Question about Sansui HDLCD-1900 19 in. LCD Television
My screen is black when its hooked up to my pc
I hooked up this tv to my pc but the screen is just black. i changed the resolution to 1028. still no help. how do i fix this
  • Sansui Master
  • 520 Answers
For a Sansui tv, select the pc input on the tv and change the refresh rate on your computer to 60hz to match the refresh rate on the tv.
Posted on May 29, 2010
Connecting pc to tv - tv shows pc screen then goes black
Try running through all the different resolution settings on your laptop, some tv's are very specific about which resolutions will display and which won't.
Nov 06, 2013 | Televison & Video
PC - TV Screen solution issues.
the resolution of your monitor is not working on your tv. Try changing the screen resolution to a different size. Right click on the desktop and choose display settings. change to either a lower or higher setting . you can work from low to high until the tv works.
Jun 15, 2013 | Philips 32PFL3505D 32 in LCD TV
Gateway laptop stopped picking up signal from tv monitor. how do I fix problem?
maybe it change screen resolution! try press press auto adjust from the monitor!
Feb 02, 2013 | Gateway CX210X Notebook
I have a new sanyo 32in flat screen for a monitor my pc loads up and it seems fine then when the log in screen should appear it goes black if i hook up a diff monitor it shows up
This most likely happens because the pc is using a resolution or frequency that is not supported by the tv/monitor. The resolution when starting pc is different than the resolution when logging in.
On Win XP right click on the desktop background, and choose properties from the pop up menu. Open the far right tab and change the screen resolution to 800 x 600. This is highly likely to work on the tv/monitor. [Vista or Win7 right click and choose personalize to get to resolution settings]
Connect to the monitor, restart pc, and you should be able to then see logon screen. Go back to the resolution setup screen and experiment with different resolutions till you find which works best for your display. You can pick a resolution and try it, then it will ask if you want to keep the setting. If you do not answer in 15 seconds, it will revert automatically to where it was a moment ago. So if the screen goes all funny or blank, just wait and it will come back.
Note that your display video card may not be able to support the optimum resolution you need, in which case you will be under utilising the screen. Everything may appear too big or stretched in one direction. In that case you will need to upgrade your video card to make full use of the screen capabilities. You should consult any documentation which came with the monitor to see what is optimum pc resolution to use, and bu video card appropriate to pc and monitor.
Nov 27, 2010 | Televison & Video
I'm trying to use my 6 yr old Sharp TV as a remote monitor for my MacBook laptop. The Sharp manual says that port 5 is the correct port for PC hook up. So, I'm hooking up the laptop's mini DVI port to the...
You need to set your MAC video resolution to the native resolution of this TV in PC mode, please read your manual to find out what that is, if the resolution is set too high, the TV will not be able to display it.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Aug 27, 2010 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
PC plug into the TV...not working
Screen resolution is set too high on the computer. Right click desktop > Properties > Settings > Change to 800x600 then connect to TV.
OR... boot the computer while connected to the TV and it should automatically figure out what resolutions the TV can do.
-=/ Daft Tech /=-
Oct 25, 2009 | Televison & Video
Screen adjustment
you have adjust the screen resolution
1028 X 600
16bit or 32bit
goto control panel----look for appearance and personalization ---screen resolution
Feb 25, 2009 | Toshiba TE2100 Notebook
Not supported mode error
Hi, boot up to an F8 and select safe mode. While there change your screen settings to 800X600.
The available resolutions in the windows operating system has to be compatble with the TV screen you are hooked up to. try lower settings first.
Thank you and god luck.
Oct 25, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Installed a nividia video card into emachine,
When this PC is connected to the TV, what is the property settings for the videos screen resolution? You may need to bring the resolution to 800x600 or 640x480.
Aug 03, 2008 | Computers & Internet
Sansui HDLCD-1900 19 in. LCD Television Logo
456 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
