Question about HTC Touch Diamond2 Smartphone
Screen scrolling problem
If I scroll down on the touchscreen of my HTC Diamond 2, first it lets me scroll down, than after a while it stops scrolling and if I tap the screen (no matter where or what I do with it), it moves a bit up or down but I can't select anything. With the end call button I can go to the home screen an that's it. Soft and hard reset didn't help. After squeezing the phone with my hands, it works but as soon as I have to scroll down a longer list, it starts all over again.
  • HTC Master
  • 515 Answers
You have the technical problem of hardware so you have to fix it so you have to go to service center
Posted on Jun 12, 2017
  • 45 Answers
SOURCE: HTC Touch screen not responding!
This is a common problem with many touch screen phones. There are about three reasons this can happen that I know of:
1. Hardware issue. Needs to go in for repair. Hopefully under warranty still.
2. Needs to be re-flashed with the OEM ROM. This is not likely, since you've already Hard Reset, but worth a try.
3. The EASIEST and FIRST thing to check is to run a 'business card' around the edge of the screen between the case and screen. Dirt or other objects can easily get wedged into that area and hold the screen pressed down. This would prevent a press from any other area of the screen. Also, a screen protector that has shifted might cause this. Hopefully this is it, as it's a simple fix!
Posted on Aug 28, 2008
SOURCE: My HTC Touch suddenly turn off, and Is hard to start it again.
the solution to the problem is explained in detail here
Posted on Oct 31, 2008
SOURCE: Hard reset for a HTC Touch Diamond
I find certain voodoo rituals to do the trick. Especially those derived from rites originating in the southern gulf coast region. To start, build a low, hot burning fire pit surrounded by granitic stones roughly the size of oranges. Be sure you have a light bed of gravel beneath the fire itself to allow air space for the spirits to commune before entering the fire and your device. Use eucalyptus logs ages approximately 2 months for the fire itself, and sprinkle a solution of pulverized bat wings soaked in winter menstrual blood from a one year old goat. Wave your Diamond over the fire vigorously while chanting the names of all three major thorn gods repeatedly. That should do the trick.
Posted on Dec 07, 2008
  • 5 Answers
SOURCE: Touch screen not responding at all
The touch pad is's a hardware issue...go to the vendor or workshop...within a year it is replaced for free.Good luck.
Posted on Feb 04, 2009
SOURCE: stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Posted on Mar 17, 2009
I went cleaning my htc p5500 screen with a dap clothes and rub it up and down now the touchscreen isnt working,jus would like to know if i reboot it will the touchscreen work?
FOLLOW this steps and fix it. God bless you
  1. Hard Reset
    • 1
      Pull out the stylus from the back of the HTC Touch Diamond or the side of the HTC Touch Pro.
    • 2
      Using one hand, press and hold the volume down button on the left side of the device, the power button on the top of the device and the circular button on the face of the device. It is generally easiest to hold the volume down button with your thumb, have your palm over the LCD, press the power button with your index finger and the circular button with your pinky.
    • Sponsored Links
    • 3
      Continue to hold the buttons down while you turn the device over to access the back side. Use the stylus to press the "Reset" button, located near the end of the stylus cavity on the Diamond, and by the port on the bottom of the device on the Touch Pro. Release the "Reset" button, but do not stop holding the volume down, power and circular buttons.
    • 4
      Turn the HTC Diamond over and watch the LCD. When a message appears saying that this operation will delete your data, release the three buttons. Press the volume up button to complete the hard reset.
    Clear Storage
    • 5
      Slide your finger to the right along the bottom of the LCD until the "Settings" option appears. Tap "All Settings" on the device.
    • 6
      Tap the "System" tab on the screen and then tap "Clear Storage"
    • 7
      Select the drop-down box and choose "Clear Storage Only." Type "1234" into the text box confirming that you do want to delete your information and then press "Yes."
Jul 25, 2013 | HTC Touch Dual P5500 Smartphone
How can I find my alarm clock on my HTC inspire phone
On the Home screen,tap HTC Clock widget.
Tap on Alarms.
Select checkbox of an alarm and then that alarm.
On the set Alarm screen,use your finger to drag up or down to roll the time scroll wheels and set the alarm.
Scroll through the set Alarms screen for available options.
Choose alarm sound and also days to sound the alarm.
Select vibrate if you so wishes.
Tap on done to save the settings.
Here's a manual for your HTC smartphone.
Hope it helps.Thanks!
Feb 26, 2012 | HTC Cell Phones
How to enable cookies on an HTC wildfire
Press all apps button (to the left of phone button on home screen). Scroll to internet click on internet then press menu and scroll down click turn on cookies. Hope this helps
Oct 29, 2011 | HTC Cell Phones
I have an htc google phone that does not display the screen on start up
all you need to do is go to settings,scroll to factory default and click on it to restore to reset every thing
Feb 02, 2011 | HTC Google G1/Dream Cell Phone Black...
Htc touch diamond 2 screen not working. i tried hard reset but cant complete as it ts asking to follow onscreen command and touch screen is dead.
plug in the phone in to windows and double click on the phone icon in My computer on your pc. go into storage drive and open the windows directory by double clicking on it. then open the startup directory and copy to somewhere on your pc (your desktop is probably best).
open notepad on your pc and click file open, in the filetypes drop down box choose all files, then choose desktop and click on the file. When notepad has opened it up delete all the txt inside and click file
Apr 07, 2010 | HTC Touch Diamond Smartphone
How to change font for HTC diamond bigger? I difficult to read text message. looking forward for u answer
I have a touch diamond...
Go to the text message thread like you are going to reply, and scroll your finger clockwise along the edge of the round middle button. Your text should increase in size. Scroll counterclockwise to make the text smaller. Hope this helps!
Apr 25, 2009 | HTC Touch Diamond Smartphone
How to change settings
This will help you Tweak out your Diamond. Click here , all you have to do is put the .cab file on your phone and run it.
Third apps. are easy to install........all you have to do is find what one suits you Sync it to your phone and run it.
Also try this site
Jan 18, 2009 | HTC Touch Diamond Smartphone
get into joggr and you have the option to scroll,adjust volume etc you might have it on scroll let me know how you get on
Jun 18, 2008 | HTC S620 Smartphone
Scrolling Input Screen
have tech take a look at your tv the problem is very technical for you to handle the vertical circuit is defected.good luck.a check should be made on the eeprom.
May 06, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
HTC Touch Diamond2 Smartphone Logo
105 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
