it matches with the video input the cable is connected to.
Dec 06, 2008 | Philips 50PFP5332D 50 in. Plasma...
DVI connection fault
I had the same problem, you must call Viewsonic to change your screen. The DVI input on the screen is dead.
Jul 08, 2008 | ViewSonic VX2255 Monitor
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
JVC AV-32230 32" TV Logo
43 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
