WHAT SHOULD THE OUT PUT VOLTAGE BE AT SUB OUT MY SUB SPEAKER HAS 6OHMS OF RESISTANCE
  • 3,230 Answers
Well power is the product of Voltage times Current.
If you load an amp with lower impedance than it's rated at, for the same voltage that the amp is outputting there will be a higher current. But if you reduce the voltage (by reducing the volume) then the current will be as it is for the rated impedance. Summarizing: Limit the Total Power that the amp is handling by not exceeding the volume. If you run loads lower than 6 Ohms, you may be exceeding the max current that the amp's output transistors can handle. You can please check the following link for more information -
http://www.churchsoundcheck.com/imp1.html
(Just copy and past the above link in your web browser)
Please tell us the model number of your Home theater system, so we can help you more accurate)
Thanks
Posted on Feb 07, 2010
Connecting a passive subwoofer to a denon 2113
you need another reciever/amp to power that sub, because that denon reciever is designed for a powered sub,. if you have another old reciever/amp laying around, you can connect the sub out from the denon into an auxillary input of any old reciever/amp, (switched to that input) with speaker wires from old reciever/amp to the passive sub
Mar 05, 2013 | Denon Avr-2113ci 7.1-channel Home Theater...
4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Dec 09, 2007 | Audio Players & Recorders
How come my two subs wont get powered with a 12 ohm load. is it to high of a load. they are 12
HelloCheck the output impedence [indicated in OHms]]. You can get it from its manual. If it is designated as; 8OHms for example; you can connect one 8OHMs speaker direltly, or two 4 OHMs speakers in serieal connection. Likeways, if the output impedence is 6OHms, you can connect one 6OHms speaker direltely, or 2 12OHMs speakers in parellel. Just see, when we connect thow speakers in serieal, the impedence will be the sum of both speaker impedences. if we connect the same in parellel, the impedence will get halved. OK.
Dec 19, 2011 | Car Audio & Video
Any difference sound if set imperdance to 6ohm?
Hello
As impedence of the speaker go low, output from it will be more, but quality will be less. You can use upto 4OHms impedence speaker, in place of a 6Ohms. Using speakers less than this impedence, will make the amp to overload and heat up considerably. Most of the Yamaha amps are designed to use 6OHms speaker with them. OK.
Dec 11, 2011 | Yamaha RX-V440 Receiver
Can i use 4ohmes speaker in- STR-DH810 av receiver
Hello
The original speaker is of 6Ohms. You can connect a 4Ohms speaker instead, but the quality will be a little less. The output power will go up, so never give so much volume as you raise on 6Ohms speaker.OK.
Apr 17, 2011 | Sony STRDH810
Volfenhag ZX4725 i am buying this subwoofer and
No the LOWER the resistance the MORE Output or Draw, If say it is 100 Watts into 4 Ohms, if you used a 2 ohm speaker it would draw 200 watts.(only if capable of delivering that amount of power) The LOWER the Resistance, the HIGHER the Current Draw. WATTS = AMPS x VOLTS. (This is not strictly true with amplifiers output though, as it is an AC Current, and a "Reactive" load, it has, Inductance, Capacitance and Resistance, all in one.and is worked out via a Formula) see below. http://en.wikipedia.org/wiki/Audio_power
http://www.hometheaterhifi.com/volume_1_1/v1n1spk.html
Now with Dual Voice Coils, Essentially, you can think of these speakers as TWO speakers in ONE enclosure. As such, They are basically TWO Speakers. Please see the website below it explains everything for you. http://www.diyaudioandvideo.com/FAQ/Wiring/
Everything is a function of Resistance and Ohms law.
Current (I) = Voltage (E) divided by Resistance(R).
Voltage = Current Multiplied by Resistance.
Resistance = Voltage divides by Current.
Apr 17, 2010 | Car Audio & Video
I have a behringer 1500 watts amp that is clipping
What is happening is that your amp can deliver 1500 Watts at a given impedance. The Sub PROBABLY is a higher impedance. Your amp runs out of voltage due to the speaker impedance, hence it "flat tops" or clips.
You will probably find the sub is 8 ohms and your amp might deliver 1500 Watts on a 2 ohm system (this is "specsmanship" to sell their product... more is better thing...
If your amp was as above, the max voltage output would be the same before clipping but with the resistance 4 times, the current is only one fourth that which would deliver 1500 Watts. So you would only get 1500/4 Watts into the speaker or about 375 Watts.
Mar 10, 2010 | JBL SP5 Main / Stereo Speaker
4 ohm speakers on Yamaha HTR 5540
Model number of the Lux? The only unknown to me regarding the answer is if the Lux speakers are designed for non-Lux attachment. If there are molded connectors on their leads I would be cautious as that is usually the manufacturer's subltlke clue that you really don't want toi mix them with other makers. If they're bare wire I think you're ok.
The impedance selector on the receiver supports minimum 4-ohm front and 6-ohm center and rear, so you'd be marginal on those last two, but barring excessive high volumes I'd think it would work. The powered sub is supported and its impedance spec is irrelevant.
Just curious, is this an upgrade in electronics? From what?
Feb 23, 2010 | Yamaha HTR-5540 Receiver
Monitor problem.
um.. im just gona say this it seems obvious but on mine one of the leads connecting the sub to the rest of the cabinet fell off and all i had to do was reconnect it and it was fine.
Aug 11, 2009 | Yamaha NS-A636 Speaker
I am not getting power to my sub-woofer that i added on sub works fine just no out put to it checked resistance getting nothing
Nothing = zero or nothing = infinite?
If it is essentially zero, you are probably OK since the DC ohms of nearly any speaker measures very low resistance; they are rated in impedance which is a complex combination of  resistance (R), inductance (L), and a little capacitance (C) and becomes the 'Z' of the rating of (typically) 4-8 ohms.
If it is measuring open (a flashing display on any resistance range of a digital meter), then you probably have a problem.
You can safely take a single flashlight battery (or any 1.5 volt cell) and apply this by tapping across the input of your sub-woofer. If it makes a fairly loud 'click' then the speaker is functional.     If it passes the test, you have connection or output problems from your amplifier.
Feb 28, 2009 | Technics SC-DV290 System
12 people viewed this question
 Grubhead
Grubhead
