Question about Toshiba Satellite A75-S229 Notebook
Computer turns on and boots up , however, the screen is dark
Computer turns on and boots up , however, the LCD screen is extremely dark, is there a fix for this or the screen needs to be replaced
  • alvarezfam68 Feb 07, 2010
    Windows xp
  • Jeremy Kuipers
    Jeremy Kuipers May 11, 2010
    Which operating system are you using?
    Genius:
  • 1,189 Answers
Hi, hope this will help you with your problem.There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop,” click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics . 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer.” *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “Did this solution help?”
Posted on Feb 09, 2010
    Scholar:
  • 106 Answers
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Posted on Feb 08, 2010
2 Suggested Answers
  • 540 Answers
SOURCE: Computer turns on and boots up , however, the
No the screen is fine the back light is not working you have replace the back light of the screen to resolve the issue.But before that please try the FN+F6 or F7 keys to control the brightness.
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
My Emac will boot up but it will not light up.What can I do?
Look closely at the screen, can you still see the icons in the background?
If you can and it seems extremely dark. then your problem is likely an lcd inverter board. This isn't a terribly expensive part but getting it replaced might not be cheap labor wise. An lcd inverter is what powers the backlight for the screen.
Oct 22, 2009 | Apple eMac G4 M9425LL/A Desktop
My gateway computer screen is dark it flashes extremly light sometimes but mostly dark how do i fix it ?
most likely your invertor, which controls the power distributed to your lcd. probably bad have a tech swap one out for you, its located right under your lcd.
Oct 16, 2009 | Gateway 450ROG Notebook
My screen is dark when the computer logs on (but I
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness.
Sep 24, 2009 | HP Compaq nx9030 Notebook
Once the PC is booted up the monito screen goes dark
try another monitor to isolate if it is the monitor, if it is the LCD, the back light may be going out
Jul 07, 2009 | Computers & Internet
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
May 27, 2009 | Dell Inspiron 1501 Notebook
Backlighting issues on tv set (I think). Screen goes extremely dark after about 30 min. of viewing. Does not return to orginial brightness unless unit is left off for a long period of time
Lcd tv sets are lit by small glass florescent tubes called cold cathodes and, are powered by: ballasts called inverters... these go out just like your office florescent lighting the parts can be purchased online from electronic parts houses and, are easily replaced
May 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
My ViewSonic computer monitor keeps displaying a Vga Not Support Message upon booting then the message Out Of Range comes up on a completely dark screen. Need Help
It sounds like the computer is trying to use a resolution that the monitor cannot handle. Boot into safe mode by pressing the f8 key during boot up and select safe mode. Once booted, right click on the desktop and select properties. In settings lower the resolution by moving the bar to the left and reboot.
I would move it all the way down, you can then move it up a step at a time once you are in normal mode again.
Hope this helps
May 02, 2009 | ViewSonic VA721 17" LCD Monitor
When I turn on my monitor I can see the Gateway letters come on the screen but then it just goes dark again. It comes on for a split second and then goes dark again.
joel_herrera, Yes, this is a very common symptom of a failing Switch-Mode-Power-Supply and/or Inverter circuit! Very common in 2-4 year old lcd/fpd's. How old is your's? Do you have warranty? Have you tried the Flashlight test? DO THIS! Reconnect lcd monitor to your fully booted PC with a known good WIN desktop screen. Then power "on" the HD2201 and tell me what happens and what you see or don't see after the screen goes BLACK! Shine a bright flashlight onto the screen at different angles and let me know the results. I'm louie12fix on fixya or lmistyrel @aol.com BYE
Apr 07, 2009 | Gateway HD2201 22" LCD Monitor
Toshiba Satellite A75-S229 Notebook Logo
215 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
