Question about Ovens
My GE gas stove keeps clocking and I can see the spark for every click. But, it doesnt turn on for a long time. It atleast takes 20-30 clicks before it turns on.
  • 1,151 Answers
If it is clicking while a pilot is present, the sensor or ignitor box is not sensing the flame. If it stops clicking as soon as a pilot is present, the spark may not be hot enough to ignite the gas or the gas may be slightly low on it's flow amount. don't over look the obvious, such as the oven being exposed to drafts which blows out the flame.
Hope this helps.
Posted on Feb 08, 2010
When one of the burners on the stove is in use the stove makes a repetitive clicking noise and one of the rear burners sparks in rhythm with the clicking.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jun 30, 2011 | GE Ovens
Gas stove with electric starters for the burners. One keep clicking after it lights. How do you stop the clicking?
heatman101
Apr 02, 2011 | Thermador Professional Series PO301...
I have a 16 year old GE XL44 which has a manual turn clock that keeps buzzing. My husband stopped it, but it is going off again. The manuals I am finding on-line have electric clocks which we don't have....
Greetings,
Remove the power from the stove to prevent shock..remove rear access panal and locate clock....there will be a small motor attached to the clock..cut the wire going to the clock motor and tape....there are other ways, but this is easiest to explain..the clock will not be working after this...or, you can have your clock rebuilt or replaced with a current digital clock
Bruce Denton
Jan 04, 2011 | GE Ovens
The lighter on the stove doesnt work and the lighter keeps making a sound? I have to switch off the whole stove cause the noise is very annoying. What could I do?
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
heatman101
Sep 04, 2010 | Ovens
Igniters will not stop clicking.
Hi
Thanks for using FIxYa.The igniter doesn't stop clicking due to a short inside the igniter circuit or due to moisture present on the ignition switch.Turn off the gas supply immediately and also unplug it from the mains power. Now take a blower or your hair dryer and blow hot air over the igniter. Also check for the following troubleshooting steps---
1) The gap between the igniter and the burner base is too large. *Should be approximately the thickness of two dimes.
2) Soiled igniter or burner base.
The above can be tested by switching the suspected burner with a known operating burner.
3) Loose wiring connections at the igniter, the grounding strap, or spark module.
4) Broken or pinched igniter wire between the burner and module.
Both of the above are physical inspections under the main top.
5) The module may have a week coil, which is not providing sufficient voltage to ignite the gas.
Even after performing these steps the igniter doesn't stop clicking then you need to replace the spark module.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Starter
Sounds like one of the control knobs got stuck or shorted in the start cycle. Can you get access to the inside where you can see each of the control knobs? Look for wiring and unplug one at a time. This may help you figure which one is shorted.
Mar 21, 2008 | GE JGRP17 Gas Single Oven
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Gas Stove - Electric Starter
Just happened to me. I unplugged the electric starter, wiped up the water, took off burners, etc., and placed a fan over the stove. After about 3 hours, I plugged in starter and the clicking is no longer.
Sep 23, 2007 | Ovens
Ovens Logo
85 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
